Question about Final Draft 7 (FD7CD)
Final draft is not responding...i keep rebooting it, but after five minutes it becomes unresponsive
Possible to fix Power Spec B633 that becomes totally unresponsive if unattended for 15+ minutes?
Most common cause of what you describe is either the power supply or overheating. To troubleshoot this unplug everything that is connected to the computer and all the items that are on the motherboard inside except the power supply and power it on. You should hear the beep signal. IF you don't then it could be the power supply. That is the cheapest thing to replace without a power supply tester. If you do hear the beep, shut it down and put the ram in and try again, then if you hear a beep, plug in the hard drive and try again, then the video card and keep going till you find the bad part. If it is the CPU that is overheating you may not be able to tell right away.
Dec 21, 2015 | Computers & Internet
How i keep web site responding ,script unresponsive ,plug in , and shock wave crashes this happen constantly
Go to the shockwave website and download the latest version. http://www.adobe.com/m/shockwave/android.html
Mar 28, 2015 | Computers & Internet
My Sony Blu Ray was working fine. I bought a used blu Ray it skipped and froze(the BD player was completely unresponsive) I had to unplug it to power it off for awhile. Then I tried watching Netflix and It...
There should be an option in your setup menu to perform a reset. Reset all settings to factory defaults and try it then. This will sometime sfix this problem. If not, then you are looking at a really expensive replacement main board that will cost you more than the unit is worth
Mar 25, 2015 | Sony Televison & Video
Splitcam will not close
Run your anti malware software to find any viruses or pups.
Malwarebytes does a good job for me.
Feb 26, 2014 | Microsoft Windows 7 Ultimate for PC
Why does my laptop suddenly become unresponsive? ex:programs i have open become unresponsive and the laptop wont shut down unless i hold the power button
Start with a 'clean boot':
Start - run "msconfig" - go to the startup tab, de-select everything and reboot. Then go back in there and select the options one by one with a reboot inbetween, that will show you which item is causing the issue.
Aug 10, 2013 | Acer Aspire One D257 Netbook
Screen cell phone keeps blacking out
Restart iPhone
Sometimes all it takes is a restart for the iPhone to become responsive again. To restart your iPhone when it is unresponsive, press and hold the sleep/wake and home buttons until the Apple logo appears (~10 seconds).
Very low battery
It is possible for an iPhone to become unresponsive if the battery drops to an extremely low level. Plug the iPhone into your computer or wall charger and allow it to charge for at least 20 minutes before using it again.
May 23, 2013 | Pantech Ease P2020 AT&T
Windows Will not detect my Philips SA6045 4gb mps player
Whenever i cannect it ,nothing comes up,nothing in "my computer" to click on.I update the driver for it,it works for about 20 seconds,then the device becomes unresponsive and i have tp update it again,which again it will connect for a short time ,become unresponsive,and then the update process.How do I keep my MP3 Player Connected.Also nothing is wrong with my USB chord.
Sep 22, 2008 | Philips GOGEAR SA6045 MP3 Player
Final Draft 7 (FD7CD) Logo
292 people viewed this question
Top Final Draft Computers & Internet Experts
David Payne
David Payne
Are you a Final Draft Computer and Internet Expert? Answer questions, earn points and help others
