My remote does not work with my bush a632" tv. i tried changing the batteries adn using a different remote but it still doesnt work. The tv light flashes when pressing buttons on the remote but it doesnt change any channels or volume etc
Hi there we had same problem so phoned 08456040105 and they told me to press menu button on tv for 10 secs and take batteries out of remote and press power button on remote for 10 secs while batteries are out. it worked for us doing both at same time....good luck
Posted on Feb 05, 2010
Testimonial: "Oh my goodness thank you so much for this advice. I was a bit sceptical but it worked wonderfully!!"
  • 1 more comment
  • phill61 Sep 18, 2010
    Thanks this was a great piece of info and im glad i looked on here many thanks.
  • kukurni
    kukurni Nov 13, 2012
    yah, just fixed remote. thank you sooooooooooo much!
  • dazzasco Jun 19, 2013
    Menu button on TV, power on or off??
You have just earned me lots of brownie points with the wife. I was ready to smash up the TV but a quick search on the net & I came across your answer. Worked a treat. Thank you .
Posted on May 02, 2010
Thanks very much worked adream
Posted on Aug 18, 2010
Thank you so much. I had the same problem and brought tv to reputable repair man. He told me there was a fault in the motherboard and it might be better to buy a new one. While my husband looked at the Argos book, I came across your tip and tried it. I couldnt believe it when it worked! Thank you so much. You have saved me a lot of time and expense.
Posted on Jul 26, 2010
Thanks for the tip as my TV was doing the same and i did do the 10 seconds thing and it worked Thanks again ..
Posted on Jul 14, 2010
Television
Try unplugging it from the outlet for a 5 minutes, and try again. If that doesn't work - try plugging in a lamp to the outlet to make sure it works. You can also try connecting the TV to a different outlet (check fuses or circuit breakers). If you use a remote - change the batteries - or try using the power switch on the TV itself.
If it doesnt work - provide the brand and model of your TV.
Apr 11, 2014 | RCA Televison & Video
Remote control for bush tv not working
REMOVE THE BATTERIES FROM YOUR REMOTE AND TRY USING THE CONTROLS ON THE TV
Jun 21, 2013 | Televison & Video
CAN YOU TELL ME PLEASE WHERE TO BUY A REMOTE FOR A BUSH A632 TV, THANKS JOHN
http://www.avukltd.com/remotecontrolsearch.php?action=send_details&item_id=558114
May 28, 2011 | Televison & Video
Bush BTU250DTR digital TV recorder. Will not turn on using remote control only with power button on front and then cannot change channel or access library, guide or menu. DTR button on remote lights up...
although the lights are working on the remote there is still no proof that its infra red led is not blown in some cases there solder point can come loose the first thing you have to do is conferm the remote is the problem as the ir receiver in the tv could be damaged first try buying a cheap universal remote and see if the tv responds if it does then you will have to have the remote serviced the cost is around @35-45 there is also i site on the net that sells secound hand remotes www.replacementremote.com you could try there but before you waist money conferm it is the remote
merry christmas
Dec 22, 2010 | Bush 5693D 24" TV
Sky remote codes for bush a632n
i have the code for bush a632 point remote at tv press tv then red and select till light flashes twice enter code 0145 press tv again press power press select all stored and ready
Sep 01, 2010 | Televison & Video
Does anyone know the code for the Sky Remote Control for Bush A632?
i have the code point remote at tv press tv press red and select till it blinks twice enter code 0145 press tv again then press power then press select to store
May 21, 2010 | Televison & Video
Remote not working changed batteries lights up but doesnt work
Use a digital camera so "see" the Infra Red (IR) beam coming from the top of the remote. Try a few known good remotes with the camera to get the hang of it, then try the suspect remote. If you don't see the light, the remote will need to be replaced. If you see the light, the problem is with the IR receiver within the TV.
Mar 15, 2010 | Proscan PS36600 36" TV
My remote does not work with my bush a632 tv. i tried changing the batteries adn using a different remote but it still doesnt work. The tv light flashes when pressing buttons on the remote but it doesnt...
Asker's Testimonial " Oh my goodness thank you so much for this advice. I was a bit sceptical but it worked wonderfully!! " - aurora393
Feb 06, 2010 | Televison & Video
My tv remote doesnt work from a distance i have to go very close to my tv for it to work, i have changed the batteries though.
There are several possible reasons. The light-emitting end of the remote, or the remote sensor window on the TV, may be dirty. The light-emitting diodes in the remote may be misaligned from dropping the remote control, or they aren't putting out as much light as they should. The TV may have another light source shining on it that prevents it from picking up the remote signal until it gets very close. The remote sensor in the TV might be bad. Or there may be an interfering signal. As more people start using compact fluorescent lamps (CFLs) in their homes, they sometimes find that remote controls begin acting strangely. It's also possible the replacement batteries you put in are weak, so you might try another set.
Sorry I can't tell you which of these is most likely. I've seen them all many times. Try another set of batteries first, then try a universal remote to see if the problem is in the TV or the remote.
Good luck! Hope this helps, and thanks for using Fixya!
Jan 31, 2010 | Emerson ET-20F7 19" TV
Televison & Video Logo
986 people viewed this question
Top Televison & Video Experts
