Question about Samsung WF337AAL Front Load Washer
Water is streaming out of soap & softner compartment during rinse cycle did a diagnostic code check and i have no stored codes samsung wf337aal/xaa purchased 9/07 made 2/07
  • igotone2 Feb 01, 2010
    Water streaming from soap tray. Seems the rinse cycle is the trouble area,right rear of soap compartment, noticed the softner and bleach cups are full of water when the wash is done not to mention the puddle of water on the floor. No obstructions, used seperate water sorce with full pressure and no tray ,drained into tub fine. I throughly cleaned the tray inside and out. Also did a diagnostic code check had little d-- c/w&c/c all it showed was d and 2 horizontal lines -- can i do something to confirm its the water inlet valve. also i just got everything perfect with the dryer(rigid alum vent, gas line, electric its on top of the washer in a corner extremely tight) dumb question do i have to undo everything and remove the dryer to access valve or is there a front access my phone#(815)762-2976
  • 311 Answers
The first thing that I would check is the top of the dispenser assy. Remove the drawer and look at the top. If it has a bunch of small holes this is where the water enters the dispenser, often times these holes will get plugged up with fabric softener (because it has a wax base) and when the water is coming in to mix with the bleach or fabric softener it will spray out in different directions.
You can take a putty knife and scrape off most of the softener, then take something small like a piece of wire and clear each individual hole out that looks to be gunked up. On most occasions this will correct the problem.
Let me know if this helps. _MJ_
Posted on Feb 01, 2010
    Brigadier General:
  • 3,917 Answers
Check for blockage into tub from inside at inlet and underneath drawer if you use powder detergent old detergent may clump and block line into tub.
The fabric softener dispenser works by time and water flow from the cold water inlet valve . Check the screen on your cold water inlet. If clean, the water inlet valve may need to be replaced. Take a look at the cold water inlet valve that has the rubber tubing running to the "bleach" dispenser nipple. It will have a water flow restrictor in it at the inlet valve. Something may partially clog the flow restrictor. Carefully drilled the valve out enough to remove the clogging object. Now both the bleach dispenser and fabric softener dispenser work properly and at the correct times during the wash.
Thanks for contacting fixya.com
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Mar 05, 2012 | Hotpoint Washing Machines
Softner is dispensed in Wash cycle
in the top of your soap draw compartment is a lever that switches the water jets over ( for instance on the main wash the jet arm is directed in the main wash compartment which will take away your main wash powder then it moves the jet are to the sofner compartment on the final rinse ) the jet arm somtimes jams and needs cleaning and the small holes above your draw compartments clog with lime build up the thing to do is take out your draw clean the inside at the top where the holes are and take the top off your machine there are two screws at the back top you will see the little ark on your soap draw it will have a return spring on it gently move it from side to side this will clear any obstuction make sure that it will spring back clean any line around the arm ( make sure you switch unplug your machine before you remove the top)
Nov 21, 2011 | Washing Machines
Fabric softner does not empty into washer during rinse cycle
Hi not sure how these work as we dont have them in the UK. With UK machines the soap and fabric softner are put into a drawer that pulls out the front of the machine. When softner and soap arnt going into machine properly we take drawer out and wash it in warm water, you usually find a lot of gunk built up blocking it, perhaps you have a similar problem. Hope this helps
Jul 27, 2011 | Kenmore 43052 Front Load Washer
Fabric conditioner compartment will not empty when in cycle
FJS1225W Front Load Washer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Zanussi FJS1225W Front Load Washer
Water is coming from soap despenser during rinse cycle, I think it maybe a clogged hose .
oull out the drawer and see if the pipe that is under the fabric softner dispenser compartment cap is all pligged up if so just clean it out w/ warm water
Feb 06, 2010 | Samsung WF337AA Front Load Washer
Softner stopped draining out of the compartment during the rinse cycle. When I open the compartment after cycle stops, there is still softner in the cmopartment
try pouring really warm water in the compartment or using small soft toothbrush type brush to clean out the build up of softener. You might try thinning your softener in the future with water if it is very thick. this works for me
Jun 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Fabric softner still in compartment after wash is completed
take out soap box first and clean,i would say that water valve coil is probably blown though,should read around 3kilohm resitance checked when unplugged hope this helps
May 06, 2009 | General Electric WBVH5100HWW Front Load...
Problems with fabric softener
check the water solenoid for open circuit, this is the water valve that supplies water to the compartment
Sep 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Samsung WF337AAL Front Load Washer Logo
107 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
