Question about LaCie F.A. Porsche (301177) Hard Drive
Not detected on laptop, hard drive beebs after bout 30secs
  • 696 Answers
The problem you're experiencing can have several causes. The beeping is a diagnostic beep but may indicate failure or simply low power. If you do not have a Same model LaCie to swap power units with, do not attempt it. You can skip to Step Two below, if you do hook it up using that adapter and that units USB/Firewire then work through the below steps.
Generally the problem lies within the the drive enclosure or the drive itself but can ocassionaly be a driver related issues with your computer.
I'll give you a few steps to try, if they work you're off and rocking. If they don't you may be beyond DIY tips but there's always the option of seeking a pro. Either way we'll give you the right advice.
Step one, plug the drive into a different computer. If it works the problem is in your computer, try a different pair of USB ports, this is important as each USB Hub controls a pair of USB ports. If the drive works on another computer but doesn't work on any of your USB ports, reply back and I'll work through that solution with you.
Step two, if it doesn't work on another computer, that serves as reasonable proof the issue is within the drive enclosure. Take the drive to your local PC shop, ask the technicians to extract the harddrive and install it in a new enclosure. If it works in the new enclosure, buy the enclosure, thank them for their time and you're ready to roll.
If it still fails to respond, the issue is in the actual harddrive. This is the point where you will need a pro to assist you. I have had great luck with Armor-IT in Canada, they are the least expensive for most types of recovery and faster than most other facilities. you can get in touch with them through their website www.aitsavemyfiles.com .
Let me know how you make out either way, if you have any followup questions please comment back into this artical as it keeps it easier for me to track your questions.
Thanks for choosing FixYa,
Crankstart
Posted on Feb 03, 2010
Hard drive cannot detect
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 03, 2013 | Computers & Internet
Detect
May 01, 2013 | Transcend USA 120GB Storejet 2.5" SATA -...
Some times randomly the screen will go black and say no signal detected then it will give off a beeb then three beebs then 3 agian i belieave whats this problem? and is it fixable or is it with the board
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
the beeps are post pre operating system searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
hope this helps
Sep 01, 2011 | Computers & Internet
I cont intstal win xp in my toshiba U200-148 laptop
you can use another installer coz maybe your installer have some scratches
May 22, 2011 | Computers & Internet
I tried to format my Dell laptop but it display internal hard drive not found
Go to the BIOS configuration and see it the BIOS detects the hard drive. If it doesn,t detect the hard drive then the hard drive coulf be faulty.
Another way to check the hard drive. Remove the hard drive and connect it to an USB hard drive adapter and then connect this to a computer's USB port. If this computer does not detect it as and external storage device, then the hard drive is faulty.
To get your laptop operational again, insertl a new hard drive and install Windows on this hard drive, together with the laptop's device drivers and your programs.
Sep 21, 2010 | Dell Inspiron 1525 Notebook
Windows did'nt find any hard drive
Sep 21, 2010 | Computers & Internet
AHrd drive Beebing and not reconized by my lap top
try using another usb cable and another usb slot on your computer. the drive is not recieving enough power from ther computer.
Jul 14, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Computer cant find hard drive
If the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 25, 2009 | Sony VAIO Notebook
Bios not find hard disk
May 24, 2009 | Acer TravelMate 2303LCi Notebook
PXE-E61: MEDIA TEST FAILURE, CHECK CABLE PXE-M0F: exiting Broadcom PXE ROM. Operating system not found. how 2 solve or repair? help me...
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
May 14, 2009 | E-Machines eMachines Desktop PC
LaCie F.A. Porsche (301177) Hard Drive Logo
214 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
