Question about Sony KP-61HS10 61" Rear Projection Television
MY PITCURE IS NOT CLEAR 3D LOOKING HOW DO I FIX IT
  • Sony Master
  • 3,459 Answers
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a Sony convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, originMY PITCURE IS NOT CLEAR 3D LOOKING HOW DO I FIX IT - 2_bing.gifrel='nofollow' href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#">Sanyo2_bing.gif STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed.MY PITCURE IS NOT CLEAR 3D LOOKING HOW DO I FIX IT - 452f0a0.jpg dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
AFTER
93a1209.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Posted on Mar 19, 2010
Picture is pink and blue and not clear.
I am going to guess the model number here is correct, sometimes it is not-----that is a older set.
Not 3d looking but washed out or dull looking firstly.
If you go to a unused video input with the color on the set turned to zero what color is the screen? It if correct should be something black and white or grey.
One of the things you can do other than that is from the rear with set not plugged in, clean the 3 large lens==if dusty picture will be darker and dull looking---they are the light source for your picture.
let me know if screen is 3d looking, screen with color off is B&W, and if cleaning the lens helps.
SD TECH
Dec 04, 2012 | Sony KP-61XBR48 61" Rear Projection...
S my picture not comming in clear and has lines threw it?
Misubishi----ws-65907 is the model number?
Two common issues here---one is convergence where picture is somewhat or very 3d looking---I can if model number correct tell you how to fix that and second issue is some models get black lines that look like interference which is a more difficult problem to deal with.
Let me know which best fits your issues.
Mar 13, 2012 | Mitsubishi WS-65907 65" Rear Projection...
Red color on every thing in pitcure.
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 21, 2010 | Hitachi 53FDX20B 53" Rear Projection...
When you turn tv on it takes 5 minutes or more to get a clear picture doublr image
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 17, 2009 | Hitachi 43UWX10B 43" Rear Projection...
The pitchure looks like its 3d. everything looks
You have a convergece board failure. Changing one board will not nescessarily fix it. It is recommended to change all 3 boards in the unit. many try this as a DIY and fall afoul because it is a specialist job to retune and reset the paramaters. The cost then becomes greater than if a tech did it correctly the first time. Be advised it is not a simple DIY.It requires soldering and desoldering skills, specialised tools and a knowledge of circuit diagrams.
Please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Convergence box is out - the picture is like looking at a 3D movie without the glasses.
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Oct 23, 2009 | RCA R52WH73 Projection Television
The picture is not clear it has a red and blue outline like 3d
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 27, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
Problem
http://www.nikondigital.com/main.html look at the service advisory link on the bottom right. It pretty much describes your problem, same model. you are eligible to a free repair. Good luck
Jun 10, 2006 | Nikon N55 35mm SLR Camera
Sony KP-61HS10 61" Rear Projection Television Logo
317 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
