Question about Epson Stylus CX6600 All-In-One InkJet Printer
Black prints not clear, even after cleaning the heads and realignment and changing of the cartridge...
  • 4,041 Answers
Hi Try this
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Posted on Feb 01, 2010
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
Changed black cartridge and now only colour printer will print in is blue/green
The black print head most likely is blocked with dried ink.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 19, 2012 | HP Photosmart 3210 Printer
Won't print in black.Colour is fine though!
your printer black cartridge is demage buy a new one
Jul 24, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Not printing - just replaced ink cartridges
Reseat the cartridges.
Do 3 consecutive head cleanings.
May 02, 2009 | Epson Stylus C84 InkJet Printer
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Standard black printing has faded to grey.
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Nov 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
Black inkwon't print
pictures are not clear even after installing new ink cartridge and cleaning print head
Oct 04, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Canon i560s printer - color problems
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
Black Ink Skipping
After entering my posting earlier today, I did some more internet searching on this problem. I found a helpful British website that listed a trick for cleaning the printer carriage area. It's a little more than halfway down the page, if you click on this link, http://www.valueshop.co.uk/printing.asp
Here is what they suggested:
"1. OPEN printer so the cartridges move to center of the carriage.
2. REMOVE all cartridges.
3. FOLD a letter size piece of paper in half, and then in half again the other way so it is quartered.
4. START with the long, folded edge and insert into front of printer where paper normally feeds out. (it will slip in a little over halfway)
5. MOVE the paper left and right to remove any excess ink under the carriage. When the excess ink is removed the printer should print streak-free. "
I tried this (actually used 3 or 4 pieces of paper because it was pretty grungy), and I can print without bands of gray now. Although, the colors are not as vibrant as they used to be, neither is the black. (My holiday newsletter looks good enough to send out, at least.)
After cleaning the printer carriage area, I ran the nozzle check pattern test again and it still looks bad. I then cleaned and realigned the print head, and again the nozzle check pattern continues to look bad. The user manual for the F60 (page 10-5)said that if the nozzle check pattern does not improve after a deep cleaning then the printhead may be damaged. I called Canon tech support and they think that the printhead is probably damaged, but they suggested that I take it to an authorized Canon repair shop, which is too far away, and probably too much trouble. My other option is to order a new printhead directly from Canon for $45 plus $6 shipping and install it myself (or make hardware engineer hubby do it ;-) ).
Hopefully this trick for cleaning the printer carriage area will help others at least for the short term, like it helped me. Good luck!
Oct 15, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
