Question about Dell Inspiron 1545 Notebook
I need the PCB to power socket pinout connections for a dell 1545 laptop
    Sergeant:
  • 226 Answers
Hi, try this link, it may help you butmay be not.
http://support.dell.com/support/edocs/systems/ins1545/en/SM/index.htm
I'm not wuite sure what the power socket looks like, but normall it's a center pin dc style socket.
the rest of the solder connections are just anchore pins.
I hope this has helped in some way.
Regards - Anthony
Posted on Feb 01, 2010
Hi my inspiron 1545 boots up and aks for a password. It will not let me go into f12 or f2 settings. when I type in anything at the requesting password screen I do not see anything being typed and then
you need to remove the cover of the laptop locate the password jumper.(near the hard drive, clearly labelled.) take what looks like a little cap off. push the power on button for three seconds. replace cap close laptop, replace cover, and your password will be reset. leave it blank, do not do this with laptop a/c power cord plug into wall socket.
Feb 24, 2014 | Dell Inspiron 1545 Notebook
Zapping sound when I plug laptop into power adapter
Most likely a poor connection of the laptop power socket, it will get worse if it is this,
Could be power supply plug but more likely it is the internal soldering on the laptop pcb
Apr 12, 2012 | Dell Computers & Internet
Hi I have a dell inspiron 1545 laptop and when I use battery power the mouse pad works perfectly , but when I plug in to the mains , it sticks , is eratic and does not work properly please help.
May be your Power cable is faulty.
Tip
1- just use another cable and check .
2- Use another power socket, may be earthing will be issue here
Dec 02, 2011 | Dell Inspiron 15 Laptop
I spilt wine on my dell inspiron 1545. At first it would turn on and tell me there was a problem with the hard drive and suggested reseating it, however this didn't do anything. Now the laptop...
The sockets appear to be shorted. All you can do is to dismantle the laptop again, wash it thoroughly with demineralized water, dry it completely and see if that fixed it. If it hasn't then the motherboard has been damaged and it will have to be replaced.
Jun 15, 2011 | Dell Inspiron 1545 Notebook
Dell Inspiron 1545 - IT won't turn on anymore the AC charger is on and the laptop has no lights signaling its charging. If the power jack is dead how would I be able to fix it?
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Feb 07, 2011 | Dell Inspiron 1545 Notebook
Wireless dirver dell model number pp41L inspiron 1545
you can find all drivers for dell inspiron 1545 here
http://www.general-search.com/download/video-dell-inspiron-1545-model-pp41l-driver-for-xp
Oct 05, 2010 | Computers & Internet
No audio output to tv on my dell 1545
That, & most, earphone sockets, simply doesn't have enough "Current" or signal voltage to drive your TV set's audio in Amplifier. You need to get a Pre-Amp, to amplify the signal, up to a level that can be used by the TV. So you need to purchase, or build from a kit, a small stereo pre-amp and insert it between your laptop & TV audio In.
Feb 04, 2010 | Dell Inspiron 1545 Notebook
When I close my Dell Inspiron 1545 laptop, it always shuts down, even when I set it to sleep mode. This causes Windows to shut down incorrectly among other problems.
Check your computer bios settings. There is a power managment section. Turn off power managment or set it to os controled. Check dells support site for any acpi drivers that you may need. These are needed for suspending controls.
Hope this helps.
Aug 30, 2009 | Dell Inspiron 1545 Notebook
Dell Inspiron 1545 power adapter not charging machine
if it is under warranty please take it to the service center if you try doing anything by yourself that may damage the warranty and it may pinch your pocket,
Aug 08, 2009 | Dell Computers & Internet
Dell Inspiron 1545 Notebook Logo
245 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
