Question about Dryers
Intermittent squeaking noise while dryer is operating. Which rotating part would most likely make the noise?
  • 4,070 Answers
Probably the drum. Could be the bearing the back center of the drum ride on or the gliders the drum rest on while turning.
Posted on Feb 01, 2010
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Mar 16, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
Sears Kenmore Smartheat Elite HE4 Dryer emitting "squealing" sound and drum struggling to rotate when turned on. Operating and drying fine up to this point.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 20, 2011 | Kenmore Elite HE4 Electric Dryer
My dryer is making a loud squeaking noise when i turn it on
I would suspect the belt to be making the noise. If you are handy with a screwdriver, unplug the dryer, take the back panel off and have someone rotate the drum while you listen for the squeak. If it is the belt, get a can of belt dressing from your local auto parts store and lightly spray it on while rotating the drum so you get all parts of the belt.
Mar 29, 2011 | Dryers
There is intermittent squeeking when the dryer is in operation. Is this the drum bearing or the drive belt? How do I access both to check?
heatman101
Nov 08, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My dryer make a loud noise when its rotating
heatman101
jkgjh
Feb 16, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My GE Profile Dryer is still operating but produces loud intermitent noise as the drum rotates. What can I do to eliminate the noise?
It sounds like you may have a bad bearing in the back of the drum. That model rotates on a sort of ball and socket type mechanism. You may be able to lubricate it if the noise is just squealing/squeaking. If it is more than that, you'll probably need to replace the bearing mechanism. If you lube it, use a heavy weight lube that is rated for high heat (I've used brake caliper grease.)
Jan 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
Dryer rotates and drys well, but makes a noise when reversing rotation. Makes more noise at the beginning of use, then subsides. What could be wrong? Belt, bearings? Can I fix or do I need an expert?
heatman101
fsjhgf
Nov 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer will not work1
Squeaking noise often indicates problem with drive belt. If belt broke, drum will no longer rotate. Belt is similar to fan belts used in autos. Ck Sear's website for parts diagram of yr dryer. If it shows a drive belt, I would start there.
Jun 05, 2009 | Kenmore 659 Electric Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Jan 13, 2009 | Dryers
Dryers Logo
111 people viewed this question
Top Dryers Experts
