Question about Gateway FPD1975W 19" LCD Monitor
When I turn my monitor on, the screen comes on for about 2 seconds and goes back off. If I turn it off and back on, it does the same thing again.
I am currently having the same problem.. One trick i found out... and this isnt a solution.. but find something to hold in any of the buttons on the side... I noticed that as long as im holding in ANY of the buttons on the side.. the monitor will stay on
Posted on Feb 27, 2010
  • 11,361 Answers
The problem can be in the power supply due to bad caps, or bad inverter circuits, or worst will be bad lamps. Open it up and look at the power supply first and report back what you see so we can guide you furhter, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 01, 2010
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Aug 14, 2009 | Samsung SyncMaster 920NW Monitor
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
When i boot up my desktop the monitor comes on then goes off, it come back on momentarily when windows starts up and then goes off again. i can turn the monitor power off then on again and it comes on for...
Your backlight might be dead. Try using a flashlight to see if you can see a screen
when it turns black. If you can, its a backlight problem. What model of screen do you have?
Oct 25, 2008 | Computers & Internet
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Dell SP2208WFP Flat Panel Monitor flickers out and goes black.
Hi again,
Any luck with the Dell people?
A favor if I may, at your convenience, would appreciate if you can rate our Live Session as you see it fit.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 05, 2008 | Dell 21" M1110 .22DPI 1600x1200 *SUPER...
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Phillips 170b monitor not working
Exactly the same problem here. Phillips 170B Monitor about two years old. Lights up for no more than 2 seconds then goes blank. Switch on/off and exactly the same thing. I suspect than the screen goes really dim rather than switching off because sometimes I can see the screen image very faintly.
Dec 31, 2007 | Computers & Internet
Gateway FPD1975W 19" LCD Monitor Logo
157 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
