Question about HP OfficeJet 6110 All-In-One InkJet Printer
Sign here tab stuck
I sent some papers through the scanner to be copied and a sign here tab is still in there. Now all my faxes have a line through them. Is there a way to get in there and remove it?
  • 181 Answers
I am assuming that you did this through the auto document feeder at the top? Read this document that tells you how to clean the scanner glass - chances are your little sign here tab will be on that glass as well.
It is for the 6210 and 6310 but your product should be quite similar in nature - http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00671260&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Posted on Feb 28, 2008
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Mar 31, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Fax problem
Something is blocking part of your scanner light, or scanner light may be bad. Check if the scanner light comes on, and check inside the original feeder and machine for a scrap of paper blocking the scanner light to the imaging drum.
Nov 26, 2008 | Brother IntelliFax-2820 Laser Fax
Mfc-7420 ,when sending faxes puts a black line down centre of page
the scanner glass which reads the page is dusty.or any hair like material is stuck on that.just open the scanner and clean the glass.
pls do rate the solution
thanks.
regards.
fixya expert team
Sep 01, 2008 | Brother Office Equipment & Supplies
Stripe on receiving fax Brother MFC 7820N
I had the same problem, and I just fixed it.  It was a tiny little black dot which was stuck to the glass where the document feeder passes the paper to.  First you need to figure out where the line is on paper with respect to the paper, and just carefully run your finger on the glass to see if there is something on the glass.  I removed it, cleaned the glass, and anything which I run through the document feeder is now fine.  Hope this helps.
Aug 15, 2008 | Brother MFC-7820N Printer
Brother 1270
One of 2 things going on here.
If it is in the same spot all the time on sent faxes.
There could be some contaminant on the scanner glass, Some toner, white out or a piece of paper blocking it.
With as wide as it is, that is not likely.
I would think with it being that wide, once section of that scanner CCD assembly has failed. That would need replaced and probably pretty costly.
As was asked above. Does this problem occur in copy mode and does it repeat when you print out a report.
Mar 27, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
HP OfficeJet 6110 All-In-One InkJet Printer Logo
37 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
