Question about Dell Wireless 2350 Router
Unplugged Power and Now Unable to get a connection with router
I unplugged the power of the router by mistake. I shut everything down and started up again and it still doesn't work. A worked with my internet provider and I was able to get a connection from the modem, but not the router by bypassing for now. Do need to fix as my son needs for XBOX LIVE. Any suggestions
  • helplessinnj Feb 19, 2008
    Everything was plugged correctly. Worked OK until I unplugged router while computer was on.
    Problem Solver:
  • 13 Answers
Make sure that the Ethernet Cabel is plugged into the computer and attached to the router. make sure another ethernet cabel is attached from port 1 of the router to the Modem. Hope this works.
Posted on Feb 19, 2008
Router just shut down no lights anything
if you have a OHM meter you can test the power supply it may have short out causing the original problem ounce you pulled the power it was over
Nov 17, 2013 | TENDA W368R Wireless-N Router
Computer read unable to accept wireless connection
You may try to power cycle laptop, modem and router. For router just unplug the power cords of laptop, modem and router. Leave it unplug for 30 secs. Put everything back on and try connecting again.
Hope it works.
Mar 12, 2011 | Computers & Internet
Unable to connect to internet through Linksys WRT160N router. Can unplug it and internet is fine. Tried power cycling the modem and router. Linksys comes up with all lights flashing and will not...
If I understand your problem correctly, you are able to connect to the Internet when you hook the computer directly to the modem, but not when the router is connected to the modem.
If this is the case, then you need to do a power drain on the modem. Power cycling the modem is not enough to clear the NVRAM of the MAC address of your computer. You have to unplug the power cord of the modem for 15 to 20 minutes in order for the NVRAM to reset and allow the modem to recognize the MAC address of the router.
After the modem has been unplugged for 15 to 20 minutes, disconnect the power cable from the router and then connect router to the modem using the Ethernet cable.
Next with the router power cord still disconnected, plug in the power cord of the modem and allow the modem to sync to the network.
Once the modem is finished with its start-up, plug-in the power cord of the router and let it sync to the network.
After the modem has completed its start-up, it should now be connected to the internet.
Good Luck
Dec 30, 2010 | Linksys WRT160N Wireless Router
I plug my router into my modem and it just doesn't want to work with me. Everything was working fine, and then last night my connection gradually got worse until I lost the Internet. I plugged my computer...
There must be a small reset button on your router. Hold it down for 30 seconds. Release it. wait for one minute. Now unplug the power and plug it back in. Wait for 1 minute.
Once you reset the router, it will come back to factory default settings.
You will need to reconfigure the router form the start according to your Internet service provider.
Click here for step by step instructions
Sep 26, 2010 | Linksys Wireless-G WRT54G Router
Upgraded to windows 7 and i am unable to connect to the internet. I get a limited or no connectivity
I'm thinking modem/router combination. first power down modem and router. Then leaving router unplugged, power up modem, make sure it's sync up then power up router. If this is a wireless connection search for your networks name on computer/laptop..ie View wireless connection. Windows allows a automatic setup if the wireless connection is unsecured. If it is secured Windows 7 will prompt a pass phrase/ or access code. Good luck. Repeat process if necessary
Jan 31, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How can i get back on line please
try powering down everything starting with your pc, then the router and modem unplug the router and modem then after its all shut down plug them in in this order, 1st the modem let it boot up wait like a minute then power up the router same thing let it boot and last power up the pc, if this doesnt work try connecting your pc directly to the modem if that works then the problem is in your router if not then the problem is most likely with your ips contact them and ask around if thats the case
Sep 21, 2009 | Computers & Internet
I am unable to access the internet via a wireless connection with my thinkpad.
Shut off your router and unplug the power. Also unplug your cable modem and shut down all your computers. First plug in your cable modem, wait for lights to come back on, plug in your router and then boot your computer.
Aug 16, 2009 | IBM ThinkPad A31 Notebook
Router cannot connect to the internet.
Turn everything off:
Cable modem unplug the power to the modem if it has a battery remove it.
Router unplug the power to the router
Shutdown any and all computers connected to the router
Turn everything on in this order:
Cable modem wait until all the lights are on but the internet act light
Router wait until the lights goes through it's test cycle and the internet light (wan) is on.
Boot up the computers one at a time after the first computer is fully loaded go to the next computer
Hope this helps
Terry
Feb 27, 2009 | Arris Touchstone 450a (CM450) Modem
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Hp2410 unable to operate
Cleaning your appliance may very well take care of your problem. But if not make sure the drivers and the software have been installed. If they appear to be installed then uninstall them and restart your computer and reinstall them. If you have the same problem then take to a qualified service center.
Aug 06, 2007 | HP PSC 2410 All-In-One InkJet Printer
Dell Wireless 2350 Router Logo
Alun Cox
