Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Removal of the agitator for cleaning - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • Whirlpool Master
  • 3,361 Answers
This video will show how to remove the agitator. You probably should replace the agitator dogs while you have it apart.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Posted on Feb 01, 2010
How to clean machine
what are you wanting to clean?? most places are the pump & bowl under the agitator..
the pump is under the machine, some have a little plastic side hatch you open to get to the pump.
the bow is gotten to but removing the agitator, usually a thumb nut down the middle of agitator, and then pull up agitator to remove out the top,
soak up all the water & clean out the dirt & scale you find.
Feb 20, 2014 | Fisher and Paykel Aquasmart wl80t65c
Removing kenmore agitator 417.94862302
You do not have agitator dogs in your machine, yours is made by Frigidaire the agitator can be removed by removing the top of the agitator and remove the bolt. It is screwed directly into the transmission shaft, You want to check the belt to see if it is stretch out , just normal from use.
Feb 06, 2014 | Kenmore 24032\24036 Top Load Washer
Clean under agitator on a Kitchen Aid top loading washing machine.
To remove the agitator to gently remove the cap from the top - it will have a rubber o-ring seal. Beneath it there should be a nut and washer assembly remove that. Then there should be a stack of agitator parts - clutch, upper agitator, lower agitator. Set them aside in the order you remove them. then back in the opposite manner.
Hope this helps.
Joseph
Apr 16, 2011 | Washing Machines
Water is draining very slowly out of the washer and if it takes to long it gives a code of DR
Hi
It seems that something is stuck and you'll have to remove the agitator to clean it. I f this is an old style washer, then it should have a bolt under the cap that must be removed to remove the agitator, then grab hold of the agitator and lift up. If it's a not too old then the agitator just pulls out, remove cap, if no bolt, just grab hold and lift up hard...picture. You can also clean the drain hose as that might be clogged if the agitator is fine. Hope this helps...please post back for further assistance.
Daniel
Jan 10, 2011 | GE Spacemaker WSLP1100D Top Load Washer
I am unable to remove the agitator from my Kelvinator K605 washin
 Before removing the agitator, unplug the washer to avoid an electrical shock hazard.
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
he agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
read more about the agitator removal in the next comment.
Jan 30, 2009 | Washing Machines
I can't get the agitator out.
remove fabric softner cup from top of agitator and remove 1/2 bolt for inside agitator then you'll need spanner wrench to remove nut that hold spin basket in tub. maybe use some affresh tabs or washer magic to remove build up
Dec 13, 2008 | Maytag PAV2300 Top Load Washer
How do you remove the agitator on a Maytag Dependable Care Washer?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
Aug 09, 2008 | Maytag Dependable Clean Top Load Washer,...
Build up of scum on inside of agitator
You should be able to remove the agitator,also try adding or spraying limeaway or clr on it during the rinse cycle
Apr 27, 2008 | Maytag Dependable Care LAT9416
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
132 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
