Question about iRiver E150 (4 GB) MP3 Player
My IRiver E150 4 gb blocked.It's says Generating Database.Plase wait... I wait a lot....wt can i do?
  • blackops_hd
    blackops_hd Mar 07, 2012
    i have the same problem too but i can't connect the iriver to pc what should i do? and i can't turn it off...
  • blackops_hd
Hi, I had the same problem with my Iriver E200. The cause is firmware corruption.
I solved this problem using this method:
1) connect your Iriver device to pc and open the disc of your player;
2) you can see various folders: open the folder named "system";
3) this folder contain a *sys file;
4) open this file using notepad;
5) go to the row "version = ...";
6) you have to modify this row by inserting an older version of firmware. For example if you have "version = 1.11", insert a smaller number, for example 1.07. Save the *.sys file edited. In this way you can force iplus3 to reinstall an uncorrupted version of firmware;
7) now open iplus3, go to Tools -> Portable device -> update firmware. You should be able to reinstall firmware.
Posted on Feb 13, 2010
  • wvrn Aug 26, 2010
    Had the same problems with my E150. The cause was probably an empty file on the internal disk. First, I removed all my music-files from the Music folder. From WindowsXP I was unable to remove the 0-Byte-file out of the Music-Folder, so I renamed it and moved it out (- with Linux you can!)
    After adding the music files once again, the database rebuilds work!
Just uploaded music to e100. its frozen on generating database for 2 hours so far. what to do?
reset it by inserting a pin at the side of the device, in a small hole provided.
Feb 28, 2011 | iRiver E100 Digital Media Player
Just bought an iriver S100 GB mp3 player but computer doesn't recognise it. I've tried using device manager and usb settings but still no joy.
Go to settings, Advanced, Click Rebuild Database. Also make sure you are uploading songs through iRiver Plus 4
Sep 23, 2010 | iRiver X20 MP3 Player
Cannot delete or add music to iriver h10
I had this problem at first too. the only thing you have to do after it's done syncing disconnect it and turn it on. then afterward go through the options till you find database refresh and wait for it to refresh and all your new music should be in it.
Jan 04, 2009 | iRiver H10 MP3 Player
2 GB of music disappeared from Menu but space still taken (Clix2)
hi this happened to me when you go on ur iriver playlist right click on all music and click onto database update then hit start button and all will be found!
Oct 13, 2008 | iRiver clix 2nd generation MP3 Player
Database refresh on Iriver H10
I have done this. my iriver is almost full i have the 20gb, when the you do the database refresh, it just takes a really long time. mine takes about 2 hours to finish, once you see the clock on database refresh you cant do anything but wait till its finished.
Oct 18, 2007 | iRiver H10 MP3 Player
Iriver e10
You need to rebuild the database. You can do that using iriver Plus3 which is out now. I am not sure about Plus2. Look for rebuild database function in your software.
Sep 18, 2007 | iRiver E10 Digital Media Player
Iriver H10 20GB - i can't access my music through Artists or Albums
Have you tired doing a "Database Refresh". It's located on the main screen under "Settings". Go to Database Refresh and check "Yes". How much music you have on your player will determine how long the refresh will take. If that doesn't work possibly run the Firmware Updater from iRivers' web site and only update the database, do not do a complete "Recovery" or all of your music will be erased as that choice reformats your hard drive. Only choose "Update Firmware"
Regards,
John H.
Aug 14, 2007 | iRiver H10 MP3 Player
IRiver keeps loading and loading and ...
Just a thought, try removing the battery, then holding the rest button in for about 15-30 seconds, release it, then re-attach the battery, if that don't work, try removing the battery, then re-attach the battery while holding in the reset button, then release the button after about 15 seconds. Konqueror?, That's a Linux based file manager/internet browser, is it on your PC or the iRiver? If it's on the iRiver, then the operating system is more likely Linux based, and removing the battery then re-attaching the battery while holding down the reset button, should!!! (not everything works as it should) reset the machine.
Jun 18, 2007 | iRiver H340 MP3 Player
iRiver E150 (4 GB) MP3 Player Logo
694 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
