Question about LG DLG3788W Gas Dryer
Can't get heat from our gas dryer. LG dlg3788w
Had sam problem with very little heat. It was because the vent was full of lint and restricted out put. pull off the duct and make sure it is clear and the outside vent door opens to allow flow.
Posted on Apr 13, 2011
My model number is lgr4634eq1. my gas dryer just spins but does not heat. The dryer came w/the house 3/13/98..
Posted on Feb 01, 2010
Testimonial: "the answer to all of life's problems, clearly!"
  • 489 Answers
SOURCE: Gas dryer LG DLG3788W
Take a 2 inch putty knife and slide in the separation gap just above the door.  There are 2 catches on each of the panel about 3 inches from each side.  Push in to release the catch and the top panel will pop open.
Posted on Jun 11, 2008
SOURCE: conversion back to natural gas
4948EL4001B back to natural part number LG will only sell it qualified techs..but here's a start.
Posted on Jul 09, 2008
  • 410 Answers
SOURCE: LG Gas Dryer #DLG3788W will not heat. Checked the
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 05, 2009
  • 180 Answers
SOURCE: We have a LG TROMM Gas Dryer #DLG3788W. It will
The igniter or the gas valve. Both are on the bottom right in front of the machie. You will need to remove the lid and front panel to get to them. To test them take the door switch out of the door, plug it back in, and have someone hold it while you watch the igniter. It should glow almost white. If it does not check to see if it is getting power, If it is not getting power your might have an issue with the control board. If it is getting power replace it.
SOURCE: my lg tromm DLG3788W gas dryer is not heating, it
I just cleaned those sensors at the bottom of the filter, it worked like a charm. The dryer is now drying perfectly, I did not know you were not supposed to use fabric sheets with this dryer. Now I know, Thank you for the good information.
Posted on Dec 20, 2009
It takes way to long to dry close, no it takes up to 5 hours to dry
if u look where the heat tube is there is thermostats one or more is burnt out
Dec 08, 2013 | LG DLG3788W Gas Dryer
LG Tromm dryer dryer number DLG3788W is not heating. it spins and works perfectly accept it stopped heating yesterday. I took off the vent hose yesterday and cleaned out all the lint there, it wasnt too...
Either there is a fault in the power supply to the heating coils, or the heating coils have burned out. A multimeter will come in handy at this point to check continuity across the terminals to the heating coils, and to test current supply to the coils. Be very very careful since you are dealing with 220 volts. If you do not feel comfortable doing it yourself, call an appliance repairman.
Oct 02, 2013 | LG DLG3788W Gas Dryer
Not getting heat from dryer
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 08, 2011 | LG DLG3788W Gas Dryer
My dryer stopped heating
heatman101
Nov 13, 2010 | LG DLG3788W Gas Dryer
Gas dryer noot heating up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 24, 2010 | LG DLG3788W Gas Dryer
My dlg3788w dryer is not heating, what do think the problem is?
heatman101
May 29, 2010 | LG DLG3788W Gas Dryer
Lg dryer wont heat up DLEX7177RM how do I reset the thermostat
heatman101
Apr 30, 2010 | LG DLG3788W Gas Dryer
No heat after drying several loads
the vent in your house may be stop up in the wall.
Jun 15, 2009 | LG DLG3788W Gas Dryer
Conversion back to natural gas
Jul 09, 2008 | LG DLG3788W Gas Dryer
LG DLG3788W Gas Dryer Logo
808 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
