Question about Kenmore Elite 45986 Front Load Washer
My washer is showing error f20 what does it mean
I have a kenmore front load washer and dryer. my washer is showing error f20 what does it mean
  • 5,911 Answers
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. The following link explains how to troubleshoot:
http://www.fixya.com/support/r3608632-f20_error_code
This is one of those error codes that can be tricky to troublehsoot due to the many potential causes of the problem. My adivce to you is to eliminate the easy common sense items first.
Read through the information provided and let me know if you have any further questions. I hope this can help you.
Posted on Feb 02, 2010
    President:
  • 842 Answers
Pretty sure that F20 is a pump or drain error. Take a look at my article http://www.fixya.com/support/t3144835-not_draining_water_not_spinning This may help
F20 error code
Hi.
F20 means that there is a water inlet problem:
Reasons for error F20:
(Water Inlet Problem-no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
If that does not help inlet valve, pressure switch and control module must be tested. The defective part must be replaced.
Here the tech sheet.
Regards.
Ginko
Aug 20, 2011 | Kenmore HE2 Plus Front Load Washer
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore front load washer keeps showing a F--20 error code and then stops in the middle of the rinse cycle
Hi
The F20 error on this machine indicates that there is no or very little water coming into the machine. This means that the pressure switch is not being activated after a while and the error is then thrown up.
See this excellent FixYa link for a complete breakdown of the problem and how to troubleshoot and then solve it.
Acknowledgement jsrock516 for this excellent breakdown of the problem
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
Please do rate my answer. Many Thanks.
Aug 27, 2009 | Kenmore HE2 Plus Front Load Washer
Front load kenmore washer giving error f20 messsage.
take the kick panel off and find the tech sheet. i believe you have3 either a bad pressure switch or something stuck in your pump. let me know how it goes
Apr 04, 2009 | Kenmore HE2 Plus Front Load Washer
F20 error on Kenmore HE2 front load for no reason
under top cover does it have flow meter? ck connection and resistence with ohmmeter, ck pressure sw.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Have kenmore elite HE5t giving code F20 help pls
The following link explains the "F20" error code:
I recommend checking your washer installation for a possible siphoning condition and kinked fill hoses, first, as these are the easiest items to rule out.
If you have questions, please let me know. I hope this helps you.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
F20 code.
in my fixing f 20 needs a new cpu main board in the top washer middle back side
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
2006 kenmore smartwash quietpak4 he3t F20 code washer
F20 ERROR CODE ON A KENMORE HE2T FRONT LOAD WASHER.THE FIX FOR ME WAS TO REPLACE THE TUBE THAT RUNS FROM THE PRESSURE SWITCH TO THE BOTTOM OF THE WASHER.YOU MUST REMOVE THE TOP AND BACK COVERS OF THE MACHINE(EASY).REPLACED TUBE WITH3/16 INCH CLEAR TUBE.THE ORINGINAL TUBE HAD A PIN HOLE FROM RUBBING AGINST THE SIDE OF THE MACHINE AFTER 5 YEARS OF USE.THIS COST UNDER $10 DOLLARS TO FIX. NO SERVICE GUY=MORE BEER MONEY GOOD LUCK.
Nov 07, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
723 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
