Question about Polaroid FLM-3232 Television
TV doesn't turn on
When I plug the TV in and push the on button, nothing happens. It just stopped working. I opened it up and put a voltmeter to the connections where the transformers supply DC to the PCB. There was no voltage but the transformers were supplying around 80 Volts DC. What do you think is busted on the power regulation board?
  • 1 more comment
  • motorcitykid
    motorcitykid Feb 20, 2008
    SAme problem will not turn on. When turn it on the red led light blinks one time and thats it. Checked fuse. I can get the backilght to come on if i unplug and replug in different wiring harnesses from board to board. But no picture appears when i get the lights on and also when i get the backlight to stay on the tv will not do anything at that point. The red led stays solid red during this period of time and power button will not work, and i have to unplug power cord to make it go off. Then have to plug it back in and mess with those harnesses to get lights to come back on. I dont know. I hate polaroid.....
  • warper2001 Mar 09, 2008
    only half of the board has power and the heat sinks have 80V across them as well. Its like half of the boards heatsinks are 0V and the half thats near the ac to dc rectifiers have 80V. It even tells me that the big 150uF @ 450V cap is connected to the heat sinks. but I can't find were they bridge. Is there an easy systematic method to solve the problem or am I just totally off?
  • BudP Mar 18, 2008
    was working fine one day then decided to use it with my computer cause it has all the hook ups worked great for two days then just would not come back on no lights for the on off button ,i hear it start up but nothing comes on..
    Sergeant:
    Champion:
  • 362 Answers
First warper2001 your power supply is probanly bad the voltage checks was you getting 80 volts on the output side of the transformers each one should be labeled as to the output voltage, at least one of them should only supply 24 volts, the transformer went bad probably overheated and melted the protective coating in the trans and let the voltage increase. could have burned out lots of things. unplug it, use a screw driver and short across the plug ins and the ground on the cord to drain the capicitors in the unit. the ohms check the components through each and to ground. check for opens and shorts. when checking a board remember that you will get a little bled back because you cannot isolate the parts. so most of you ohms readings should be large amounts of resistance if not you have a problem with that component, wire coils excluded. ie transformers they are best voltage checked. hello motorcity kid. i sent you a buddy message but also remember these items of advice.
Posted on Feb 25, 2008
I have a 24 inch sanyo flat screen tv it is stuck on video and when I try to change the channel nothing happens I do not have the remote controller for this tv or any universal controller in general w
tried with unplugging and re plugging the tv doesn't work?. if not, tried to push any button like the channel up/down button and tv/video button at the front panel.
Oct 15, 2012 | Computers & Internet
Coffee maker turns on but will not brew
why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
My Dell D600 laptop stopped working today. Coincidentally, I had just turned it off to try running a test on the RAM because the PC had been slow and locking up for the past month or so. Anyway, when I...
try this:
1- deattach the RAM , run the laptop without (RAM) you must hear som beeps
2- put the ram back again in the same slot
if it doesn't work try other slot
Feb 07, 2012 | Dell Computers & Internet
Dryer won't turn on...
Try pushing the breaker pair off, then on and re-check the dryer. If still nothing, pull the power plug and check the two slanted slots for ~220 volts AC. If you don't have access to a voltmeter, or a friend with one, call an electrician to check. If you read the voltage stated, then the problem is within the dryer. Check the back of the machine for a reset button.
Sep 14, 2009 | Dryers
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
TV won't turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 25, 2008 | Mitsubishi WS-65511 65" Rear Projection...
TV won't turn on
I am having problems turning on the tv. I had lost the remote control so I bought a universal remote which was not working at the time I unpluged the tv form the powersocket then I tryed to turn on the tv the green power light stays on for a few seconds then it blinks two times then there isn't a power light on after that what is wrong
Jul 26, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Polaroid FLM-3232 Television Logo
108 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
