Question about Yaesu Radio Communications
Power button on FT 50R hard to get radio to go on but goes off ok
  • 518 Answers
SOURCE: Yaesu FT-50R battery drain
I have the same radio.
Does the radio work? Could it be the battery that's getting hot?
Geno
N8BHG
Posted on Feb 20, 2008
SOURCE: Yaesu Ft-50 hard to turn on
The rubber power button is impregnated with carbon and when pressed, it makes contact with two points on the printed circuit board, turning on the radio. This button eventually wears out and needs to be replaced, which is a rather easy process.
I've performed the operation four times - takes about 15 minutes. The button is available from Yaesu.
I also tried "repair kits" for these buttons which are supposed to replace the conductive surface. Both times, they failed again within a couple of weeks.
The upside is the new button is not as quite as tall as the original and requires depressing it below the surface of the case to switch, which prevents accidently turning off the radio.
Good luck, and 73
DE NøAWN
Posted on Apr 07, 2009
  • 25 Answers
SOURCE: My Yaseu FT-50R doesn't stay on. I have to remove
Darned resistive silicone contacts! This link will help you:http://www.sdarc.net/forum/printer_friendly_posts.asp?TID=828 There are kits available that "rebuild" the carbon conductive layer, should cleaning not help. It's like (car) rear defogger repair kit material. I haven't had long term success with the two part repair kits, myself. I didn't read the link myself, but cleaning with alcohol often works. If not, try acetone. If that doesn't work, a conductive kit or sticky aluminum tape may help. If cleaning doesn't work, and replacement is available from Yaesu, order it! Darned these silicone contact pads! Same pads as most remote controls.
Posted on Jul 16, 2009
SOURCE: i need a memory battery for a ft 50r
I just had my FT-50R repaired due to a overheat issue with a reverse polarity diode. When I asked Yaesu to alao check my Yaesu for the memory battery I was told by their top technican that the radio does not have a memory battery in it. I hope this helps.
Posted on Aug 24, 2009
  • 4 Answers
SOURCE: Yaesu ft-50r HT getting very hot and not charging battery
From the description your battery has one or more shorted cells. Replace the battery.
Posted on Mar 17, 2010
I need to know A M power high and low AM mod and ssb power on RCI 69ffb4
you need to buy a dummy 50R load and a watt meter
and a patch cable to plug them in
they you can know whats coming out!
Nov 29, 2014 | Radio Communications
Mar 15, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Jul 16, 2009 | Yaesu NABC NABC LMR NICD BATTERY FNB-V47...
I need a memory battery for a ft 50r both sides are sorderd the main board
Apr 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Good luck, and 73
DE NøAWN
Mar 17, 2009 | Yaesu NABC NABC LMR NICD BATTERY FNB-V47...
Steam generator will not activate- thermasol model ASD300A
how do you know the unit has power?
what control do you have?
does it light up.
Mar 15, 2009 | Thermasol Steamshower Generator AF Series...
Yaesu ft 50r
The FT-50R is an extended receive, but dual band (UHF & VHF) amateur transceiver. It is capable of transmitting between approximately 144Mhz - 148Mhz VHF and 430Mhz - 450Mhz UHF.
Typically, the radio will provide an audible warning whenever attempting to operate outside of its intended range(s). The manual has a section on maximizing battery life, and can be downloaded below:
http://www.radioamateur.eu/schemi/FT50_user.pdf
May 25, 2008 | Yaesu NABC NABC LMR NICD BATTERY FNB-V47...
scotwho, I personally do not know the radio you are asking about, but I do have many years working with radios in troubleshooting. What I am guessing is, if the heatsink gets hot, then whatever is connected to the heatsink has shorted out. Two main parts come to mind here, and that's the audio chip, and the transmitter output final/chip. Possibly the main IC (brain) that controls most everything, but I doubt that. The radio needs to go to a repair shop that can troubleshoot the damage/ and find an answer as to why it occurred. A lot of times the factory's do not use heatsink compound when they assemble the units, and after an x amount of time the part/parts will fail. 10cents worth of heatsink compound can make a radio last a few years longer.
Probably not the answer you wanted but I hope this helps,, let us know. Mechanic
Feb 19, 2008 | Radio Communications
Radio Communications Logo
201 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
