Question about Toshiba Satellite P200-0TD00Y Notebook
I have a Toshiba P2oo Backlight goes out
I have a Toshiba P2oo Satellite When I open the lid more than 60 degrees approx the backlight goes out. Can you offer any advice
  • 62 Answers
The wire that connects the lid with the motherboard might be damaged, but not completely damaged as you use your screen normally, so i recommend that you check this connection.
Posted on Feb 01, 2010
Toshiba satellite P305D-S8818 location of lid switch
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 20, 2012 | Toshiba Satellite P305D-S8818...
Toshiba satellite backlight
Mohammad,
Toshiba Satellite P100 screen Inverter replacement;
1) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
(You can click on any photo to enlarge it. At the top, and bottom of the page are the page numbers. They are in white; Page1 :: Page2 :: Find another model )
2) Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight (Present technology) is a CCFL, or a series of LED lights.
The Toshiba Satellite P100 series of Notebook PC's uses a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average size is approximately 2mm Thick, and the length is close to the height of the LCD screen. 2mm is a little larger than 1/16th of an inch.
This means the CCFL can be broken quite easily, as it is fragile. (You also DO NOT want to be cut by a Fluorescent lamp )
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A screen Inverter converts the power from the laptop, for the Backlight, and LCD screen.
As previously stated in a Clarification, 90 PERCENT OF THE TIME the fault is the screen Inverter.
Regards,
joecoolvette
(I never request commendations, but thank you for offering.
We, the older techs here, feel that is begging.
3 years at FixYa so far.
Regards,
joecoolvette)
Mar 23, 2012 | Toshiba Satellite P100 Notebook
I've a Toshiba Satellite A200. The display works fine providiing I don't open it more than 45 degrees. When fully open the display goes dark although the correct image is still there in...
The fault is a back light problem, it could be the power connection to the inverter, because you can see a dim video image.
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 30, 2011 | Toshiba Satellite A135-S2276 Notebook
Dim backlight
you need to contact the manufacturer and ask to replace the backlight...
May 20, 2010 | Toshiba Satellite 15" Flat Panel LCD...
Screen keeps going black. Will come on after
It sounds like a problem with the backlight, but could be a cabling problem as well, or a voltage problem (least likely).
May 05, 2010 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite p205-s6267 backlight
Your system is consuming much power.
Go to Control Panel, Power Options.
Click "Advanced Power Settings" for your current power plan.
Under the section "What happens when I close the lid", choose "Do nothing" for both "Battery" and "Plugged-in".
Click "Apply" and "Ok".
Now, close the lid of your laptop and open it, it would restore but next time don't overload your system power.
This is common with Dell and Toshiba.
Apr 03, 2010 | Toshiba Satellite P205-S7402 Notebook
Toshiba A105 - S4334 laptop,imediately on startup the screen goes so dark I can't see anything but a shadow of the screen,if I clsoe lid and open again I can see the display but only for a few seconds.Is...
Hello wall flower hi, when you turn on the laptop, did you see the start up screen clearly? can you read words on the screen, and then it goes dark? If this is the case, check first the Fn key with the corresponding display for projector, (usually Fn+F5) this combination key is used to display the content of your computer to the LCD or Projector, IF not such a case, it may be problems with your laptop inverter board that powers the backlight. Check your bios settings also.
Feb 12, 2010 | Toshiba Satellite A105-S4334 Notebook
Replacing CCFL Tube
I've repaired 1000+ Toshiba and replacing the FL tube is something I would never attempt to do because of how hard they make it to do. Generally there is a FL Inverter below the LCD that goes bad which causes the backlight not to light up correctly. The actual FL tube rarely breaks and unless you know you dropped the laptop it probably isn't what is wrong. 95% of the time when the backlight isn't lit up it is the FL inverter board.
Nov 13, 2009 | Toshiba Satellite A135 Notebook
Toshiba Satellite A105 lcd display
keep typing the combination of "Fn" and "F7" on the keypad .
note: you can find "Fn" on the lower left of the keyboard and "F7" on the topmost right of the keyboard...
Please let me know the results...
Thanks
Jan 09, 2008 | Toshiba Satellite A105 Notebook
Open Questions:
Toshiba Satellite P200-0TD00Y Notebook Logo
229 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
