Question about Delta Martine Crib
One of the springs/clips that lets the front of the crib go up and down is broken. where do I get a replacement
  • 3 Answers
Go to productamerica.com and get the 800 number and call them with your model number. Explain what part you need and they will know right away if it is a part they carry.
Posted on Feb 03, 2010
Ge washer wjrr4170g agitating very hard and rough and out of balance but is level on the floor. What is possibly wrong?
Hello Trina;
My name is Peter. I am a retired field service appliance technician.
Go into Searspartsdirect.com. In put your model number. Ther will be a diagram showing your rod springs. I suspect you have a bad rod spring or it has come loose. The rod spring stabilizes the washer drum during agitation and spin cycle. These are relatively inexpensive parts approximately $16.00 each.
Lets repair this together. I have faith in you Trina. No man required.
Unplug or turn the circuit breaker off.
To replace this part you need to open the top cover. There are two retaining clips, one on the right and one on the left. If you look into where the top cover meets the front plate you will see these clips. With a putty knife or a spatula push on these clips to release the top cover. Raise the cover up.
Now, you need to remove the front cover. First disconnect the electrical connector to the door latch. Using a small screw driver wedge between the connector for release.
You will see screw on the inside at the top of the front cover. One on each side. They are either Phillips head screws of hex head screws. Remove these fasteners. Lift up on the front cover. There are tabs that go into slots. You may have to play with the position of tabs and slot to remove. You will now have access to the rod springs.
If the rod springs are loose tighten the threaded fasteners. If they are broken replace. You probably have only one broken. Keep running the dishwasher then you will have both broken.
Peter, Baltimore, MD
Nov 09, 2014 | Washing Machines
One of the clips that hold the side of the cot up is broken where can i get one
mcdevito75 here, Best Bet, contact the maker of the crib online, In search type in the makers name plus.com for this part. Or at any store selling cribs, check for replacement parts. Better yet check with a large hardware store, bring the old clip with you for match up.
Jul 16, 2010 | Mamas and Papas Jasmine Crib
Side keeps falling down
check the hardware on the sides clip may be broken or missing also check to see if ur crib is made by stork craft there is a massive recall or cribs that the sides go down on call 877-274-0277 ur crib might be involved in the recall or u can log on to http://www.storkcraft.com
Nov 24, 2009 | Childesigns Savannah Crib
Fixig my cot
my son cot is broken on the side that slide up and down one of the clips broken off<!-- from fixya rte -->
Jun 14, 2009 | Dreamtime Milano Crib
How do you open the dryer to fix the belt
First before you you raise the top, open the cover on the back by the motor and let the belt loose from the motor pulley unless the belt has broken. If it has go to the lid. Slide a thin flat blade under the front of the lid and feel for the two clips several inches in from the corners. Push straight in on a clip while pulling up on the lid at the front edge and it will release the lid at that point. Do the other clip. Lift the lid. Three are usually two screws, one on each side holding the front tight. With the screws removed, pry out by each of the push clips on the side. The front should be come loose. Swing it away slightly paying attention to the wires to the door switch. Slide the new belt over the drum and work it to where it ran in the past. Put the front back on and snap the lid down. When putting the front on guide the front panel and the drum together at the felt seal. Open the panel on the back near the motor. Reach in and spring the belt tightener over and put the belt around the motor pulley. Let the spring tightener tighten the belt. Put the cover back on.
Jun 06, 2009 | Maytag MDG6000 Dryer
The 4 plastic brackets that adjust the bed spring up or down have broken, can these be replaced and where do i find the replacement parts. thanks for any help
You can email them - they emailed me the instructions and parts list in a 16 page pdf.
customerservice@sjfdec.com
Here are the instructions for your crib. Please review them and see which parts you will need. We accept Visa or Master Card. Parts are non returnable. Delivery is normally 7-10 business days. We do have replacement parts for this crib. Please review the instructions and see what you will need. J Thank you, CindyCustomer Service RepSimmons Juvenile Furniture':Phone: 1-800-218-2741 ':Phone: 1-920-779-40047:Fax: 1-920-779-4216
May 23, 2009 | Simmons Mattress Matino - Natural Maple...
Rods to let rails up and down and l-shaped bracket to hold spring
You can contact the company directly for replacement parts. Here is the number and times of service.
1-800-889-8158
M-F 9-5 EST
Apr 12, 2009 | Angel Line Jenny Lind Crib
Replacement parts for Simmons crib
Find cheapest simmons crib replacement parts here (great quality too) here by using this wholesale tool Find the low cost Wholesalers Dropshippers. Best of luck
Jan 24, 2009 | Baby Gear
Pottery Barn Kids Sleigh Crib broken clip on side rail
We had the same thing happen and Pottery Barn was terrible at helping us remedy the problem. However, after much research, we found the solution! There is a company called Products America (www.productsamerica.com) that sells replacement kits for the PBK cribs. Ours was the antique white sleigh crib...all parts matched perfectly and were identical to the originals! Good luck!
Dec 04, 2008 | Pottery Barn Kids Espresso Sleigh
Missing pieces
This is from Bassett's website.
Bassett recommends that all cribs manufactured prior to 1972 be replaced because improved safety features were instituted that year. If your crib was made in 1972 or after, replacement parts are available from Products America at 1-800-772-1041. If you are unsure when your Bassett crib was made, Bassett urges you to replace it.
Link to Products America
Jan 21, 2008 | Bassett Parson Ridge Crib
Delta Martine Crib Logo
56 people viewed this question
Top Delta Baby Gear Experts
paulcarew
William McDowell
Are you a Delta Baby Gear Expert? Answer questions, earn points and help others
