Question about Acer Aspire One PC Notebook
I cant see some text on my acer aspire one when looking at the screen normally, but if i look at it from an angle i can see it . What is wrong ?
  • 152 Answers
Display driver incompitible download it from acer website
Posted on Feb 01, 2010
How do I adjust contrast?
There are Function Keys to do this.
from Troubleshooting section. Keyboard (if contrast and brightness function key)
http://tim.id.au/laptops/acer/aspire%203680%205570%205580.pdf
and Page 10 of the manual
Display Keep your display clean. • Keep your head at a higher level than the top edge of the display so your • eyes point downward when looking at the middle of the display. Adjust the display brightness and/or contrast to a comfortable level for • enhanced text readability and graphics clarity. Eliminate glare and reflections by: • placing your display in such a way that the side faces the window or • any light source minimizing room light by using drapes, shades or blinds • using a task light • changing the display's viewing angle • using a glare-reduction filter • using a display visor, such as a piece of cardboard extended from the • display's top front edge Avoid adjusting your display to an awkward viewing angle. • Avoid looking at bright light sources, such as open windows, for extended • periods of time.
http://www.manualslib.com/manual/205261/Acer-Aspire-3680.html?page=10&term=contrast
Dec 27, 2015 | Acer Aspire 3680 Laptop
I appear to have either a hardware or software problem and the i get an set of options witch are start normally, safe mode and safe mode w/ networking. but when i select one it appears to start up normally...
Check your memory. If you have a faulty or substandard RAM chip, this is a likely cause. Also there may be an error on the hard drive hence Safe Mode. Run CHKDSK/F as soon as you get it to boot and save all of your data!!!!
Dec 23, 2010 | Acer Aspire One Netbook 8.9" Notebook
I appear to have either a hardware or software problem and the i get an set of options witch are start normally, safe mode and safe modw / w networking. but when i select one it appears to start up...
I open my laptop up and all that appears is the desktop background...nothing else. How do I get it going?
Force a restart... Unplug any power and pop the battery out. Give it a minute, then pop battey back in, and power wire if needed.. Press power on buttn. Should start up. It may give a black text screen with start up options saying shut down wrong.. Just use Normal Start up.
Dec 09, 2010 | Acer Aspire Notebook PC
I have a black screen on an acer aspire laptop it starts up but screen is black starts fully if i look at an angle i can see the screen but its hard to make out
If you shine a flashlight at it and look it from an angle and can see your screen then the inverter board is bad and it needs to be replaced.
You can hook up an external monitor to your laptop in the meantime to use your system.
Oct 18, 2010 | Acer Aspire 5500 5570-2609 Laptop
Screen is blank? can you check this computeR? exentsa acer model #jalao
If your system seems to be going through its normal boot routine, look at the screen from several different angles. If you see 'ghosting' then it is likely the display backlight or the inverter for it that has failed. If you have, or can borrow, a standalone monitor, plug it into the VGA port of your notebook. If you still see nothing, it may be only that the external port must be turned on in your CMOS setup but the external monitor should at least show text during the boot routine.
Apr 17, 2010 | Acer Extensa 4620 Notebook
Text has changed
Try opening the Control Panel and double click on Fonts (it's the tenth icon from the top). You may also try to open add0remove programs and see if you accidentally installed some type of Font Program in another language. If you did, try to uninstall it as well. GOOD LUCK!!
Mar 26, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5570 black screen.
This problem occurs in most Acer laptops. Its actually a bug in the mother board. Try reinstalling the clock battery or give it to your nearest service center.
Jun 26, 2009 | Acer Aspire 5500 5570-2609 Laptop
Rotation of screen acer Aspire 5100
First go to your graphics properties and make sure that screen rotation is enabled. then press ctrl+alt+(arrow key) and it will turn that direction.
Jan 17, 2009 | Acer Aspire 5100 Notebook
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
