Question about Samsung LNT3242H Television
Channel scanning My tv appears to be possessed! It is scanning channels like its doing some sort of auto programming, only I didn't push anything! I can be sitting there watching tv and then suddenly it starts scanning through channels. I am unable to push any menus, I can't do anything to stop it regardless of what I push. I can't even shut it off when it does this unless I unplug it because even the power button doesn't work. I left it off overnight and it appeared normal today after work, then suddenly it started all over again? Should I take it back where I got it from? It's been 6 weeks since I bought it. Tanya
    Genius:
  • 1,554 Answers
Yes file for repair as everything you would have to do to fix this means opening it. and likely voiding the warranty.
Posted on Feb 19, 2008
I want to hook up my old 1992 Sylvania TV to HD Antenna, but I cannot figure out how to scan or auto-program the channels. Model SRC1351 101
Hello... Somewhere in the same menu as the Air/Cable setting should be an option to scan for channels. It might be called Auto-Program, or something similar. The bad news is that: "On June 12, 2009, the Federal Communications Commission (FCC) mandated that all U.S. based television signals must be transmitted digitally." Since your TV was manufactured in 1992, it isn't capable of detecting or displaying digital channels. If you're really fond of the TV, you will need some sort of conversion box. If you can afford to, I'd recommend buying a new TV, and get the extended warranty. I hope this helps!
Nov 26, 2017 | Sylvania Televison & Video
I have a 32inch Olivia tv model 432S12 I can not get the tv to auto scan channels. How do I get to reset my channels or reset factory settings.
1st unplug your TV.After 5 minutes turn it on and see if it prompts you to set up the TV with a setup wizard of some sort. This will probably include an auto scan of channels. If that doesn't work explore all options in the menu to see if there is a reset of some sort. And if all else fails, read the users manual.
Jul 01, 2015 | Televison & Video
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
Hello
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
Jun 17, 2011 | Zenith H27E35DT 27" TV
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Programming channels
The only thing I see in the Manual is to do an auto search which will scan all available channels and saves them to memory. the faxtory setting is auto search. the search allows you to manually search for available channels. in this mode, available channel must be stored individually. the program sets your favorite channel to appear when the tv is turned on. the range is from channel 0 - 255. i hope this helps.
Sep 15, 2009 | Trinity CT-V710 7 in. Portable TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
CCVG297 broksonic 9" TV
When the channels show up in red thats an indication that they are not programmed into the TV set. Your going to need the original remote, go into the menu and then press auto scan with an attenna attached to the set. If it wont scan then you have a bad microprocessor
Sep 25, 2006 | Broksonic CCVG297 9 in. TV/DVD Combo
Televison & Video Logo
154 people viewed this question
Jerry Greenberg
Jerry Greenberg
