Question about Palm TX Handheld
I can not hot sync my palm TX with my computer. I have had 4 other palm types od pilots and this is our new one. When I tap on the Hot Sync logo it resets to the Palm logo and goes back to the time setup page. Help Thank you Jack
  • jackershaw Feb 01, 2010
    i TRIED TO REINSTALL THE TX PROGRAM, AT ABOUT 90% DONE (i THINK) A MESSAGE CAME UP AS FOLLOWS.
    "ERROR 1714 THE OLDER VERSION OF PALM CAN NOT BE REMOVED. CONTACT YOUR TECT. SUPPORT TEAM".
    BEFORE THE WIZARD CLOSED ANOTHER MESSAGE SAID "THE WIZARD WAS INTERUPPED BEFORE PALM COULD COMPLETELY INSTALLED YOUR SYSTEM HAS NOT BEEN MOTIFIED . TO INSTALL PLEASE RUN AT A LATER DATE.".
    JACK
  • 2,418 Answers
This is an indication that the Palm Date book is corrupt. When the Palm goes back to the time set up screen it has reset or has sensed a short in the cable. Do the standard stuff, remove the battery, after you reinstall the battery, turn on the Palm and reset the time and match the time to the computers time, this is a time date issue with the palm Date book. You may have to Download add. software from the Palm site to resolve this issue.
Posted on Feb 02, 2010
  • 2 more comments
  • John Fourteen Six Feb 02, 2010
    Have you rebooted your computer and retried to reinstall the software? If you have an anti virus program running stop it if you can - also press control, alt, delete, and check for any apple software that may be running as that may cause a problem.
    If you have the choice, leave any older Palm software on the computer.
    Last Have you tried to do a hard reset?
    Press and hold the Power button.
    While holding the Power button, use the tip of the stylus (or a paper clip)
    to gently press and release the RESET button inside the hole on the back of your Palm.
    The RESET button may be somewhere else on the back of your particular device.
    First you'll see a palmOne or Palm logo and a progress bar. Keep holding Power.
    Then you'll see a grey circular Palm Powered logo. Now you can release Power.
    When the warning appears, press Up to confirm the hard reset.
    If a language selection screen appears, select the same language you selected for your desktop software. Try this if this does not work for you reject my answer and repost. Thats all I have.
  • John Fourteen Six Feb 09, 2010
    Hello jackershaw have you resolved your problem with your Palm TX?
  • 3,230 Answers
Well first of all you can try to uninstall the software of your palm and then reboot your system after that just install the palm software again.... you can please check the below manufacture website for more information and for software -
http://kb.palm.com/wps/portal/kb/common/article/26457_en.html
Please post comments if further you have the same problem.....
Good Luck!!
Thanks
Posted on Feb 01, 2010
By typing hot Sync my palm makes a restart
Try this, uninstall your current version of Palm Desktop, then go to this link on the Palm support website http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/home/page_en.html this will give you the link to the download for the TX version of Palm Desktop, this may or may not fix your particular problem but it is worth a try.
Mar 24, 2009 | Palm TX Handheld
Can not get fi fi on my tx even though I have been getting it for a year
what is the problem you are facing
pelas explain it clearly
Sep 16, 2008 | Computers & Internet
I broke my old Palm TX. Now I have another one
Great!
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 14, 2009 | Palm TX Handheld
My TX crashes every time I try to hot sync
You could delete that app if you want, however I would go into hotsync config and sync only one section at a time, such as Notes, but not contacts or calendar (or anything else). If it works then add a section, such as contacts. Keep adding sections until it malfunctions. Pimlico software makes a product dbfixit ($) that can fix database (blob errors). You can download and install it, and it will report on (but not fix) any errors it finds.
Feb 04, 2009 | Palm TX Handheld
Palm Pilot: Connection for Hot Sync
Has synch worked before on this set up?
Jan 01, 2009 | Palm Z22 Handheld
Palm TX travel charger problem
It is an issue with the slot on the device, however you can charge the device using the Sync cable, it is the safest way to charge the device.
Dec 01, 2008 | Palm TX Handheld
HotSync error ((sys 0505) (0,841)
I also had this problem. Searched for a solution and found that the error message refers to older programs incompatible with newer models of the palm. If you do a Hot Sync on a different and/or newer model palm device there may be these incompatibilities. The usual problem programs are mypalm and mytreo. You need to delete them by
first doing a Hot Sync
going to Applications on the palm
tap on the menu icon (or the left upper corner of the display)
tap on Delete
go down the list to delete each of these programs.
Hot Sync problems should stop
If not, you need to do a hard reset and then slowly add third-party software one by one and look for problems.
Jun 23, 2008 | Palm TX Handheld
Hot sync
Try reinstalling the Palm software from the CD into your computer. You should unistall it first and reinstall it.
Is this on a Windows Vista computer by any chance?
May 03, 2008 | Palm TX Handheld
Palm tx
Is this on Windows Vista computer?
Apr 20, 2008 | Palm TX Handheld
Palm T/X won't hot sync on Window XP Media Center Edition
i had that problem too. sorry it is bugging you.
i know you probably want to sync your data rught now. So for now try to disable the syncing of documents to go (just for now)
on palm desktop, look for the conduits and temporarily disable the syncing of docs to go. Also ensure you plug in your pda charger as well as the usb cable (I found out this helps through experience) and sync. (Just to back it up)
as for the documents to go, there is probably a file(document) that is generating the errors. please look through documents to go on your palm desktop and remove any file you feel is not necessary. also take note that it is best if your pda has some free memory on it. you may want to save those documents on a disk (If you are not already that is..) clearing up ram made my tx more stable esp during hot sync.
please let me know it that worked for you. i still have some suggestions
good luck and enjoy
Nov 05, 2007 | Palm TX Handheld
Palm TX Handheld Logo
57 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
