Question about Philips 42PF7220A 42 in. Plasma Television
Philips 42 Hey, My tv has a 5" vertical line about 5" in on my tv. What could be the problem? Thanks
  • clackmaster Feb 19, 2008
    Well i would think that but it is going from top to bottom. Any other thoughts?
  • archie101 Mar 08, 2008
    I HAVE THE SAME PROBLEM WITH THIS SAME MODEL TV.
    Brigadier General:
  • 6,966 Answers
Initially if it is near the bottom, I would suspect that somehow you have activated the "Close Caption" feature. Corrective procedure would of course be to disable/turn it off.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 19, 2008
  • Louie  Role
    Louie Role Feb 20, 2008
    Hi again,
    The going from top to bottom makes it an entirely different issue. You have a 60 cycle hum in your video. This could either be:
    1. interference in your signal source which include aerial, cable, DVD, VCR. Pls check if the AC plugs are fitted correctly to the mains outlet. In some instances reversing the way they are plug in also helps. If it is only when watching TV programs, then perhaps you can bring this concern to the attention of your cable provider. It using an aerial, you may need to reorient the antenna;
    2. at other times, this could be caused by a fault with the big filter capacitor in the power supply. The PSU though getting and giving sufficient power is not filtered enough and allows stray hum to enter the circuitry. This is then displayed as the black moving bar super imposed on the video.
    #1 would be relatively easily to verify, however #2 would perhaps require the services of a qualified professional.
    Chhers.
I have a philips flat panel lcd model#42PFL36030/27 I have a vertical yellow line that is near the left side of the screen. The TV is only 2 years old. What could this be and what can I do to fix this...
This problems are alway the causes by the T-CON decoders board that sit at the bottom wright in middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to a refurbish T-CON decorders board for the replacement.
Nov 20, 2010 | Philips 42PFL3603D 42 in. LCD TV
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
Whats causing horizontal lines in my philips 42 in. plasma tv? seems to be 4 sets of lines with about 15 to 20 lines in each set. Also has the red vertical explosion from images on the channel im watching.
There are very fragile ribbons that are attatched to the top of some LCD displays, if these have been pinched or damaged in anyway, this can create what you are describing. Was the LCD panel ever hit by like a wii remote around the tv bezel or did it fall without cracking the screen? It could be something simpler like, some really wrong color settings or something...
Jun 14, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Black vertical lines across the full screen on 42in lg plasma tv
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Mar 26, 2010 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Plasma has half screen good and other half no picture just colored lines
bad buffer board email me and tell me if there horizontal or vertical these board are about 30. to 100. redscomputers@gmail.com
Oct 19, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Vertical green line
You've got a bad panel. Hopefully Philips support will stand by their product & give you credit towards a new TV or replace your panel. There is no other way around this.
Apr 06, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Phillips Plasma 42PF3320
I have phillips 42" plasma tv it has 7 red light flashes at start up and locks out
Jun 15, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
Lines through flat screen
The only Item to fix a vertical line running through screen is to replace the panel itself. You can check the price at a repair shop or through parts.com for a rough estimate but I can tell you it will be more than what the TV is worth.
Apr 23, 2008 | Philips 42PF9996 42 in. HD-Ready LCD...
White lines equally spaced 1" apart.
This is probably caused by the small signal board. It controls and decodes the picture information before it is sent to the display panel. It can be fixed by a quailified technician and if you contact philips (this is who makes magnavox) they will tell you the closest certified technician. Hope this helps.
Mar 29, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Phillips plasma 42 in tv thin
malfunction of the vertical output integrated circuit
Dec 22, 2007 | Philips E-Box FTR9965 DTV Receiver
Open Questions:
See all Philips 42PF7220A 42 in. Plasma Television Questions
Philips 42PF7220A 42 in. Plasma Television Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
