Question about Watches
How do u get the keyboard yo turn sideways when typing? I've simply turned it sideways when typing but it doesn't work.
    President:
  • 2,501 Answers
Change the page layout from p
"portrait " to "landscape".
Posted on Feb 02, 2010
MTG 900 SAYING "CHARGE" AND I'VE BEEN PUTTING
I am assuming you are reading the battery charge correctly. If so you need a new rechargable battery. Special battery so it is a little expensive. Make sure the person knows it is a "rechargable battery" you want. A regular battery will not work properly or recharge.
Nov 02, 2011 | Casio Atomic-Solar MTG900 Watch
Tip
HOW TO START YOUR AUTOMATIC WATCH
mcdevito75 here,The Automatic feature in your WATCH consists of a counter-weight attached to the MAIN SPRING by a gear that allows a SLOW but steady wind of your watch with the motion of your WRIST, ARM. Once, only in HIGH END watches, today almost all watch manufacturers have this feature in some of their models. Everyone who owns an AUTOMATIC watch knows, you can START your AUTOMATIC watch by WINDING THE STEM and you can continue to wind the stem with no end. This will at least START your AUTOMATIC watch and, this is true to some extent BUT, does this apply to my watch you ask?, Here"s how to tell if your AUTOMATIC watch will START with a few winds of the stem or not. ------- Very Simply, Hold your AUTOMATIC watch to your ear and wind the stem, if you hear a sound as though something is DRAGGING or the stem feels slightly stiff one way you wind the stem and you hear a clicking sound when you wind in the other direction, then you have the TYPE of AUTOMATIC watch that will start with a few winds of the stem, approx, 20 turns or winds. If on the other hand you hear nothing when you wind the stem and the stem feels very loose when turnning then you have the TYPE of AUTOMATIC watch that winds only with the motion of your wrist / arm, to start this type of AUTOMATIC watch, simply hold the watch in your hand and rock your watch back and forth, say from the 12 O"clock to the 6 O"clock, and or, Hold your watch securely in your hand a make circular motions with your hand, any movement to get your watches counter-balance to turn and thus wind your watch. Approx. 1 minute of this extra motion will start your AUTOMATIC watch, then simply wear your watch and your wrists / arm motion will keep it wound.
on Jul 06, 2010 | Watches
The day date always now switches over at noon instead of midnight. I've tried to reset it correctly several times, but it doesn't work. what do I need to do?
Hi!
The problem you described is caused by incorrect setting of the hour: AM and PM must be set correctly, AM before noon and PM afternoon.
For more details regarding setting of your watch, please visit Citizen site here:
http://www.citizenwatch.com/COA/English/settings.asp
Please let me know if it helped,
good luck!
Aug 09, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Water inside
you need to open the back plate of your watch and sit the watch in a dry warm area for atleast 24 hours to allow the water to evaporate and dry out..to open the back If the back plate of your watch is smooth around the edges, then it will pry off. Look carefully around the edges for a spot with a small gap, which it may or may not have. Prying gently with the tip of a sharp knife, usually with a light twisting motion, will pop the back plate off the watch. It simply presses back into place with moderate-to-light pressure. IF the back plate has notches around the edge, it need to be unscrewed from the back. Harbor Freight has a cheap tool to engage these notches and turn the plate, but I've had good luck simply using the tips of a needle-nose pliers to engage these notches and unscrew the plate.
Jun 19, 2011 | Chase Burberry Endurance BU7503, Steel...
Question 1:Well,this guy was gonna throw away this watch,so i asked him if i could have it.Now i have a Guess G65023G watch that doesn't work. I want to fix that. Problem 1:The minute hand turns when...
Well, thats a good watch. however, based on the conditions of your watch, probably, its battery is not dead. some of its mechanism were not in place or broken. Repairing it is advisable. Afterall it has no scratches like what you've said. So go for repair men!
Jun 09, 2011 | Guess G65023G Watch for Men
Can not turn on
Then it needs a new battery or some sort of repair. The button on the face turns the monitor on for use, if this doesn't work, then you need to replace something.
Apr 24, 2011 | Polar FS1 Unisex Heart Rate Monitor Watch
After inserting the batteries I do not get any lcd reading.
mcdevito75 here, Double check your battery insertion 1 of them or both incorrectly installed. If you"ve used to much pressure in installing the batteries you could have damaged the LCD display happens with Casio LCD"s. If the LCD display has turned color it may be shot. It may also be you need the press any function button to activate the LCD as when you installed new batteries it simply shut down.
Jun 25, 2010 | Watches
I have a problem pulling out the stem to set the date on my Roadster. Can you help? I can't seem to grasp the stem securely enough to pull it out. Thank you
mcdevito 75 here, you should be able to get a finger nail just under the stem to lift the stem to set the time, day/date, first be sure the stem isn"t a screwdown type, gasp the stem and turn it to see, if it is a screwdown type, simply un-screw the stem then pull it out to set the time, day/date. If all fails your local or any jeweler can help.
Jun 16, 2010 | Cartier Roadster W62016V3 Wrist Watch
Please i want to sign in to yahoomail but it is not working so help me
mcdevito75 here, From your computers home page, that"s the page your computer shows once you"ve connected to the internet. Up at the top of the page see the yahoo logo, or my yahoo, or simply type in Yahoo mail in the search box, then just follow the instructions given to go to yahoo mail.
Jun 08, 2010 | Citizen Watches
I've recently found an old Elgin pocketwatch (Hunter Case, 1904?)
If you wish to return this watch to a working condition you need to find a skilled watch repairer who is willing to take on a challenge.
It could prove to be very expensive is parts have to be made to replace anything that is worn out or broken.
Jan 05, 2010 | Elgin Circa 1904 Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
