Question about Sony STR-V333ES 5.1 Channels Receiver
Sony STR-V333ES repeatedly clicks when i try to power it up. is there an internal fuse???
You most likely have a short in one of your speaker wires (+ and - are touching somewhere) causing the receiver to enter a protect mode "Click!". Disconnect all speaker wires then connect and test each one at a time to find the culprit. I've seen this happen with speaker wire or a subwoofer cable that is too small of a gauge. Hope that helps.
Posted on Jan 07, 2010
I have a SONY STR DE915 receiver home theater amp. After 14 years, it decides not to power up! Are there internal fuses? Can i replace the power supply myself?
There are internal fuses that you can check. This model was notoriously bad for amp problems. These amps would burn up a lot of components when they go out.
Oct 11, 2013 | Sony STR-DE915
Sony tv doesn't turn on and there are no lights flashing. Fuse is still intact too. Any thoughts?
Hello
Your TVs internal power supply [usually STR controlled}, is in trouble. It does not outputs any of the internal secondary power voltages. As fuse haven't blown off, there may be some loose soldering around it. Please resolder all the solderings. Check the High Watt wirewound resistors too. Ok.
Oct 18, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have the same problem. The fuse blows every time I plug the Sony STR-DE135 into the wall. I did not find the F901 at Radio Shack, so I bought a fast acting 5 Amp 125V Fuse at the Hardware store. It blew...
There is usually one or two normal clicks on power-up. A self-protection relay activates after a short delay for circuit and power stabilization plus some internal cheking for shorts and thermal issues.
If it keeps blowing fuses you are stressing it a bit more every time you feed it another one. I'd get it in to a Pro for repair.
Mar 02, 2010 | Sony STR-DE135 Receiver
Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
Feb 13, 2010 | Sony STR-DE445 Receiver
I have a Sony STR DB930. Something happend and it
The fuse blowing is a symptom of something seriously shorted internally. What preceded the initial problem? Smoke is bad. Fire would be soon to follow without the fuse blowing. Take it to a tech.
Feb 08, 2010 | Sony STR-DB930 Receiver
No power on my Sony STR-DA555ES
i went to sony's webite and called direct and got a power supply for just under 200 dollars to my door better than paying 1500 for a new one i over loaded mine and plug to may things in the back of it but the part is available
Jan 07, 2010 | Sony STR-DA555ES
On the display of my sony str-de135 appears the word"protect" and then the cd does not work. what must I do ?
your speaker wires are grounding out on something or you have popped an internal fuse or youve burnt the power supply refer to your manuel
Oct 07, 2009 | Sony STR-DE135 Receiver
Sony STR-DE335 will not power on, I can hear clicks inside like it is trying to but it never does.
these tend to have bad stk-350 preamp ic's in them. sometimes they can be resoldered though.
Jul 16, 2009 | Sony STR-DE335 Receiver
I have a sony str de445 and it overheated one nite and stoped working. when i click the power button it clicks as if it turn on but no display or sound or anything, could you help please
you might have burned up some internal parts, it is very important that you keep your unit well ventalated so that it has less of a chance at overheating, check for any internal fuses that might have blown.
Jun 27, 2009 | Sony STR-DE445 Receiver
My sony v333es say protection panel power off
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 03, 2008 | Sony STR-V333ES 5.1 Channels Receiver
Sony STR-V333ES 5.1 Channels Receiver Logo
311 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
