Question about Hobart AM14-253 Free-standing Dishwasher
Hobart am 14 electric heat does not turn on water temp just drops
  • 3 Answers
Assuming that the machine fill cycle works properly and the float is intact, and the heater contactor doesnt pull in:
possible heater contactor malfunction: check for power to coil
High limit snap thermostat may be tripped or damaged ( needs to be manually reset). located in heater connection cover.
Thermistor probe and or wiring to it may be damaged
main control board may not be functioning properly. check output to heater curcuit
Posted on Feb 11, 2010
Hobart undercounter high temp dishwasher not heating water
am14 is not an under counter. Please specify what you have and is the issue is with wash or rinse heat.
Dec 31, 2013 | Hobart AM14C-155 Dishwasher
I have a am-14 hobart washer. having problem with rinse temp indicator. it is fine for the wash then the temp gauge is jumping around, could it be the thermostat?
Your rinse temperature sensor that is a tiny probe in the water piping (top rear of machine) needs replaced. Hobart part # 00-294692. It costs about $84.
Oct 19, 2012 | Hobart Dishwasher Am-14 Commercial Dish...
Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Feb 04, 2010 | Hobart AM14C-155 Dishwasher
Hobart dish machine low wash temp
make sure all the curtains are there ,also check for any baffles missing from mach. should be 2 1 on incoming side 1 on outgoing, also ck hood vents had problem before with vents wide open sucking heat right out of warewasher
Jan 09, 2010 | Dishwashers
Hobart AM-14 water temperature not maintained
Hobart AM-14 will wash and rinse in manual, but not in automatic
Oct 01, 2009 | Hobart AM14-253 Free-standing Dishwasher
AM14 tank heaters--when are they energized?
How hot is the wash temp?It should be 150-165 degrees.The model is an am14 not an am15?I'm hobart tech and repair these units weekly.Let ne know.
Feb 26, 2009 | Hobart AM14-253 Free-standing Dishwasher
Verifying breaker rating of AM-14
Commercial dishwashers don't take it for granted that the hot water is hot enough to sanitize. And, they know restaurants need to turn dishes.
So there is enough heat to make sure warm water heats up quickly to sanitizing temperatures.
Jan 29, 2009 | Hobart AM14-253 Free-standing Dishwasher
Hobart am-14
facing front of machine top right near pressure guage there is an electric solenoide valve , you must change the kit inside it is eighter diaphram type or piston type, you must shut off the water inlet before servicing, then undu the 4 bolts on the top of the valve to see if it is diaphram or piston
Alain
services.techniques.jcv@gmail.com
Apr 15, 2008 | Hobart AM14-253 Free-standing Dishwasher
Hobart AM14-253 Free-standing Dishwasher Logo
282 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
