Question about Brother MFC-665CW All-In-One InkJet Printer
I have moved and can't find my installment papers for my broterh MC 665cw printer is it possible to install without have this information, if so can u please tell me how to install. also, i have also updated my computer to window xp 7
  • 4,041 Answers
Hi
You will have to get the right software for it to run, I will try to find it for you but this could take time because it is not easy to find a driver for Windows 7, most drivers are for windows xp, but they have made some drivers for the new windows 7 but not for all printers yet, vista driver will work as well but that’s another driver hard to get hold of also you go to make sure if your windows 7 is 32bit or 64bit you are using it got to be the right driver for it.
That’s the problem with the new windows 7 at this moment.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 01, 2010
I hve windows 7 and am trying to set up brother mfc-665cw wireless is it supported
Try installing the software that shipped with the MFC. If you have problem installing the software on Windows 7, you can go to the Brother Solution Center and download the latest version. If the Optical character Recognition software is not installed with the suite downloaded from the web, you will have to use the CD shipped with the machine to install it.
You will need to use the software to add a new printer to your network.
Aug 27, 2011 | Brother Multi-Function Center MFC-665CW...
Will not print or shut off comes up unable to print 50
I had this same problem and it is an easy fix. It is similar on all brother printers but mine was a 5860CN.
Lift the lid on your printer and at the back you can see the opening where the print head is.
With the power off, use your finger to move the print head into the middle.
Now feel under the lip of the cover at the front of the gap and you will find a plastic strip that runs from one side to the other. This is the encoding strip and it what the print head uses to read where it is. This encoding strip is easily pushed out of position when a paper jam occurs and all you need to do is to get it back into position. Using both hands use a finger on either side of the print head and lift the encoding strip upwards slightly and move slightly towards the back of the printer. This will locate it back into the correct position in the print head when you release. You can feel this with your fingers. Power back on and the problems will be gone!
Remember and be gentle so as not to damage the encoder strip!
Nov 27, 2010 | Brother Multi-Function Center MFC-665CW...
Printer grabes paper at an angle every time i try to print a page,never has done this before, am using same kind of paper, just keep's going in sidways,thank's rr
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Please follow the steps given below to perform the self-test:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let me know.
If it still fails to feed the paper correctly, please reply with the following information:
What type and brand of paper were you using?
Have you ever used this type or brand of paper before and if so what were the results?
Once we have this information we will try to fix the unit through email support.
Apr 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
Will not print in color brother mfc-665cw
Check to see if the ink color is installed correctly....if it is installed correctly...then you may right click on the printer name in the printers menu...choose properties and look for where it says print in color or black and white and chose the appropriate one as you desire..
Mar 26, 2009 | Brother Multi-Function Center MFC-665CW...
I have lost the installation disk for my brother mfc-665cw printe
Here is the link to the brothers website with your printer information already put in: http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc665cw_us_as
Just select driver, firmware, or utilites to get what you are looking for. If you need help installing it just leave a comment and I'd be glad to help you further. If this helps you please rate, thanks!
Jan 13, 2009 | Brother MFC-665CW All-In-One InkJet...
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
Printing problem with MFC-665CW
1. Take paper tray completely out of the machine.
2. Remove the rear cover, clean the paper pick-up roller.
3. Put rear cover back, put paper tray into machine.
4. Copy a blank page for paper feeding test.
Jan 23, 2008 | Brother Multi-Function Center MFC-665CW...
Brother MFC-665CW All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
