Question about Maytag Dryers
INSTALATION DETAIL COULD YOU TELL ME PLEASE IT IS
INSTALATION DETAIL COULD YOU TELL ME PLEASE IT IS NECESSARY TO INSTALL EXHAUST PIPE B/C WITHOUT THIS IT IS NOT WORKING.
Baixar esse progama
Posted on Feb 01, 2010
Will putting block off plates on my 1998 ZX 11 D stop it from popping on deceleration
Hi, Derek not sure what block off plates are but silicone sealing the slip joints in your exhaust system and new exhaust pipe to head gaskets will, your probably sucking air, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
How To Install Motorcycle Exhaust at RevZilla com
Motorcycle Exhaust Installation TOTW Video HD Do it Yourself
Install Vance Hines Pro Pipe Exhaust on Harley Davidson Biker Motorcycle...
http://motorhead.jactup.com/ZX-11/tech/ZX11_Service_93_01-converted.pdf
Dec 10, 2015 | Motorcycles
Diragram on how to change the water pump on a 1995 z24 cavalier 2.3
Check this procedure, according with the repair guide for...
2.3L and 2.4L Engines
(see Figure 9)
  1. Disconnect the negative battery cable
  2. Detach the oxygen sensor connector.
  3. Properly drain the engine coolant into a suitable container. Remove the heater hose from the thermostat housing for more complete coolant drain.
  4. Remove upper exhaust manifold heat shield.
  5. Remove the bolt that attaches the exhaust manifold brace to the manifold.
  6. Remove the lower exhaust manifold heat shield.
  7. Break loose the manifold to exhaust pipe spring loaded bolts using a 13mm box wrench.
  8. Raise and safely support the vehicle.
It is necessary to relieve the spring pressure from 1 bolt prior to removing the second bolt. If the spring pressure is not relieved, it will cause the exhaust pipe to twist and bind up the bolt as it is removed.
  1. Unfasten the two radiator outlet pipe-to-water pump cover bolts.
  2. Remove the manifold to exhaust pipe bolts from the exhaust pipe flange as follows:
    1. Unscrew either bolt clockwise 4 turns.
    2. Remove the other bolt.
    3. Remove the first bolt.
On the 2.4L engines, DO NOT rotate the flex coupling more than 4° or damage may occur.Pull down and back on the exhaust pipe to disengage it from the exhaust manifold bolts.
  1. Remove the radiator outlet pipe from the oil pan and transaxle. If equipped with a manual transaxle, remove the exhaust manifold brace. Leave the lower radiator hose attached and pull down on the outlet pipe to remove it from the water pump. Leave the radiator outlet pipe hang.
  2. Carefully lower the vehicle.
  3. Unfasten the exhaust manifold-to-cylinder head retaining nuts, then remove the exhaust manifold, seals and gaskets.
  4. For the 2.4L engine, remove the front timing chain cover and the chain tensioner. For details, please refer to the procedure located later in this section.
  5. Unfasten the water pump-to-cylinder block bolts. Remove the water pump-to-timing chain housing nuts. Remove the water pump and cover mounting bolts and nuts. Remove the water pump and cover as an assembly, then separate the two pieces.
Fig. 9: Water pump and cover mounting - 2.3L and 2.4L engines (click over image for zoom)
To install:
  1. Thoroughly clean and dry all mounting surfaces, bolts and bolt holes. Using a new gasket, install the water pump to the cover and tighten the bolts finger-tight.
  2. Lubricate the splines of the water pump with clean grease and install the assembly to the engine using new gaskets. Install the mounting bolts and nuts finger-tight.
  3. Lubricate the radiator outlet pipe O-ring with antifreeze and slid the pipe onto the water pump cover. Install the bolts finger-tight.
  4. With all gaps closed, tighten the bolts, in the following sequence, to the proper values:
    1. Pump assembly-to-chain housing nuts-19 ft. lbs. (26 Nm).
    2. Pump cover-to-pump assembly-106 inch lbs. (12 Nm).
    3. Cover-to-block, bottom bolt first-19 ft. lbs. (26 Nm).
    4. Radiator outlet pipe assembly-to-pump cover-125 inch lbs. (14 Nm).
  5. Using new gaskets, install the exhaust manifold. Make sure to following the tightening sequence and torque specifications given in the exhaust manifold procedure located in this section.
  6. Raise and safely support the vehicle.
  7. Index the exhaust manifold bolts into the exhaust pipe flange.
  8. Connect the exhaust pipe to the manifold. Install the exhaust pipe flange bolts evenly and gradually to avoid binding. Turn the bolts in until fully seated.
  9. Connect the radiator outlet pipe to the transaxle and oil pan. Install the exhaust manifold brace, if removed.
  10. On the 2.4L engine, install the timing chain tensioner and front cover.
  11. Install the lower heat shield.
  12. Carefully lower the vehicle.
  13. Fasten the bolt that attaches the exhaust manifold brace to the manifold.
  14. Tighten the manifold-to-exhaust pipe nuts to specification.
  15. Install the upper heat shield.
  16. Attach the oxygen sensor connector.
  17. Fill the radiator with coolant until it comes out the heater hose outlet at the thermostat housing. Then connect the heater hose. Leave the radiator cap off.
  18. Connect the negative battery cable, then start the engine. Run the vehicle until the thermostat opens, fill the radiator and recovery tank to their proper levels, then turn the engine off.
  19. Once the vehicle has cooled, recheck the coolant level.
Hope helps; remember to rating this answer and leave a testimonial comment. Thank you for using FixYa.
Oct 13, 2011 | 1995 Chevrolet Cavalier
My brothers O2 sensor went out on his 97 2.3l ranger and we are having an hell of an time finding. Could you please tell me in detail where both of them are. thank you
They should be located before and after your cat converter in your exhaust system. Im not familiar with this vehicle but all O2 sensors are mounted basicly in the same area.
Apr 10, 2011 | Ford Ranger Cars & Trucks
My husband and I are trying to get to our thermostat to change in my 2002 rendezvous, but there is a metal pipe in the way that we can't figure out how to remove. just behind the pipe, is a metal plate...
Hello vocalviixen,
The pipe that you referred to is the exhaust crossover pipe. Below I've included removal and installation instructions.
Also, the procedure for bleeding the coolant system is critical; if you need those instructions please post the question.
REMOVAL PROCEDURE
1. Disconnect the battery ground (negative) cable.
2. Remove the throttle body air inlet duct.
3. Drain the coolant from the cooling system.
4. Remove the inlet radiator hose from the engine.
5. Remove the thermostat bypass pipe.
6. Remove the exhaust crossover heat shield bolts.
7. Remove the exhaust crossover heat shield.
8. Remove the exhaust crossover pipe studs/nuts.
9. Remove the exhaust crossover pipe.
INSTALLATION PROCEDURE
1. Install the exhaust crossover pipe.
2. Install the exhaust crossover pipe studs/nuts.
3. Tighten the exhaust crossover pipe studs/nuts to 18 lb ft.
4. Install the exhaust crossover heat shield.
5. Install the exhaust crossover heat shield bolts.
6. Tighten the exhaust crossover heat shield bolts to 89 lb in.
7. Install the thermostat bypass pipe.
8. Install the inlet radiator hose to the engine.
9. Fill the cooling system with engine coolant.
10. Install the throttle body air inlet duct.
11. Connect the battery ground (negative) cable.
Regards,
netvan
Mar 14, 2011 | 2002 Buick Rendezvous
How to do an oilpan on a 88 chevy montecarlo
  1. Disconnect battery negative cable.
  2. Remove air cleaner.
  3. Remove upper fail shroud (V8)
  4. Raise vehicle and drain oil pan.
  5. Disconnect A.I.R. hose at converter pipe (V8)
  6. Disconnect A.I.R. pipe at exhaust manifold (V8)
  7. Remove exhaust crossover pipe at manifold and converter.
  8. Remove starter.
  9. Remove flywheel cover.
  10. Disconnect transmission oil cooler lines at oil pan.
  11. Remove engine mount 'through' bolts on V8. Loosen right bolt and remove left on V6.
  12. Remove oil pan bolts and lower oil pan. Check that forward crankshaft throw and/or counter balance weight are not extending downward so to block oil pan removal. Turn crankshaft, necessary, to put throw on horizontal plane.
  13. Raise engine.
  14. Remove oil pan.
Installation
  1. Clean sealing surfaces on cylinder case and pan.
  2. Check oil pan gasket for damage; replace if necessary.
  3. Apply a small amount of 1052751 or equivalent to front and rear corners of oil pan.
NOTICE: Only a small amount of sealant is required. Excessive amounts of sealant may cause a problem with proper sealing of oil pan.
  1. Install retaining bolts and torque to 9 N.m (80 lb. in.).
  2. Raise engine, if necessary.
  3. Lower engine, install mount 'through' bolts and torque to 50 lb. ft. (65 N.m).
  4. Install torque converter cover.
  5. Install starter.
  6. Install exhaust crossover pipe at manifold and converter.
  7. Lower vehicle.
  8. Install fan shroud.
  9. Install air cleaner.
  10. Fill crankcase with oil.
  11. Connect battery negative cable, start engine and check for leaks.
Nov 30, 2010 | 1987 Chevrolet Monte Carlo
WHAT ARE THE TORQUE SPECS FOR A WATER PUMP ON A 2003 CHEVY MALIBU
Water Pump REMOVAL & INSTALLATION CAUTION
Never open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old. 2.4L Engine
  2. Detach the Oxygen (O2) sensor electrical connector.
  3. Properly drain the engine coolant into a suitable container. Remove the heater hose from the thermostat housing for a more complete coolant drain.
  7. Break the manifold-to-exhaust pipe spring loaded bolts loose using a 13mm box wrench.
  8. Raise and safely support the vehicle. NOTE: It is necessary to relieve the spring pressure from 1 bolt prior to removing the second bolt. If the spring pressure is not relieved, it will cause the exhaust pipe to twist and bind up the bolt as it is removed.
  9. Unfasten the two radiator outlet pipe-to-water pump cover bolts.
  10. Remove the manifold to exhaust pipe bolts from the exhaust pipe flange as follows:
    3. Remove the first bolt. NOTE: DO NOT rotate the flex coupling more than 4°or damage may occur.
  11. Pull down and back on the exhaust pipe to disengage it from the exhaust manifold bolts.
  12. Remove the radiator outlet pipe from the oil pan and transaxle. Leave the lower radiator hose attached and pull down on the outlet pipe to remove it from the water pump. Leave the radiator outlet pipe hang.
  13. Carefully lower the vehicle.
  14. Unfasten the exhaust manifold-to-cylinder head retaining nuts, then remove the exhaust manifold, seals and gaskets.
  15. Remove the front timing chain cover and the chain tensioner. For details, please refer to the procedure located later in this section.
  16. Unfasten the water pump-to-cylinder block bolts. Remove the water pump-to-timing chain housing nuts. Remove the water pump and cover mounting bolts and nuts. Remove the water pump and cover as an assembly, then separate the two pieces. Fig. 1: Water pump and cover mounting - 2.4L engine 87953070.gif
    To install:
  17. Thoroughly clean and dry all mounting surfaces, bolts and bolt holes. Using a new gasket, install the water pump to the cover and tighten the bolts finger-tight.
  18. Lubricate the splines of the water pump with clean grease and install the assembly to the engine using new gaskets. Install the mounting bolts and nuts finger-tight.
  19. Lubricate the radiator outlet pipe O-ring with antifreeze and slide the pipe onto the water pump cover. Install the bolts finger-tight.
  20. With all gaps closed, tighten the bolts, in the following sequence, to the proper values:
    1. Pump assembly-to-chain housing nuts:19 ft. lbs. (26 Nm).
    2. Pump cover-to-pump assembly: 106 inch lbs. (12 Nm).
    3. Cover-to-block, bottom bolt first: 19 ft. lbs. (26 Nm).
    4. Radiator outlet pipe assembly-to-pump cover: 125 inch lbs. (14 Nm).
  21. Using new gaskets, install the exhaust manifold. Make sure to following the tightening sequence and torque specifications given in the exhaust manifold procedure located in this section.
  22. Raise and safely support the vehicle.
  23. Index the exhaust manifold bolts into the exhaust pipe flange.
  24. Connect the exhaust pipe to the manifold. Install the exhaust pipe flange bolts evenly and gradually to avoid binding. Turn the bolts in until fully seated.
  25. Connect the radiator outlet pipe to the transaxle and oil pan.
  26. Install the timing chain tensioner and front cover.
  27. Install the lower heat shield.
  28. Carefully lower the vehicle.
  29. Fasten the bolt that attaches the exhaust manifold brace to the manifold.
  30. Tighten the manifold-to-exhaust pipe nuts to specification.
  31. Install the upper heat shield.
  32. Attach the oxygen sensor connector.
  33. Fill the radiator with coolant until it comes out the heater hose outlet at the thermostat housing. Then connect the heater hose. Leave the radiator cap off.
  34. Connect the negative battery cable, then start the engine. Run the vehicle until the thermostat opens, fill the radiator and recovery tank to their proper levels, then turn the engine OFF.
  35. Once the vehicle has cooled, recheck the coolant level, then install the radiator cap.
3.1L Engine
  1. Disconnect the negative battery cable.
  2. Properly drain the cooling system into a suitable container.
  3. Loosen, but do not remove, the water pump pulley bolts.
  4. Remove the serpentine belt.
  5. Unfasten the water pump pulley bolts, then remove the pulley.
  6. Remove the five water pump mounting bolts, then remove the water pump. To install: Fig. 2: View of the water pump mounting and bolt tightening specifications - 3.1L engine shown 86883115.gif
  7. Clean all the gasket surfaces completely.
  8. Apply a thin bead of sealer around the outside edge of the water pump along the gasket sealing area, then install the gasket onto the water pump.
  9. Position the water pump on the engine, then tighten the water pump mounting bolts to 89 inch lbs. (10 Nm).
  10. Install the water pump pulley and finger-tighten the pulley bolts.
  11. Install the serpentine belt.
  12. Tighten the water pump pulley bolts to 18 ft. lbs. (25 Nm).
  13. Fill the cooling system.
  14. Connect the negative battery cable, then start the engine. Let the engine run until it reaches normal operating temperature, then check for leaks and coolant level. Add coolant, if necessary, then turn the engine OFF.
Nov 03, 2010 | 2003 Chevrolet Malibu
How do I replace a water pump on a 1999 malibou with a quad 4?
    To install:
Oct 26, 2010 | 1999 Chevrolet Malibu
How to replace water pump on 97 pontiac sunfire 2.4
PLEASE DON'T FORGET TO RATE! THANKS! 2.3L & 2.4L Engines
  2. Remove the radiator outlet pipe from the oil pan and transaxle. If equipped with a manual transaxle, remove the exhaust manifold brace. Leave the lower radiator hose attached and pull down on the outlet pipe to remove it from the water pump. Leave the radiator outlet pipe hang.
  5. For the 2.4L engine, remove the front timing chain cover and the chain tensioner. For details, please refer to the procedure located later in this section.
Water pump and cover mounting-2.3L and 2.4L engines
To install:
Sep 13, 2010 | Pontiac Sunfire Cars & Trucks
Where are the exhaust system bolts located?
Removal & Installation 2.2L Engine To Remove:
  1. Remove or disconnect the following:
    • Negative battery cable.
    • Heat shield.
    • Oxygen sensor.
  3. Remove exhaust pipe from the exhaust manifold.
  4. Lower the vehicle.
  5. Remove the exhaust manifold mounting nuts from the cylinder head. chevy_cav_02-04_exmanifold.gif
  6. Remove the exhaust manifold.
  7. Clean the mating surfaces.
  8. Check for cracks, broken flanges and gasket surface damage.
  9. Use a straight edge and a feeler gauge. If the flanges or the mating surfaces do not align, the manifold is warped and should be replaced.
To Install:
NOTE: The manufacturer recommends using new exhaust system nuts.
  1. Install the manifold gasket.
  2. Position the exhaust manifold to the cylinder head. Exhaust manifold 2.2L 87953055.gif
  3. Install the new exhaust manifold nuts. Tighten the nuts starting from the center and working toward the ends to 110 in lbs (12.5 Nm).
  4. Raise and safely support the vehicle.
  5. Install the exhaust pipe to the manifold using a new flex coupler gasket.
  6. Install new exhaust flange mounting nuts.
    • Tighten to 33 ft lbs (45 Nm).
  7. Lower the vehicle.
  8. Install the oxygen sensor.
  9. Install the heat shield.
  10. Connect the negative battery cable.
2.4L Engine To Remove:
  2. Disconnect the Oxygen (O2) sensor electrical connector.
  3. Remove the (O2) sensor.
  5. Remove the exhaust manifold brace-to-manifold bolt and the oil pan nuts, if necessary. Exhaust heat shield 2.4L 87953051.gif
  6. Remove the upper heat shield. NOTE: Do NOT bend the exhaust flex decoupler more than necessary to remove it. Excessive movement will damage the flex decoupler
  7. Remove the manifold-to-exhaust flex decoupler fasteners.
  8. Remove the exhaust pipe.
  9. Carefully lower the vehicle.
  10. Remove the exhaust manifold-to-cylinder head mounting nuts/bolts. Remove the exhaust manifold.
  11. Discard the gaskets and/or seals. Clean the mating surfaces.
To Install:
  1. Install new exhaust manifold gaskets. Position the exhaust manifold on the cylinder head. Tighten the mounting bolts in sequence to 110 in lbs (12.5 Nm).
  3. Install the exhaust manifold heat shield. Tighten the mounting bolts to 10 ft. lbs (14 Nm).
  4. Install the exhaust manifold brace-to-manifold bolt and the oil pan nuts. Tighten the mounting bolts to 41 ft lbs (56 Nm) and the nuts to 18 ft lbs (24 Nm).
  5. Position the exhaust pipe to the manifold. Install the manifold-to-flex decoupler mounting bolts. Tighten to 26 ft lbs (35 Nm).
  6. Lower the vehicle.
  7. Coat the threads with a suitable anti-seize compound and install the O2 sensor.
  8. Connect the O2 sensor electrical connector.
  9. Connect the battery ground cable and check for leaks.
Sep 02, 2010 | 2000 Oldsmobile Alero
Replacing the water pump
2.4L Engine
NOTE It is necessary to relieve the spring pressure from 1 bolt prior to removing the second bolt. If the spring pressure is not relieved, it will cause the exhaust pipe to twist and bind up the bolt as it is removed.
NOTE DO NOT rotate the flex coupling more than 4° or damage may occur.
87953070.gif Water pump and cover mounting—2.4L engine
Click to Enlarge
To install:
  3. Lubricate the radiator outlet pipe O-ring with antifreeze and slide the pipe onto the water pump cover. Install the bolts finger-tight.
  10. Install the timing chain tensioner and front cover.
  18. Connect the negative battery cable, then start the engine. Run the vehicle until the thermostat opens, fill the radiator and recovery tank to their proper levels, then turn the engine OFF.
  19. Once the vehicle has cooled, recheck the coolant level, then install the radiator cap.
3.1L Engine
To install:
86883115.gif View of the water pump mounting and bolt tightening specifications—3.1L engine shown
Click to Enlarge
  1. Clean all the gasket surfaces completely.
  2. Apply a thin bead of sealer around the outside edge of the water pump along the gasket sealing area, then install the gasket onto the water pump.
  3. Position the water pump on the engine, then tighten the water pump mounting bolts to 89 inch lbs. (10 Nm).
  4. Install the water pump pulley and finger-tighten the pulley bolts.
  5. Install the serpentine belt.
  6. Tighten the water pump pulley bolts to 18 ft. lbs. (25 Nm).
  7. Fill the cooling system.
  8. Connect the negative battery cable, then start the engine. Let the engine run until it reaches normal operating temperature, then check for leaks and coolant level. Add coolant, if necessary, then turn the engine OFF.
Aug 20, 2009 | 1997 Chevrolet Malibu
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
