Question about HP LaserJet 2840 Printer
Hp 4345 mfp rpinter not pickup paper from tray 2(lower tray) erro
Pls give me solutions
    Scholar:
  • 94 Answers
Is it pulling paper from the manual feed station?
If so then you need to make sure the paper tray size is correct for your paper stock.
You can also pull out the tray completely - power off the system and while looking into the tray openning power on the system. As part of it's power up initialization- it will cycle the feeder roller shaft but not lower it for a pickup. If that does not spin then you may have a broken gear.
Is the printer making any strange noise?
let me know - we can take it from there.
Posted on Feb 01, 2010
My printer hp laserjet m1132 mfp give E1. Pls I need help
Albert,
This means that the paper try you're' trying to print from is empty. or at least the printer thinks it is. Can you confirm if there's paper in the tray?
Jan 31, 2016 | HP Office Equipment & Supplies
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
Error 13.01.00 - Jam in Tray 2. There is no jam. We've changed the pickup roller and separation pad twice. Problem started after technician installed the first pickup roller/separation pad set for routine...
try it without the separation pad. Since the problem started after the maintenance, it may nt be in properly. As you are getting the rubber on the paper, the roller is turning, but the paper is not going anywhere giving the error
Oct 23, 2013 | HP LaserJet M3027 MFP Printer
My HP laserjet printer is showing Out of paper repeatedly. How to fix it?
the out of paper erro can also be caused by worn pickup rollers. These rollers are used to pickup paper from the paper tray and feed it into the printer. When they get worn down they can't grip the paper to pick it up so the printer thinks the paper tray is empty. The pickup roller runs $3.99 and can be installed by the end user, no service center is needed. The part number is RL1-0266 and looks like this:
We carry them in stock if you would like to order one here:
http://www.ccl-la.com/catalog/product_info.php?products_id=202
I hope this helps, if so please rate my solution.
BuddyMc
Feb 09, 2012 | HP LaserJet 1018 Printer
PRINTER COULD NOT AUTOMATICALLY EJECT PAPER HP 4345, with error code 13.20
Check inside the MFP (manual feed tray) for a scrap or a whole sheet of paper.
There is one of three sensors that is sending a paper jam notice to the printer.
Nov 05, 2011 | HP LaserJet M4345 MultiFunction Printer
We just installed an HP 4345 mfp. Every job we print requires us to go to the printer display and choose a different paper tray. Tray 1 is the manual feed, Tray 2 is bond and Tray 3 is yellow. What do...
If you are setting the trays for non-plain paper then you need to ensure that your print driver is set to match the paper types that are set on the printer. Otherwise the printer will always ask you to confirm which paper you want to print on.
Aug 09, 2011 | HP LaserJet M4345 MultiFunction Printer
I have an hp laserjet 4345 mfp which gives error code 58.04.Please help me
Hi
Follow the below solution
Turn the MFP off, and then turn the MFP on.
58.4 = Engine power supply
Check the power supply connections
Replace the air-temperature sensor.
See Main fan (FN101) and reversing unit
do rate my solution
Jul 07, 2011 | HP LaserJet 4345mfp Printer
HP LaserJet 2840 Printer Logo
394 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
