What does the message F-08 mean on my Hotpoint Ultima wt721 please?
  • Washing Mach... Master
  • 3,463 Answers
Error code F08 that the heater relay cannot be activated.
Check all connections to the module, pressure switch, and heater element.
Hope this helps.
Posted on Feb 02, 2010
Hotpoint Ultima WT721 F 08 fault code
Try the brushes first. I'm guessing the carbon deposits on the floor are from the brushes.
Nov 16, 2013 | Washing Machines
I have a Hotpoint Ultima WT721. I originally got an error F-08. I am now getting arror H-20. The water fills and drains with no problems but it seems the water is not heating up. The obvious is the...
Yes, check the heater relay for correct operation as this will cause the same problem and the generic error condition is a defective or stuchk heater relay according to the Hoptpoint Service Manual.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 12, 2012 | Washing Machines
F 08 & f 02 flashing on my hotpoint ultima wf860 washing machine.
For most Indesit (Hotpoint and Ariston) models 'F08' means 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections'. 'F02' means 'motor jammed or module connections'! (apparently poor PCB connections are often the cause of faults)
So- if you are not electrically confident and competent yourself, which you may be, you need to employ the skills of a partner, friend or service engineer ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 16, 2011 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint ultima WT721 1200 spin keeps tripping out all plug sockets. Have changed fuse but still does it. What could it please?
hello, bad earth check all the wired connection to the washer if these are ok then check your socket wires make sure wires are tight if these ok then there may be fault inside the washer power supply hope it helps
regards
shaun
Jan 15, 2011 | Hotpoint Washing Machines
Hotpoint Ultima Wt761 is displaying F-08 what can I do any ideas please
First, try turning off the mains power to the machine for 30 minutes and switching it back on to see if the error persists. This indicates a problem with the heater relay or heater. This usually means that the relay cannot be operated due to a heater fault and that the heater will need replacing. A service call to replace it will be the quickest option.
Oct 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code F-08
The meaning of F08 is that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
In order to resolve this the only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Hoep this resolves your issue. God Bless.
Jul 09, 2009 | Hotpoint Ultima WF860 Front Load Washer
Help with correcting fault code f-5
F-05 error means:-- Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
TO RESOLVE THE PROBLEM:--
Check the Water Temperature Sensor, Heating Element and Element Relay globul1a.gif Check connections to the Sensor, Heating Element and Relay
May 07, 2009 | Washing Machines
Found filter on front of my WT721 hotpoint but tried turning anti clock wise it turns slightly but can,t get if off !
You are turning it the correct way, could be something stuck in the filter, just keep trying to unscrew it and pull hard at the same time.
Please rate my solution.
Thanks.
May 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ulima wt721
Error code F02 means the motor has jammed, and or the tacho is loose or broken.
You will find the tacho on the opp end of the motor to the pulley..
Check to see if it is loose or broken, if it is loose, just push it back in to position.
Plz rate my solution,
Thanks.
Jan 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wf 860
Taken from another post - just happened to me 5 mins agao so not fixed yet!......now showing F-01 (motor triac short circuit).....
F-08 heater relay stuck check pressure switch, heater and module connections poss pressure switch fault
Good luck and let me know if/when it's sorted as may give me an indication of costs etc
Sep 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
250 people viewed this question
Top Washing Machines Experts
