Question about Acer Aspire 5670 Notebook
Touch pad and keyboard freeze after startup
My acer aspire 3000 has been behaving really weird of late. As soon as i start up, after a couple of minutes, the touch pad and the keyboard stop functioning. I can still move the mouse pointer using a USB mouse and the same using a USB keyboard. but that too not for long. I tried a system restore, the problem wouldn't go. I tried using the recovery disks provided by Acer to perform a recovery, but the problem still persisted. I then deleted the partition I had and formatted my whole hard disk and then did a fresh install of XP from one of my friends' CDs. The problem was still there. I have also tried booting the system from a bootable CD with an OS like "Reatogo XPE" . They keyboard and touchpad seem to function perfectly well in that environment (although such an environment gives me only basic functionality). Please tell me how I can solve this problem as I seem to have tried everything possible short of contacting acer. I am having the same problem with my acer aspire 5670 . it is 2 years old.
  • 10 more comments
  • John  Campbell
    John Campbell Feb 29, 2008
    Same problem with an acer aspire 3000 laptop.
    Keyboard and mouse freeze after 10 sec on boot up.
    If you boot into safe mode, everything is fine.
    Reinstalling systems did not solve problem.
  • danuka Mar 23, 2008
    i have the same problem and i have acer aspire 5670....i also try the formating, deleting partitions and again format it.but not use. same problem happens.
    but problem is when using safe mode touch pad and keyboard working fine..plzzzz help ppl...plzzzzzzzzzzzzzzzz
  • Anonymous May 14, 2008
    connect without battery, works!!!
  • Anonymous May 15, 2008
    Acer does have a replacement program
    Check this link to the acer website
    https://www.acerbatteryrecall.com
    to "Determine if you have a battery pack subject to this replacement program."
    mine sadly didn't, taking the battery out and running of AC with the powercord solves the keyboard and touchpad freeze. I'm running Vista Business
  • yambut Jun 21, 2008
    having the same problem with a aspire 5050. trying to fix it for a co worker. After 4 days of reloading and fiddling removing the battery works. now I have to try to explain that if he wants the keyboard and touchpad to work he needs a new battery.
  • james482 Jul 09, 2008
    I have an Acer Aspire 3000, had exactly the same problem, machine would start up and get to windows log on screen but then touchpad and keyboard would not work, replaced hard drive after full restore didn't fix it, then I replaced the Ram, now £140 into a repair, guess what ? - same problem. Been searching on forums for days looking for fix, couldn't find anything. Sent my laptop reluctantly to a so called computer expert, he put new silicone grease onto processor/heat sinc, said it worked fine,when I started it up it was ok for a day, but the next day it locked up again. Getting really fed up by now. Read this forum, unplugged the battery and left it on mains power - works fine. Have ordered a replacement battery at £40, will let you know if it fixes it. I really think I would have been better putting the money towards a new laptop but these computers draw you into a battle of wills, never had a problem before that I couldn't fix myself. Hope some of this helps some other person to keep their money in their pocket. Will repost when I receive battery.
  • huxuning Jul 21, 2008
    Acer Aspire 5050 keyboard and mouse lockup, USB mouse works fine in Vista. I formated several times putting Vista and XP on the machine, also system restore failed to fix the lockup when booting up.
    Problem solved by starting windows after removing battey. I believe the battery was getting really hot, and the laptop ran cooler without it. Good luck
  • stevemnatp Sep 02, 2008
    I had this problem with my machine which is about the same age and found it was a battery fault. When removing the battery and powering on mains alone machine worked fine. New battery required.
  • Anonymous Dec 07, 2008
    key board , on board mouse , external mouse stops working or becomes frozen, these problems are being caused for unknown reasons and I am not able to fix permanently but one thing you can do, you have to use your system as a desktop thereby removing the battery solves all the problem, put back the battery and it starts to haunt you again ok, now remove the battery and you will find the problem is kind of solved. Thanks. K.V.Shriram -- Chennai City -- India
  • Anonymous Apr 29, 2009
    WOW, i really didnt think that taking out the battery would work!! but hey im a oc tech and i learn new and silly things about pcs every day.....
    This is a really bad peice of engineering for this to happen but thanks for the info... and the solution im a happy chappy once again...
  • mpommpo May 18, 2009
    Ditto 5670, input freeze in win screens only - resolved with removal of battery: - and I have 3 batteries all with the same problem - so I don't believe its the battery. Was having recharging issues for months preceding. I think the presence of the battery triggers a short in the charging system or maybe in the keyboard disable feature.
  • juandavid49 May 18, 2009
    tengo un acer 5670, y de un momento a otro, aparecia el aviso de bateria critica, el teclado y el mouse dejaron de funcionar. La solucion fue quitar la bateria, y ahi mismo funcionaron.
  • 20 Answers
Battery problem, remove battery... fixed!
Posted on Mar 14, 2008
  • Karthik Jun 10, 2013
    Thank you so much!! Had exact same problem on my laptop - Samsung NP350V5C (Windows 8). Removed the battery and problem goes away. My laptop is barely 2 months old.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
My Acer Aspire 5050 developed the exact same problem last wekk. I reinstalled everything and even a new operating system. It was only when I read the answer on this page that I took the battery out.
It has worked flawlessly ever since.
Posted on Apr 22, 2008
  • 70 Answers
It may be mechanical mistake...re-install all ur touchpad drivers..
Posted on Apr 11, 2008
    New Friend:
John Campbell, I'm an IT admin and looked over the most obvious, removing the batttery! It worked like a charm :-) THANKS!!!!!!
Posted on Dec 29, 2012
    Problem Solver:
  • 5 Answers
TRY TO RMOVE BATTERY AND ATTACH THE ADAPTER
AND TURN IT ON
Posted on Dec 01, 2012
    Cheetah:
  • 108 Answers
This is just a problem with the battery engine IC inside Aspire, in other words, they did a bad Windows driver for it. It works 100% fine under Linux, even if the battery is bad.
Posted on Feb 01, 2010
  • Gradius2 Feb 01, 2010
    Acer needs to provide a better driver for Microsoft. Is a bad programmed battery driver, under Linux works 100% even if the batter is bad, or need replacement, or wear.
My son solved this problem for me. It is a build up of excess electrical charge in the components of the laptop over time. it can be disbursed by closing down, pulling the power cord and the battery and then press and hold the power button for 30 seconds. Power back up and you are ok!
Posted on Dec 13, 2009
  • 4 Answers
Dear Reader
Yaw the machine becomes haunted when you use the machine as laptop ie. using the battery while operating. You may remove the battery and use it as power on desktop and the problems will vanish, when you put the battery the machine becomes haunted and will not listen to you every thing will freeze.
Removing the battery will fix all the problems and you will gain all the controls back.
Thanks
Posted on Dec 07, 2008
ACER Travelmate c110 - Touch pad and keyboard would lock up at random times for random lengths of time. USB mouse would work when touch pad was frozen. Tried reloading drivers and all that but nothing provided a solution. Searched the web and this is what worked for me.
In device manager, disable the MS ACPI-compliant control method battery. Tablet now runs fine on battery power or AC power.
Posted on Oct 28, 2008
  • cuddleo Jan 08, 2011
    I LOVE YOU! It worked like a CHARM for me!
I'll try removing the battery, tell you later if it worked...
thnks
Posted on Jul 28, 2008
Had Vista Business, worked fine with battery in for some time. Then it stopped working.
Formatted laptop again (Acer Aspire 5673wlmi) with Vista Ultimate, rebooted and it still freezes within 10 seconds of the desktop coming up.
Try booting just with the mains plugged in and the battery out - works fine.
Utter rubbish.
Posted on Jun 15, 2008
This solved the fault on my acer aspire 1640 thanks for the info great job guys.
Posted on Jun 11, 2008
Mine doesnt even work with the battery out and the mains plugged in, really weird, it happned once but i restarted and all was ok, now its not having any of it.
Posted on Jun 04, 2008
Acer aspire 3003LMI. Thanks for you help saved all the time repairng windows that would not have worked
Mouse/keypad lock up after boot up. OK in Safe mode!
Took the battery out PC worked fine. The battery would only last for about 15 mins. So I will be buying a replacement.
Suspect over current theory is correct!
However did the act of removing the battery create a total power down in the system? So causing a fresh reboot?
Anyway my advice if you have the same fault remove the battery FIRST.
All the best
Posted on May 19, 2008
This is the link to acer's battery replacement program www.acerbatteryrecall.com
However, the replacement program is not related to any issues with keyboard and touchpad - it seems to be about batteries catching fire!
I have an acer aspire 5672wlmi (vista business) which has a bad battery. My battery sadly didn't mach the replacement criteria : (
Just taking the battery out and run on your adapter/powercord immediately solves the keyboard and touchpad issue. getting a new battery costs about 100€ and solves the issue aswell.
New drivers or any reinstall didn't work for me.
There is also a page wtih phonenumbers that you can call to check if you can get your battery replaced. I've tried the dutch number 078-150024 but it seems to be allways occupied
Posted on May 15, 2008
I have an acer aspire 5672 wlmi, it's having the same problem - freezing of keyboard and impaired funtioning of touchpad.
I took out the battery and the problem is fixed! (amazingly) However, I need to allways plugg-in my powercord, which sucks.
I'm writing Acer for a replacement battery
So TAKE OUT THE BATTERY
Battery problems works for me, Acer Aspire 3660. Thank you for your help.
Posted on Apr 25, 2008
Battery there was a recall on batterys from acer
Posted on Mar 27, 2008
Your computer should work well , without the battery.
then i visit a friend to test with another battery. it works.
That means that my battery was shortcicuit .
i bought a new battery an everything is working fine.
It was a respond to a battery problem.
I had the same problem tht u got :S.. problem in nt de lap. it is the battery. u cn unplug de battery and work fine. but sad seen whn f there power cut or current went of ur lap dead. so u hv 2 options.
01. chage the battery (this will cost u..... :S)
02. unplug the battery and work as u cn time. f u hv pc n home u can use UPS 4 giving current 2 lap (this will help more bcz f current when v can still work 30-40 min usin UPS. so can save fils. thn thz become a LAP --->>>> pC.. NW IM USING THZ OPPTION)
WORK AS MUSH u can from the Lap and change 2 new a good brand.
PROBLEM IS IN battery....
    Genius:
  • 3,587 Answers
This is mechanical..you may have a bad touchpad, or the connector under the keyboard is having some issues.
Posted on Feb 19, 2008
4 Suggested Answers
SOURCE: touch pad and keyboard freeze after startup
I've been having this problem myself. The thing is, whenever I disconnect the battery, everything decides to work fine. When I put it back in, everything turns into crap again. Try plugging your laptop in, but turning it on without the battery attached.
Posted on Mar 22, 2007
Well this might not solve your problem but it may help others. I thought I was having the wierdies! on my new Acer Aspire 5315 after happily installing Suse 11.0 and getting all but wireless to work. Yes even Crystal Eye was identified and Skype picks it up and give me a great pic.
Suddenly this morning for no apparent reason I could no longer use the touchpad only the mouse 'logitech' worked. Checked everything and then did a search using ixquick.com and got here. Tried all the suggestions including taking the battery out but nothing. Sat and pondered and then looking at the keyboard noticed that F7 had a little hand and finger pointing to a square icon just below and to the right of the F7. Umm! let see whar happens when I use the Fn and the f7 keys. BINGO!!!! Touchpad loves my fingers again.
Might help if anyone else has similar Aspires or laptops with lockout like this.
GaryC
Posted on Sep 30, 2008
jgwhomeequip
  • 1902 Answers
Check your memory. Reseat your memory. Try that first. The next step would be to get *********** board checked. All I own is Acers and I have had that same problem. Usually after reseating the memory everything seems to work just fine. But this could even be your graphics card. I would try and run a diagnostic on it and reseat the memory. You can run a diagnostics by shutting down the computer then hitting F8 and click on diagnosis and repair. And see what kind of a reading you get out of it.
Posted on Feb 04, 2009
My touchpad still wont work for my acer 3000
There is a button to turn on and off the touch pad. Is there a button on your keyboard that has the letters FN on it? if so hold that down and see what comes up. If not search for any kind of switch near your touch pad or that is on the keyboard that is not a normal typing key.
Mar 14, 2010 | Acer Aspire 3000 Notebook
My acer Aspire 3000 with a fresh windows xp home install, is having issues with the touchpad pointing device. I plug in a wired USB mouse and have no issues, but with the touch pad i am getting very eratic...
you may need to reinstall the drivers for keyboard and touch pad, if you still have the drivers cd on hand look for these two important drivers, since you have the new xp installed all drivers have been erased.
hope this helps
Nov 19, 2009 | Acer Aspire 3000 Notebook
Feb 04, 2009 | Acer TravelMate 2300 Notebook
Acer Aspire 3304WLMi keypad and mousepad not working
if you take a hard look at your laptop you'll probably find a key that to disable keyboard that with fn will do it
what type of laptop and model
also check in control panel mouse then device settings see if you disabled in there
Feb 01, 2009 | Acer Aspire 3000 Notebook
Computer freezes on start-up
whenever your doing a cd recovery you need to remove the battery
use ac power
if its still freezing up you'll have to run windows again
Windows uses a lot of power to install
Jan 09, 2009 | Acer Aspire 3000 Notebook
Aspire 3000 Keyboard Lag
Try running an Antivirus and Antispyware application.
One of your other programs is interfering. (as it disappeared in safe mode)
Try deleting things out of the Startup in the Start button menu.
Mar 12, 2008 | Acer Aspire 3000 Notebook
Frozen keyboard acer 5100
for aspire 3050, try to remove the battery, battery can cause many strange thing.
if you still got problem after removing battery, it's look like motherboard need repair.
Mar 02, 2008 | Acer Aspire 3000 Notebook
GaryC
Mar 15, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5670 Notebook Logo
5,744 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
