Question about Sony Playstation 3 (PS3) Console
What wires plug in where for wired internet does it hook up to the router
  • 583 Answers
You'll need a CAT-5 (or CAT-6) ethernet wire plugged into the ethernet port on the back of your PS3 with the other end plugged into one of the ethernet ports on your router (assuming your router has multiple ethernet ports). These ports will usually be labeled 1,2,3.. etc. Do not connect to the LAN or WAN ports on the router. If your router only has one port, you'll need to get an inexpensive ethernet switch to connect to the LAN port of the router and all of your computers, PS3 and other ethernet peripherals to the switch.
Posted on Feb 01, 2010
I can only get it to work with a wire,the box says its wireless.dlink233OL
If you are talking about the wire that comes from your modem to your dlink2330L, yes you have to have it hooked up via wire. Then your wireless "wifi" capable devices connect the the internet wirelessly through the modem. If you are talking about having to hook up a wire from the router to a computer to get the computer to get on the internet, that computer may not have a "wifi" device built into it. If the later is the case you can buy small "wifi" devices (like a "Bear Extender) that plug into your usb port to make them wireless.
Sep 26, 2016 | Computers & Internet
How to hook up the internet
The Internet cable wire is the same on each side, so plug your wire in the wii, which the inlet looks like a square. Then plug the other end into your router.
Jul 28, 2011 | Nintendo Wii Console
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to...
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Dec 29, 2010 | Linksys : WRT54GS Wireless-G Router W/...
Hooking up a Linksys dual range router to a 2 Wire cable modem
ok once your internet is resolved you shouldnt need to have any computer hard wired to the router but it should go like this cable from your wall to the modem, then cable from modem to the router, after that you can go wireless all the way just make sure that its all secure and encrypted dont want the next door neighbor stealin your internet
Feb 25, 2009 | Linksys Ultra RangePlus Wireless Routr...
I have no computer or cable and need to set up internet on my PS3
??? A router will NOT replace your modem; the router won't work without the modem. If you're going to give advice, please make sure it is somewhat correct.
Okay. So first you need the telephone cord to go from the phone jack into the DSL port on your modem. Then you need the Ethernet cable that came with your modem (looks like a phone cord but much bigger) to go from the ethernet port in the back of the modem into the wan or internet port on the router. Verify that the DSL and internet lights are on on the modem.
For the rest of the setup, watch this . It will walk you step by step in connecting your PS3 to the wireless internet. Thanks and please take a moment to rate as fixya.
Feb 04, 2009 | Sony Playstation 3 (PS3) Console
I have a cable modem. from the cable modem I go to a 5 port hub
That is because most cabel internet providers only gives you one public IP. Please go to a Best Buy, Office Depot, Staples, Walmart, or Targer, and ask for a LinkSys Router. The router will do NAT (Network Address Translation) that will allow more than one PC share the single public IP. This will solve your problem and will cost an estimated $30.00. The router is simple to hook up, just plug the cabel from your modem into the Internet/WAN port on the router. And the two computers into any of the other ports. Be sure to unplug both cable modem and router then plug up the cable modem first, once the ready light is on, plug up the router.
Adam
Nov 15, 2008 | Stratitec 5-Port 10BaseT Ethernet Hub...
Ps3 probems with usb router
Plug the router into the modem provided by your internet service. Then hook up the router to your comupter with a wire. Then go to settings connections on the PS3. then hit find networks. It should find your. Follow the on screen intructions.
Feb 22, 2008 | Sony Playstation 3 (PS3) Console
Lynksys BEFSR41 hookup
To hook up your lynksys router plug your internet connection wire in the back of the router where it says linksys then run another cable from the slot one to your computer, when you first get your router your username and password will be admin type your IP address into your internets browser window and use your username and password to log onto your linksys router, choose your router settings and there you have it,
Good luck
Chris
Feb 19, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
No internet through ports
Try hooking up the PC through the router, then unplugging the modem and plug it back in. Once that is up, do the same to the router and try it again.
Oftentimes if you're limited to one IP address, it will be assigned to your PC, and your router will be unable to get one. Resetting the modem frees the IP address and allows the router to get it.
Feb 14, 2008 | Linksys WRT300N Wireless Router
Sony Playstation 3 (PS3) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
