Question about Echo Garden
Echo leaf blower cuts off after 15 minutes. - Echo Garden
  • 202 Answers
Remove the muffler. Look for a screen in there that may be almost completely plugged with carbon. You can run your blower without that screen if it is clogged.
Posted on Feb 01, 2010
How do I fix a blown gasket on my echo blower?
Leaf Blower Intake Gasket Replacement - Echo ... - YouTube
? 3:01
www.youtube.com/watch?v=XCz7V7rZ3SM
Jul 8, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing the intake gasket on Echo leaf blowers. The most ...
Aug 21, 2015 | Echo Garden
Runs for 7-8 minutes then cuts off
suspect in this order
carb adjustment
then exhaust plugged
then piston damage
then crankshaft seals
then coil
Oct 24, 2013 | Echo Gas Blower 204 MPH765 CFM Blower...
Craftsman weed eater misfires after operating for 15 or more minutes when hot
new spark plug is first option as when hot plug or cil pack will get hot and short out causing misfire will lead to none starter
Jul 28, 2012 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Blower starts and runs for 5 seconds and cuts off. Is it an oil to gas ratio. Is is 32:1 or 40:1? For the Echo PB250 gas blower.
I don't think the oil-gas ratio will cause that problem. Did you check to see if the fuel lines or fuel filter is clogged?
Aug 15, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
My echo pb-201 hand held leaf blower starts and runs for about 2 minutes then begins to sputter and stop. Sometimes I can get it to work for about 4 minutes but then stops.
may be a clogged fuel filter or bad fuel lines check to see if they are real soft if so replace it they are fine the may need a carb kit
Jan 13, 2011 | Echo Garden
I have a Echo leaf blower and I can get it running but then it's cuts off after just a few seconds. It has new plug, air filter and fuel filter. What else could it be?
The carburetor could be dirty and need a good cleaning and you could first remove the fuel pump cover (cover without the vent hole) to the carburetor and look for the small, round, fine-mesh screen. Sometimes it gets covered with dirt and debris and has to be cleaned as it allows the fuel to flow into the metering side of the carburetor.
Dec 04, 2010 | ECHO, Inc. PB-251C Handheld Blower
Brand new echo pb-251 blower, used it 3 times for 5 minutes each time and it worked perfectly, now the fourth time using it the engine starts easy and idles but engine sputters and misses when pressing...
you can thank the EPA for your blower problem the EPA makes all brands of lawn equipent "tamper proof" with plugs and limit caps. not just echo......when we service an echo piece of equipment we let it "break" in and adj the carb as needed BEFORE it leaves my shop. dont hesitate to bring it back to the dealer, if they are reputable, they will do the adj while you wait......hope this helps. good luck
Nov 21, 2009 | ECHO, Inc. PB-251C Handheld Blower
Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
May 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
Oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
Mar 27, 2009 | ECHO, Inc. PB-251C Handheld Blower
Garden Logo
221 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
