Hi, my ideal combi boiler model mini HE C28 goes through the light sequence upto ignition sparking but main burner not lighting. having had the gas valve and ignition sequence pcb relaced, boiler still not working. what next ?
  • Anonymous Mar 30, 2014
    timmer instructions
  • Heating & Co... Master
  • 2,597 Answers
Hi check the flame senser is in postion and clean
Posted on Feb 01, 2010
Heating is not firing up
check burner tubes for clogs and gas valve
Sep 27, 2017 | Water Heaters
I have a halstead finest gold combi when I turn the boiler on the boiler goes into its ignition sequence when it comes to ignite the boiler fires but after the igniter stops the boiler cuts out completely...
Difficult to get too specific without knowing if you have gas or oil. Also, I am going under the assumption you mean the burner shuts down, not the whole heating system. That being said, all heating appliances have whats called a safety curcuit. Each control has the ability to shut down if certain critera are not met. There is a sensor that senses light down the blast tube. If no light is sensed in a predetermined time period, then the sensor cuts power to the burner. This stops delivery of fuel so if it does ignite you wont blow up.
(I suspect that the ignitor and burner shut down simultainously.)
It may be the sensor (cad cell eye) is doing its job, however why is the question. Could be a number of things including the fuel delivery, ignition, improper air adjustment, etc.
No qualified professional should diagnose a problem unless they are in front of the appliance. I recommend you find a licensed qualified heating techician. Hope this helps.
Feb 04, 2013 | Water Heaters
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
Glowworm 24hxi combi boiler fault codes
it's an ignition fault (lockout) failed to light.
cause:
no gas
insufficient gas
incorrect gas valve adjustment
electrode ignition lead defective
electric igniter defective
check air inlet duct
check connections to igniter unit.
most common cause is igniter is defective (looks like a spark plug)
if you can hear a clicking when boiler goes to ignite, then it will be igniter at fault (no spark), check lead going to igniter (for any deterioration, looks like a ht lead). if all ok. change igniter.
hope this helps?
Jan 22, 2012 | Kitchen Ranges
Gas boiler doesnt ignite
Clean the pilot assembly and replace the thermocouple. I suspect that the thermocouple that is installed now is getting tired and is failing. While you do that, clean any debris off the burner(s) and look for any sensors that may need a cleaning as well. You could have a bad connection on the gas valve so check all wire connections for corrosion and clean. Yes the gas valve could be bad not allowing the main burner to ignite but check everything else first.
Oct 20, 2009 | Heating & Cooling
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
Combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Jan 22, 2009 | Whirlpool Aquatic Millennium VII -...
Ideal c24
Hi Jurgie,
I'm Harvey, the Master Plumber,
Happy to render my assistance.
This is your problem!
When you are switching on the boiler it ignites for 8 to 10 seconds, then it cuts off and the lock out lamp comes on. Pressing the reset button or turning on the hot water tap has the same effect.
I need to get the make and model of your specific boiler to give you an accurate answer!
Waiting for your response.
Harvey, your Master Plumber.
Sep 07, 2008 | Bosch 1600P-NG Natural Gas AquaStar...
Heating & Cooling Logo
757 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
