Question about Radio Communications
Output works fine on headset but it fails to detect input (microphone). have checked all interfaced settings on xp. thanks
  • bwblake10 Feb 01, 2010
    this is a dell 800 laptop. pretty old but refuses to die. it is running sigma tel sound card. thanks.
  • bwblake10 Feb 02, 2010
    thanks, but i'd done all that. i found that i needed to update the sigma tel driver, which i did by downloading it from dell.com site. that seemed to fix it.
    bb
  • 3,740 Answers
You will have to go to the device manager and add new hardware for the microphone.
If you don't see it on the HCL (may have a yellow icon) in the device manager then either the Microphone cord / wiring for the head set microphone is broken or the microphone jack on the soundcard is really dirty from not being used and or just plain bad. I don't remember the manufacturer of the headset I once had (now trash) but, it would work with windows 3.1 yet not with Win98 or XP. That too is a possibility depending on whether there is an internal amp in the head seat that requires a software driver for microphone.
I have dealt with several OEM on the Motherboard sound cards and plug in sound cards that have had dirty jacks from air passing through the CPU tower from regular use over an extended time. Try using a small piece of cloth and the broken off end of a toothpick to clean the microphone jack. DO NOT use tissue as it will tear and get stuck in the jack. Sure hope you get it sorted out.
Posted on Feb 02, 2010
    President:
  • 2,923 Answers
First, make sure that the mic input connected is properly seated to the microphone jack.
Next, go to the Control Panel > Sounds and Audio Devices > Audio tab > make sure that the sound card is selected under the "Sound Recording"
If it's selected, go to the "Volume" tab > click "Advance" button > then it "Options" > Properties > check "Mic Volume" > OK
Then go back to the Audio tab > click the Volume button under the 'Sound Recodring' then adjust the volume for mic.
If that did not help, try connecting the headset into another working computer to isolate the problem.
If same problem occur, the the mic connector cable could be defective. Replacing the cable should not costs you too much.
Good luck and good evening!
    President:
  • 846 Answers
Two things come to mind
First, you need to ensure that the driver for your sound card is up to date. If it is not, that could be causing the microphone jack to not function. If you post the make and model of your desktop I can direct you to the latest drivers for your sound.
Second, you mentioned that you checked all interfaced settings. Does that include all settings on the program your trying to use the mic with in the first place along with all the settings in windows ?
Post back and let me know the status of said problem. I will be sure to assist you further to solve your problem. Thank you for choosing Fixya!
Posted on Feb 01, 2010
When i install application or games on my sony ericsson aino it display operation failed, how can i fix this?
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 4410
Jul 10, 2013 | Audio Players & Recorders
How can I fix my Dynex Microphone
Plug the USB connector into another available USB port.
• Check your computer's volume level.
• Check if your computer's volume is muted.
• Check your operating system's audio input and output settings.
• Check the headset's volume and mute settings.
• Restart computer.
If these don't resolve your issue, I would recommend pursuing replacement options.
Feb 27, 2013 | Dynex Mono USB Headset with...
Whenever i tried calling someone and talking then i try to turn on my headset to talk to them from it it doesnt work
. Open up your control panel and double click on audio device properties. There you'll find your device settings for sound , audio , input and output device settings . You will select your headset for your audio and microphone properties . Also , follow the instructions to set up your microphone input levels .
Apr 28, 2011 | Radio Communications
Activate mikrophone on ps3
•Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
•Set the "Microphone Level" to 4. You can change the level any time if needed.
•Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
•Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
•Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
•Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works. I will add info on that as it comes in.
In Game XMB:
•All of the functions in Audio Device Settings are available when using the XMB via the PS button during a game. You can set the input/output, mic level, and device. You can test your mic, and pair a new BT headset while in game.
For more help you can try these links:
•Video Walkthrough (thanks jonny k)- http://www.youtube.com/watch?v=8tSItLGLsX8
•Playstation 3 Users Guide- http://manuals.playstation.net/document/en/ps3/current/index.html
•Step by step picture giude (Thanks kman79)
3. Troubleshooting
General:
If you are having trouble with a headset after it is paired with the PS3, there are a few things to check first:
•Make sure your headset battery is charged and working. Be aware that some brands/models will need to be paired again after each recharge. It's not a problem, it's just the way those models work.
•Make sure your controller is charged. Lots of strange things happen when the controllers don't have enough power, like dropouts and headset interference.
•The headset should be set as the input/output device from the XMB.
•For Bluetooth users, make sure there are no other Bluetooth devices in use near your PS3. Also try to eliminate any other radio frequency interference if possible.
•For USB users, make sure the connection is secure and there are no wire breaks.
•Update your console to the current available firmware
Jun 12, 2010 | Sony Playstation 3 (PS3) Console
Trying to hook my bluetooth headset to my playstation three what do i need to do
Bluetooth Headset Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
Make sure your Bluetooth headset is fully charged before you begin.
Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
Set the "Microphone Level" to 3. You can change the level any time if needed.
In Game XMB:
Feb 06, 2010 | Samsung WEP460 Bluetooth Headset
A135 Series on XP Microphone Wont Detect Sound
your laptop might have the microphone listed but it might just be a port to plug one in.thats the way mine is.
Aug 09, 2009 | Toshiba Satellite A135-S4527 Notebook
My brand new Cyber Acoustics HS-600 headset microphone won't work with AIM
Hi Bob,
The first thing to check is that nothing is muted/turned down low in the Volume Control/Mixer. Then you need to go into the audio settings in AIM and select a different Microphone from the list. The one set to default is not the one you need. You'll either have a USB input/output for the headset or 2 jack plugs for input and output. These use different drivers on the computer. So just try using the different drivers from the list, one call at a time, remember to reboot AIM as you try each different one, and that the microphone volume settings are turned up in the AIM programs as well as you Volume Control/Mixer.
Hope this helps you progress
Chris (ziraffa)
Jan 12, 2009 | Cyber Acoustics 3-in-1 Headset/Mic Headset
Microphone on Apple Macbbok 13" 2.4 GHZ,2GB
Check to see if the microphone works on the macintosh side of the computer, chances are it won't, microphone usage on Macintosh computers has been hit and miss, sometimes the microphone needs a pre-amp or USB interface like a Griffin iMic adapter.
Oct 23, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Using Motorola Blue Tooth with PS3
Yes you can. Just go to accessories or audio device settings. Have your headset on and hit connect bluetooth device. The key it asks for should be 0000. If that doesn't work do a quick search online and you should be able to find one that works.
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Mic problems: playback works great through interface, microphone isn't being detected
Check in contraol Panel under sounds and audio devices that you are using the Edirol and not an on board sound. It sounds like although the cards installed its not selected as the audio device to record from. You will also have to tel Adobce audition to select the Edirol as you audio card of choice as it to can be changed to select input from other sound devices.
Mar 31, 2007 | Edirol UA-25 External Sound System
Radio Communications Logo
49 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
