Question about NorStar T7316E Corded Phone
Only want phone to ring when A call gets transferred
My manager doesn't want his phone to ring unless if I notify him by the intercom. What settings do I need to change. Thanks!
  • jfarrar317 Feb 01, 2010
    The link provided did not have what I was looking for.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 153 Answers
You can find the manual at this link:
http://tiny.cc/U9dCP
Posted on Feb 01, 2010
How can i transfer calls from one phone to another?
First make sure you give each phone an ID on your system. You do this by going into the menu and go to phone options then scroll down to phone ID then press the intercom station button you want assigned for this phone. To transfer call: With caller on the line just press transfer then the intercom station button of the room (intercom station) you want it transferred to. If it is not answered in 45 seconds the extension stops ringing and call is placed on hold
Dec 06, 2010 | RCA 25414RE3A - - Phone
Hello.. We have the parter-18D phone system. one of the phone rings when there is an incoming call, but it shouldn't, since this is not the main phone Ext 10. How can I program this phone to ring only...
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
May 06, 2010 | Lucent PARTNER18 Corded Phone
When I try to transfer a call, the call only rings on my own intercom button. How do I get it to actaully transfer to a different extension?
Make sure you do NOT place the call on hold before doing a transfer. While on the phone, press transfer then the extension, once done simply set the receiver down and it will transfer. If the person at the other extension does not answer and you have no voicemail system, it should ring your extension back.
May 04, 2010 | Avaya 700340193 Corded Phone
Want to turn the ringer off unless receiving a transfer.
This feature determines how each outside line or pool assigned to an extension rings. You can specify Immediate Ring, Delayed Ring (telephone rings after a 20-second delay), or No Ring. Delayed Ring is useful for backup coverage on shared lines or pools, such as for secretaries who cover each other’s lines. No Ring is useful for all extensions except 10 when an operator answers all calls, or for telephones with no regular users, such as those in conference rooms. To change the way outside lines or pools ring at an extension:
To change the way outside lines or pools ring at an extension: 1 Press "Feature" , "00", "System Program ", "Central Tel Program" at extension 10 or 11.
2 Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons show the current Line Ringing settings for all lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green light next to that button is off.) The following ringing options can be shown by the green light next to the line or pool button: • Immediate Ring — on steady • Delayed Ring — flashes slowly • No Ring — flutters quickly • Immediate Ring is the factory setting for lines; No Ring is the factory setting for pools.
3 Press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
4 Continue programming, or exit programming mode.
Aug 06, 2009 | AT&T Lucent MLS-12D Phone
Phone not ringing
This feature has to be enabled on extension 10 or 11
Press Feature 00, left intercom, left intercom, right intercom
enter your extension number
press line button until it is in the solid state and display say immidiate.
Press Feature 00 to exit programming.
Cheers
Jul 09, 2009 | AT&T Lucent MLS-12D Phone
I only want my Panasonic KX-T7453 desk phone to ring when, . . .
press the mode button 5 times and then use the jog dial to get the * down to nothing.
your phone should no longer ring.
Jun 11, 2009 | Panasonic KX-T7453 Corded Phone
No ringing sound for second incoming call
On the intercom, if it's a TA or similar phone system, dial 7311# for call waiting on outside lines and 7321# for call waiting on the intercom. (0 cancels).
Carl
May 21, 2009 | Panasonic KX-TS3282W Corded Phone
Phone ringing.
On extension 10 or 11 press Feature 00
Left intercom, left intercom, right intercom
Enter your extension number
Press line buttons until its a fast blink and display say no ring
Feature 00
only transfered calls will ring
Nov 21, 2008 | AT&T Partner 18 Phone (315805B)
Transfer a call
I put it on hold, then use the intercom to notify another station to pick it up.
Jan 04, 2008 | RCA 25202RE3 Corded Phone
NorStar T7316E Corded Phone Logo
103 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
