Question about Lexmark X2500 All-In-One Printer
When I turn on my Lexmark x2500 the scanner bar moves away and then back to home...then a clicking starts and wont start. I pulled glass out so I could clean it and had to disconnect wires.
  • gage_christi Feb 11, 2010
    Thank you...I will try that.
  • Official Brand Answer
  • 3,344 Answers
Hello, Maybe there is something stuck in the paper feeder roller gear causing it to grind and make that clicking noise.
Posted on Feb 10, 2010
2 Suggested Answers
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Lexmark X2500, broke glass, got new glass from
    Well I believe this printer does not have a home position sensor. Which makes me think that the scanner bar is either out of position or damaged.
    Posted on Jan 25, 2010
    A got a new comper amd with widows 7 I can't get my Lexmar 2500 Ser # B-02143140771. What am I doing wrong?
    It could be a printer driver issue. Try to uninstall any existing Lexmark X2500 driver from your computer first. Go to Start menu > All Programs > Lexmark 2500 Series Printer > Tools > Uninstall. Reboot pc when prompted.
    When pc turns on, check if your Windows 7 is running on 32-bit or 64-bit system type. Go to Start menu > right-click on Computer > Properties. Take note of the System Type.
    Use the links below to download and install the Lexmark X2500 driver on your pc: - X2500 Driver for Microsoft Windows 7
    - X2500 Driver for Microsoft Windows 7 x64
    Jun 15, 2011 | Lexmark X2500 All-In-One Printer
    Use of Scanner
    On this model there is a SCAN in black and white or color buttons but you need to have something on the glass to scan. Once it scans it prints!!!
    Now lexmark software if installed comes with a program to scan with. you need to check under your prgrams folder under lexmark for the scanning software that was installed with the print driver.
    If you open the lid and you do not see the white light chances are your scanner has and needs a bulb inside and at the point to install one of these you might want to concider a new printer.
    Please be considerate and leave your feedback and comments and ratings before you leave, Thanks
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
    Apr 30, 2010 | Lexmark X2500 All-In-One Printer
    Lexmark X2500, broke glass, got new glass from different lexmark. Scanner bar can't find "home". How do I mark glass for home ?
    Jan 25, 2010 | Lexmark X2500 All-In-One Printer
    Does the lexmark x2500 need a special type of ink?
    If you go into the office supplies store, there's usually a guidebook for each manufacturer of printer, and what cartridges it takes. Otherwise, you can look on the sides of the packages, and there will be a listing of the makes of printers it will work with. If you hadn't thrown it out, an ink cartridge recycling service would take the cartridge and replace it with a refilled one, with a discount in exchange for the empty.
    Oct 22, 2009 | Lexmark X2500 All-In-One Printer
    Lexmark 2500 printer jam. How do I open hte back access panel
    Pull it out with a pair of tweezers and then
    clean the rollers from where the paper goes in.
    clean the carriage rod(metallic rod along which cartridges move)with alcohol.
    If this does not work that means that your pick assembly of your printer is dyiing
    May 29, 2009 | Lexmark X2500 All-In-One Printer
    Lexmark x4690 scanner jam
    Perform a hardware test, instructions on how to do so at http://support.lexmark.com , find your printer model, and then click the how to's tab.
    If no solution is found or you cannot print the page call 1-800-332-4120
    Mon - Fri: 8 am - 11 pm & Sat: 10 am - 7 pm for lexmark technical support.
    Apr 24, 2009 | Dell 924 All-in-One InkJet Printer
    System error L1-00
    the L1-00 indicate the scanner carriage is not moving. Something is stopping it. Open the document feeder and turn the copier on while watching the scan carriage (beneath the main glass) - does it move or try to move ? does it make a noise?
    If it seems to be moving freely for a bit and then stop - is it going back to its "home" position (starting point). Remove the main glass and then move the scan carriage by hand (with the copier turned off) .. does the carriage move ok? check for a loose carriage drive wire or debris or something broken. Make sure the carriage locking screw is not holding it. Then turn the copier back on and see if the carriage makes an attempt to move back to its starting point. if everything seems to be moving ok then the problem could ly with the "home position" sensor. It could also possibly be a bad drive motor.
    Apr 03, 2009 | Sharp AL-1655CS Copier
    Scanner bar seems jammed, printer shows busy, all docs cancelled
    Open the printer and pull paper. It might come in pieces then shut down printer to reboot it and that should make the symbol go away and youshould be able to start over. At least when I had a problem thats what fixed it. Hope it helps
    Jan 17, 2009 | HP OfficeJet 7410 All-In-One InkJet...
    SCANER,PRINTER,COPYER
    Saving a scanned image on the computer
    1 Load an original document facedown on the scanner glass.
    2 Close the top cover.
    3 From the desktop, double-click the Lexmark Imaging Studio icon.
    4 Click Scan.
    5 Select the Photo, Several Photos, or Document option.
    6 Click Start.
    7 From the Save or Edit screen menu bar, click Save.
    8 To save to another folder, click Browse, and select a folder. Click OK.
    9 To rename the file, enter the name in the File Name area. To assign the name as a prefix to all of your photos,
    select the “Start all photos with File Name” check box.
    10 To save the photo as another file type, select the file type from the File Type drop-down list.
    11 To select a date for the photo, click the drop-down list, and select a date from the calendar.
    12 Click Save.
    Jan 22, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark X2500 All-In-One Printer Logo
    135 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
