Question about Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725
There is frost in the freezer. I thought it was frostless.
    Scholar:
  • 150 Answers
If you live in a humid environment its the water vapor in the air that is turning to frost in your freezer. Every time you open the door you are exchanging the cold dry air in your freezer for the humid air on the outside, and when you shut the door closed its this humid air that turns to frost inside the freezer. If its building up frost faster than normal you might have a door gasket that is leaking the cold air outside thus letting the humid air in, which is turning to frost. Check that your door is aligned properly and that the gasket is secure on the freezer door.
Hope this helps explain it.
Posted on Mar 24, 2010
I have. Beko frost free freezer at the back of our garage. For some reason it is triggering the rcd. Any thoughts!
Check door seals for folds or dropping door sound like a air leak normaly you will see frost build up right were problem is
Jan 30, 2017 | Frost Freezers
Ffu20fc4cwo won't freeze food
Check power to and from the thermostat first
Sep 13, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
MY FREZER HAS FROST AROUND THE DOOR AND MOLD IS GROWING AROUND IT
You need to replace the door gasket. It's leaking air causing the frost.
May 04, 2011 | Whirlpool Freezers
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
The kenmore 20 frostless deep freezer is cold in the lower section of the freezer but the upper half is warm the setting is maxed out. the air that is blowing across the coil appears to be warm. that leads...
The evaporator coil must be lightly frosted from the top to bottom. This proves that all of the r-134a freon is still present in the system. If you visiblely see that it is not (half frosted the other half warm?no frost) then this is a sign that the r-134a freon has leaked out. Another way to determine for sure is to use refrigeration gauges to check the pressure.
let me know what you found then we can take it from there... hope this was helpful
Apr 05, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Loud shreaking sound coming from Kenmore Frost Freezer.
The fan behind the molding is hitting some ice build up and causing the sound. Sounds like the timer for the defrost isn't working. Try to turn off the unit for few hours or take off the molding in the freezer compartment and remove the ice build up with hair dryer.
Nov 23, 2008 | Kenmore Freezers
Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725 Logo
221 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
