Question about HP Office Equipment & Supplies
Tri-color cartridge problem - HP Office Equipment & Supplies
    Brigadier General:
  • 3,917 Answers
You can only refill 3 times maximum before the print head dies. If it's your first refill, then you probably have air in the cartridge which will prevent the printer from functioning properly.
Check the bellow link to know how to refill empty cartridges properly.
http://www.bs-print.co.uk/hp-338-refilling-instructions.asp
Thanks for contacting fixya.com
Posted on Feb 01, 2010
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
Bluish color to copied photos
Replace color cartridge:Reason: Color cartridge carries three color for color combination, in that any one of color empty or dried up color combination wont happen perfectly, result printer get mismatch colors.. In your case it might be magenta color over.. replace color cartridge to get good print outs..
Jan 31, 2012 | HP LaserJet 3050 All-In-One Printer
I have installed a new black and color cartridge and still I have a color cartridge replace error message. What do i do?
Your color cartridge may need some cleaning. Remove the color cartridge from your printer. Then close the printer cover. Use a moistened soft cloth and gently wipe the cartridge nozzles to clean the dirts and clogs. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the color cartridge and make sure it's properly inserted and secured in the cartridge carrier. Try to print again. If error continues, try to insert a different known working color cartridge to determine if the other is faulty.
Source: How to Clean the Print Cartridge Nozzles and Contacts Manually
May 09, 2011 | Lexmark X2600 InkJet Printer
HP Deskjet 5550 quit printing red color. Installed new color cartridge HP57. Quit printing red again after 5 pages. Is it a printer problem or cartridge problem?
Have you check your color cartridge if they are properly installed.
Make sure your are not using a refill cartridge.
Replace your tri-color cartridge with original an HP tri-color cartridge.
Aug 26, 2010 | HP DeskJet 5550 InkJet Printer
Message says problem with tri color cartridge
I don't think the date on the cartridge is the problem. It might be the electronic on your color cartridge. If there is an orange light flashing and the printer won't pull the paper to print, in 99%, the problem is one of the cartridges. Try removing the color cartridge and gently wipe out the electronic with a dry cloth. Put it back in and try to print. If that doesn't help, try removing the color cartridge and print (I am not sure if that will work, because all in one printers usually need both cartridges in order to print, but you can try that too). You can also try scanning something and see what the message on the printers display tells you. If there is an E an the color button is blinking, I think you should replace your color cartridge.
Apr 04, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Why are only black and yellow printing?
The printer has two ink-cartridges: black and tri-color.
The black cartridge has ink left.
The tri-color cartridge has run out of 2 of the 3 colours of ink.
Buy a replacement tri-color cartridge,
and responsibly recycle the "empty" cartridge.
Nov 19, 2009 | Canon i9100 InkJet Photo Printer
My printer doesn't not recognize that I just put in a new color cartridge
hi,
try to remove the new color cartridge, if you have a clean cloth, try to wipe to copper strip of the new cartridge. try to wipe the copper strip of the carrier where you put the color cartridge, BUT before doing that make sure that the printer's power cable is unplugged.
place the power cable after wiping the copper strip of the color cartridge carrier. then place the color cartridge. if still same. try the old cartridge. if the old one is recognized, it's your new cartridge fault. you need to contact dell to have the cartridge replaced. if you ordered it from dell.
Sep 30, 2009 | Dell 922 All-In-One InkJet Printer
Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Jun 17, 2009 | Dell 926 All-In-One InkJet Printer
"color cartridge missing"
Try cleaning the contacts on both the color ink cartridge and the carriage with a cotton swab dipped in alcohol. It nothing works, the color ink cartridge is likely faulty.
Apr 01, 2009 | Lexmark X6170 All-In-One InkJet Printer
Color cartridge wont print
The color cartridge is defective. Sometimes, when the printer detects a refilled cartridge, it "marks" the cartridge as defective hence the refilled cartridge will not work on any printer.
Jul 21, 2008 | HP PSC 750 All-In-One InkJet Printer
19 people viewed this question
Seeker5211
Seeker5211
