Just bought Hitachi L19D01UB lcd tv. When I switch power on tv goes to Software Uart Upgrade Application menu whch i am unable to exit. Cannot set up tv using menu button on remote stuck on the Software Uart Upgrade screen.
  • awccameron Feb 01, 2010
    Thank you for reply. Have tried turning off for 10 minutes but still return to same Software Uart Upgrade screen. I had look at hitachi site and cannot see how to update firmware. Will return to store tomorrow. Thanks again
    Thanks for quick reply. Tried the solution/advice did not solve but much appreciated assistance.
  • 443 Answers
I recommend to install the firmware update, then you can proceed through
the initial set up.
If that doesn't work, go to Hitachi's web site and follow directions for your model of TV for the firmware upgrade.
Also try disconnecting the power from the TV for at least 10 minutes, then reconnect power and try again.
Good luck !
Posted on Feb 01, 2010
We bought a hitachi 50hxt 16u tv and are unable
tried to replace the HDMI cable then set the right source.check also your box which not working.
Nov 02, 2013 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Tip
Hitachi 22HXJ06U stanby LED flashing red and blue.
Recently first thing in the morning I've found my tv power on / standby LED is flashing red and blue. The tv does not seem to respond to the remote...but after pressing remote on key the tv will eventually come on about 3 to 5 minutes afterwards. It would seem that the tv does an auto update during the early hours and then on next switch on it completes the update...during which time it seems that it has not turned on. To prevent this annoying behaviour you can disable the automatic software updates in the settings menu... see pdf user manual at https//estadoc.hitachi.eu/servlet/FileViewer?DocumentName=22%20IB.pdf see page 23 about software upgrade. In the settings options you can disable the auto upgrade. Occasoinally I expect it would be advisable to either enable the auto update for a day or two or do manual update.
on May 02, 2015 | Televison & Video
Tip
Samsung rest code Service codes Samsung: E900...
samsung rest code Service codes Samsung:
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes "Chinese" models:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
Service codes BenQ:
software version: *#300#
test mode: *#302*20040615#
Service codes Pantech:
software version: *01763*79837#
service menu: *01763*476#
reset defaults (phone/user code reset to default): *01763*737381#
Service codes VK-Mobile 3xx, 5xx:
software version: *#79#
software version: *#837#
service menu: *#85*364# (hold #)
Service codes VK200, VK2000, VK2010, VK2020, VK4000:
service menu: *#9998*8336# (hold #)
reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
on Feb 09, 2008 | Samsung SGH-E900 Cellular Phone
MY LG 20LS7D TV WILL NOT TURN ON, SCREEN IS SHOWING MESSAGE: TV SOFTWARE UPGRADE UART DOWNLOAD 1. CONNECT CABLE 2. START '1K XMODEM' IN HYPERTERMINAL
You have lost your original remote and got into this by pressing info select and the option 7 UART Download. Happened to my 95 year old aunt in assisted living. You will need the original remote and simply hit (EXIT) or another LG branded remote that has the (ROUND RETURN BUTTON) on the left. Once you accidently get in to this, I have not found a universal Zenith remote that can get you out even though Channel up/down and basic funtions work.Bud retired Bud's TV Service.
Dec 11, 2010 | LG 22" FLATRON LCD Monitor
My Phillips Plasma tv MENU pops up unasked and obscures screen.
there is a soft ware upgrade for that problem on there web site you can down load it to a thumb drive and upgrade your set
Oct 31, 2009 | Philips 32PF7320A 32 in. LCD Television
Mitsubishi VS-5003R TV is on but won't connect to cable.
this is the service menu , try to exit out of it , if you can't turn off power on both cable box and tv then unplug both of them and disconnect the cable from the tv , leave it unplugged for at least 10 min , then try it again , if it still does it then the crystal that is connected to the IR sensor and EEPROM IC needs to be replaced as the IR sensor should be also replaced
hope it comes out of that!, if not we can try to set the menu settings for it being like a clock and #1 on the remote to exit the menu
let me know what happens , thanks,
electech
Oct 21, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
China mobile is not detected by pc
You need to install the software for that particular mobile so that your system detects the mobile. For eg. to work on a nokia mobile with your system you need to install the nokia pcsuite software...similarly u need to install the software for your china mobile
Feb 18, 2008 | Computers & Internet
Unable to exit TV's menu
Try to replace the remote sensor board inside the bottom of your tv. If that won't work, you need to replace the Small Signal Board (SSD Assy) of your tv.
Nov 24, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Cannot exit the TV's menu screen
So I just called Philips about this problem. Our TV was doing the same thing, she said it was a problem with the software in the tv and you need to update it.
Go to www.p4c.philips.com
enter your product number for the tv
go to product support
then software and drivers and then click on the link and follow the directions.
Your going to have to download it onto an usb and plug it into the tv.
And if that doesnt make any sense I apologize I dont really know what Im talking about Im just repeating what she said.
Lets all hope it works!!!
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
