Question about Whirlpool AWM5125/1 Front Load Washer
Switchs on but it seems as if door is open as when you select a program it turns the dial slightly anti clock wise then stops but works on drain program?
  • 41 Answers
Replace the door interlock switch and / or programme timer
Posted on Jun 12, 2010
I have a zanussi 1600 aquacycle. We had a power cut then the machine wouldn't empty so I emptied it manually and now the door won't lock to start any programmes. Any suggestions??
turm the power off
then press in the two buttons on the left hand side while pressing them turn power back on turn selector to one oclock{if you have buttons to select programs press it } you should see the lights come on and move to different programs this is a test program to take it off test turn to off then turn anti clock wise
Feb 03, 2015 | Zanussi Washing Machines
Where is the drain pump
Bottom left of front of Miele 310 is a door, opened using the Orange tool sitting behind front of soap draw, lever it open using the tool to reveal the large white tap - see photo - turn this anti-clock wise to remove. Clean it thoroughly, including the internal section of all debris and soap residue. Replace carefully and turn machine back on. The orange tab in photo is the manual door opening- pull down on this to open door, noting that if it is full of water the water will run out onto floor! drain-pump-vpsnhtzoq0zuct4mvmfypioi-2-2.jpg
May 10, 2014 | Miele W310 Front Load Washer
Washer not agitating,spining,motor turns but will not turn belt,the belt gets hot an melts.Replaced belt,lid switch works ok, I can manually turn agitator in clock wise direction but not counter clock...
Need model number! Do a google search for a manual (just search by model number). Repair parts and some troubleshooting help at: http://www.repairclinic.com/
Jan 16, 2014 | Washing Machines
Matsui mf160 beeping then stops and wont select programme
I had the same problem today. The good news is I fixed it without replacing any parts. I tried a few things which may have worked so I will list them all. I'm not sure which one worked so try the easy ones first.
Fill the salt and rinse aid depensers up.
Once it starts beeping continously close the door and let it drain itself. Do this several times. Turn it off and leave it for a minute between goes. With the power button light on leave the door open slightly for about 15minutes, mine beeped after about 7 minutes and it had reset itself.
At the bottom of the dishwasher underneath there is an anti flood switch. My tray had water in it and caused the float to rise up and activate the switch which stops it from working. Easiest way to drain it is to pull the dishwasher out put down a load of towels and tip it backwards until all the water is gone. I found it easier to check for water through the right handside side panel, it comes off pretty handy. I also removed the upper front cover to check the door catch switch. Just make sure its not broken and not wore down etc. I also sprayed it lightly with WD40. Try disconnecting the wated inlet pipe at the back once you have turned the water off. Mine had a lot of pressure in it which it should probably should have but read somewhere else it solved their issue. I then stripped both sides off laid the machine on its back, make sure to disconnect the water inlet pipe and took apart the drain pump. If your looking at the back its on the right hand side, mine was dark grey and was attached by two screws to the side panel. There is 4 or 5 screws which hold the drain pump together. Unscrew these and again there will be a build up of pressure and water released. There might be a foreign object stuck in here which will stop the blades turning. Check the espares youtube channel on how to remove this, thats what I did. After all this mine didnt work straight away and I had given up. But I left the power on with the door open slightly and after 7 minutes it beeped and I was able to select a program as normal. Maybe the turning over on its back and release did the trick Im not sure but give it a go. Good luck
Jan 18, 2013 | Dishwashers
Central locking
turn key twice when opening, ie turn right. once drivers door will unlock, turn twice passengers doors will unlock, and locking is turn anti clock wise once will lock all doors, turn twice will set door dead locks.dead locks will stop openand lock internal button working and handle from opening door. the same actions can be applied to the remote one press drivers door, two press passenger doors, press and hold unlock button for 5 seconds and rear window will open.
Apr 23, 2010 | 2003 Land Rover Freelander
Sentry safe model 1330. i turned the dial anti clockwise 3 times, then clockwise to the No 55, then anti clock - 90, then clock - 28, then pulled the handle down. it only goes half way down and will not...
A Locksmith would say If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking sentry safe open.
Feb 05, 2010 | Sentry Fireproof Safe
Homark dishwasher programs; ( Italian ?? )
just turn the timer around slowly and you will hear it start to drain
Dec 11, 2009 | Dishwashers
How do you clean pump on whirlpool. 6th sense
Hi
On the bottom right corner of the machine you will have a drain filter.
Flip open the door. It opens vertically from top down.
Please note if your pump is blocked there will be water in the machine which has not drained out. When you twist open the filter anti-clock wise, all the water will gush out. Be prepared for this with towls and mopps. Also open the filter dial, slightly at first and only allow the water to trickle out at first. Once the water is all out, open and pull out the filter. Clean out the flilter and the cavity. Look into the cavity with a torch and make sure everything is clear.
Put back the filter.
Start your machine on the "Drain" cycle only. Check to see if you can hear the water pump working. If there is no noise, then the pump needs further investigation. It may even be faulty.
Oct 26, 2009 | Fisher and Paykel Washing Machines
Whirlpool AWM5125/1 Front Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
