Question about Bosch 24 in. SGV53E03 Built-In Dishwasher
My Bosch interated dishwasher sounds like its trying to drain but wont stop. even when you open the door the pump keeps going as if its trying to drain......
  • 268 Answers
Water is in the very base of the dishwasher.This is not the tank where the dishes go. Something could have leaked in the pump area or water overflowed to cause this. Drain pump is running because a float-type device has been tripped by the standing water, so it automatically stays on drain to avoid a flood. Only way to dry out base is to uninstall dishwasher and tilt it forward and let water out. If probelm recurs after running then you will need a tech to repair it as it is not something you can do.
I hope this helps.
Posted on Feb 01, 2010
SHE44 pump keeps trying to empty but there isn't any water
she44-pump-keeps-trying-empty-but-isnt-3dor230cw2fd2t5j4bvk0sa4-4-1.jpg Hello. First, when looking up info on your model, I came across this recall on the SHE44C unit. Check your model number and serial number to verify if your unit falls into the recall range. (fire hazard)
Next, study the schematic diagram for your unit--the drain pump is connected directly to the main board--the fact that it's running even with the door open suggests that the main board might have a stuck relay and will have to be replaced if that is the case. The part number is 444813. The drain motor (see close-up, pic 4, is designated M3) has one side wired to the board, the other side goes through the on/off switch to incoming power, (see pic 3, lower right corner). I hope this helps you!
Sep 26, 2015 | Bosch Dishwashers
I have a Bosch SHV46C03UC dishwasher. my drain motor/pump will not shut off, even when door is open...Any suggestions on how to trouble shoot?
sounds like a circuit break on the main board,and are you saying when the door is opened?.that alone suggests the main circuit board needs repaired or replaced my advice switch of the machine and call an engineer.,Adrian.....
Jan 27, 2015 | Bosch Dishwashers
My bosch shx46a05UC/14 will not shut off. I can open the door and the dishwasher just keeps going?
Are you please able to confirm what exactly is happening when you mention "dishwasher just keeps going".
Is it in a wash cycle and throwing the water around through the wash arms or do you just hear a pump running with water sitting in the base. Most likely there is a leak into the base and the auto stop circuit is trying to empty the dishwasher by running the drain pump. I would suggest you check the base of dishwasher for leaks.
Jan 28, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Bosch dishwasher not completing its cycle
Sounds to me like you have a problem with with the overflow switch or float. To access the switch or float you must pull d/w out and remove the left side panel(as you face the d/w).
Mar 29, 2010 | Bosch Dishwashers
The dishwasher wont turn off. It does a wash cycle but keeps running...help
you have a leak and it is activating anti flood device this switches on the drain pump to stop it flooding your kitchen if the pump keeps running even with the door open thats what it will be,will need inspection by service to trace leak.
Feb 11, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My dish washer won't stop trying to drain
my dishwasher would fill up and start draining when washing watt should i do
Nov 24, 2008 | Bosch SHU9925UC Built-in Dishwasher
Dishwater won't stop trying to drain even when door is opened
The drain valve is stuck open. This is electrically operated, but may have some debris inhibiting movement. If you can physically move it (with the power off) this should repair the problem.
Apr 21, 2008 | Bosch SHU9925UC Built-in Dishwasher
Bosch dishwasher is permanently draining even when the door is open. The draining usually does not stop, but on the occasions it does the wash cycle only last a few minutes before it draining again.
THERE IS A FLOAT WITH A RED SHAFT /LEFT SIDE AS YOU LOOK INTO THE BOTTOM OF MACHINE. AFTER TAKING OFF KICK PLATE. IT IS GOING TO DRAIN IF THERE IS A LEAK FROM PUMP OR HOSES FILLING UP THE PLASTIC BOTTOM OG MACHINE . KEEPS A LEAK FROM GOING ONTO YOUR FLOOR.. . MY GUESS IS YOU HAVE A LEAK DOWNTHERE AND NEED SERVICE.
Feb 27, 2008 | Dishwashers
Bosch SGV43A03 DISHWASHER: pump drains all the time, even if reset!
Typically you could possibly have a leak in the base or sump which activates a little float switch. This in turn switches the drain pump on continuously and deactivates the programing cycle.Sort out the leak.
Feb 24, 2008 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SGV53E03 Built-In Dishwasher Logo
239 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
