Question about Mitsubishi VS-5059 50" Rear Projection Television
The color seems to be out of alignment. Is this an alignment problem or an electronic problem?
  • Mitsubishi Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneerthe color seems to be out of alignment - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
The image seems to bend or convex. The colors are not aligned, red and blue can be aligned but will not merge with green.
This does sound like a convergence problem but the model you listed does not have a convergence circuit.
If you tell me the full model number and brand I can if it is Mitsubishi I have start to finish step by step instructions for this kind of repair in those sets.
To help you more I need the model and brand.
SD TECH
Nov 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
All copies and scanner outputs result in a totally black image
hi,
its could be hardware issue, if you tell me which printer, then we can try some reset on that machine..........
Regards,  raj_p5983
Jan 23, 2009 | HP PhotoSmart C4180 All-in-One Color...
Colors do not match up
Have you tried a few alignments? Also you can try turning the printer on and when you start hearing the alignment turn the printer off ... do this a few times and see if this helps.
Also you can try to manually align the cartridges.. to do this turn the printer off. Open the front cover to reveal the cartridges. On the right hand side you can see some gears. Try to turn one of these slightly.. one click (1mm) should do it. Now turn the printer on and let it align itself
Dec 15, 2008 | HP Color LaserJet 2500Lse Printer
Continually says align print cartridges
My guess is that the color cartridge is either defective or not inserted correctly. I have a 6110 and know that inserting a print cartridge is a little tricky. If it isn't completely inserted and the top latch fastened correctly, the cartridge either won't work or produce errors.
Try reseating the color cartridge so it's inserted in exactly the same way as the black cartridge and run a print job again.
Open the following web page and go to Step three to see the instructions for cleaning the electronic contacts on the cartridge and print carriage.
Ink Cartridge Alignment Fails
Those seem the most likely causes and solutions to me. Good luck.
Oct 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Blue color gun off line
Milt,
What are you referring too when you ay the blue color gun is offline? Is the blue crt not lighting? Or just the convergence alignment off??
Bill
Nov 23, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Colors out of alignment; curved lines
Please stop where you are! Expert technicians rarely align manually = only when CRT changed or someone tries to
correct an electronic anamoly mechanically........
Curved lines are caused by defective IC's = STK392-560....
Found mounted to heatsinks on " G " PCB.........T.
Please rate solution offered and ask for more help, if needed.
Nov 12, 2007 | Sony KP-51WS500 51" Rear Projection...
COLOR LAMP ALIGNMENT
Needs convergence circuit repair...........
Requires replacement of soldered-in parts..............T.
Please rate this solution.......................
Sep 24, 2007 | Sony KP-53HS10 TV
Color guns out of alignment
It sounds to me like the convergence amps themselves have failed. Ic7001 and Ic7002, both are STK392-110 Sanyo built Ic's and not an expensive job for a qualified shop. When shopping around for a shop to repair it ask what they charge for replacement of the convergence amps in this unit. And take the unit to them to save pickup and delivery charges...
Have a great day!
Bill
Dec 21, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
