Question about KitchenAid Dishwashers
We have kitchen aid dishwasher model KUDS01FLBL2. The door now opens too easily as if a spring is no longer in operation. I think I found a part called a door balance spring. Is this something I can fix myself?
    Brigadier General:
  • 3,917 Answers
You need to order pulley assembly; it comes in pairs (both doors). Open the bottom panel, undo the screws on top (exposed only when door opens), slide out the dishwasher from its place (you might have to undo the water and drain fittings depending upon how much slack or lack of it). Unhook the spring from the old pulley. Remove and replace the pulley, hook the spring back and perform the above steps in reverse.
You can check the bellow link to have an in-depth knowledge regarding your issue.
http://www.technicianbrian.com/2009/01/kitchenaid-dishwasher-door-falls-open.html
Thanks for contacting fixya.com
Posted on Feb 01, 2010
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Free Online KITCHENAID DISHWASHER Repair Manual
http://www.diytroubleshooting.com/kitchenaid-dishwasher-troubleshooting
Jul 08, 2015 | KitchenAid Dishwashers
Broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
May 07, 2008 | Dishwashers
This is the second time in 2 years my door to the dishwasher slammed open and hit me in the shins. A spring or something was replaced once ALREADY how do I get this repaired again? I thought buying a...
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Apr 25, 2011 | KitchenAid Dishwashers
Dishwasher won't run. Normal light and cancel light flashing cont
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched.The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate. It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Thank you !!
Jun 18, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchen Aid Model KUDPQ1FLSS5 door counterbalance issue
One of the counter bakance springs OR the adjuster for it let go. I had a similar thing where the adjuster which was a thin metal "T" thing that screwed up into the spring as an adjuster folded and fell out of the spring.
Remove the bottom dress cover at the tope kick of the dishwasher. The springs are all accessable right there. The problem will be obvious. Just compare the two sides.
I had to beef up the "T" adjsuter in mine as it was too weak to continue holding in the spring.
One turns it into more or less coils of the spring to adjust the counterbalance.
Apr 21, 2010 | KitchenAid Dishwashers
Fix door spring how to connect it
door spring broke in kitchen aid dishwasher
Apr 10, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
The door to our Kitchen Aide dishwasher now drops down very quickly and it used to have some control when the door was opened.How difficult is it to repair?
Hi, it is likely a broken door spring, or both. Part number 9743986. You can access them by way of removing the screws in the toe panel below the main door panel. Be sure to shut off the power to the unit. With the toe panel removed you should be able to visually inspect for a broken spring, with the aid of a flashlight ot trouble-light. One hook will connect to the hinge while the other end hooks into the dishwasher frame towards the back. Hope that help's and thanks for visiting fixya. Please take a second and rate the solution provided for here today. Good luck. Macmarkus :)
Dec 25, 2009 | KitchenAid Dishwashers
Sope dispenser will not open when running
Hi
Thanks for using FixYa. Many dishwashers (but not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open.
Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced. Older Kitchen-aid dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) Kitchen-aid dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | KitchenAid Dishwashers
The spring on the door broke. How do we fix it?
get a spring from a kitchen aid parts supplier and relace it
Sep 28, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
54 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
