Black screen on computer monitor
Dell E151FP6 monitor. I managed to reduce the contrast to a totally black screen with the buttons on the front/bottom of the screen. The only button I touched to accomplish that was the contrast button. Now I can't see anything. Except I can touch that contrast button and a bar lights up. It is set at totally minimum contrast. I hit every key and combination of buttons and keys I can imagine might work and got no changes whatsoever. I turned the computer off and on again. I disconnected the monitor and turned it off and back on. I got the test screen which looked OK. I reconnected it to the computer, but no change. I can still pull up the contrast bar but that's it. ANY SUGGESTIONS?
    Sergeant:
  • 206 Answers
Here is the link for the E151FPb monitor manual.
Since you email your question you have access to get this manual and print it. The manual shows the Auto set button, the contrast control button and a monitor reset feature.
Unfortunately you have to do each of these blind. Follow the instruction given, push buttons smartly, wait a few seconds for any action to take place, then follow the next instruction.
Good luck.
Posted on Feb 01, 2010
Testimonial: "THanks. It worked just fine. (PS, yes, I have another computer which I used.)"
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
We have rolled out Dell Optiplex 790 machines running Win XP and using E2210 monitors. Recently networking applied power managment options to power of the monitors in 20 mins of inactivity. The monitor...
Turn off power saving mode in your monitor. In monitor beside orange light there will be a menu button press it and find for power management ok it turn of power management. The problem will be fix.
Sep 13, 2017 | Dell E2210 22" Widescreen Flat Panel...
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
Gradual diming of screen over the past month.
The speaker assmbly slide out, it has two fingers on it, see pictures here on what to look for inside: http://s807.photobucket.com/home/budm/allalbums
Mar 22, 2010 | Dell E173FP 17" LCD Monitor
My Dell LCD flat screen sometimes has black horizontal lines running across the bottom of the screen. The mouse pointer will not operate in those areas. Is this a monitor problem or a computer problem?...
To me it seems tobe a resoltion problem. Right click on the desktop and select properties->Settings. In the left mid you will find resolution. Reduce it one notch and select OK. If that does not solve the problem then Control Panel->System->Hardware->Device Manager. Here select Display Adapter and remove it. Then from Actions select Scan for new HW. Allow Windows to detect the adapter and load its driver again. Reboot after clicking OK. If that too does not solve the problem then from Device manager above select Monitor and remove and rescan and select and reboot. That should sovle all your display problems.
Nov 05, 2009 | Dell Computers & Internet
Black box in middle of screen
Push your memu button and it should disappear.If that doesn't work, contact Dell.com and they will talk you through it.
Sep 14, 2009 | Dell E173FPb 17" TFT LCD Monitor
Monitor goes black after running for a few minutes. Brand new 22 inch sceen.I prees the button to turn it on and it says Analog and goes black again. I have to shut down the computor to get it to come back...
Sounds like the computer is shutting it down and the monitor is fine. Check for viruses then check your settings in device manager for the screen saver and power down (screen off) options.
Aug 10, 2009 | Dell Computers & Internet
E207WFPc Dell Monitor goes black after seconds of poweron.
The problem you have mentioned may not be due to contrast setting but the LCD itself . Power on the mointor and disconnect the signal cable from the back. if you see a self test box running on the LCD , the LCD is oK . If you donnot see the self test box the LCD is back. Dell doesnot service LCDs and you may need to get in touch with the local repair shop.
Following link may be helpful
http://tinyurl.com/lssmoa
Thanks for using Fixya
proton
Jul 27, 2009 | BenQ FP92W LCD Monitor
WHEN I SWITCH ON LAPTOP,THE SCREEN APPEARS BLACK AFTE USING FOR SOME TIME. IAM USING HCL BRAND AND OPERTING SYSTEM IS WINDOWS VISTA.PLEASE SAVE ME
I'd say your contrast is turned down, change contrast and brightness by pressing the buttons on your monitor.
May 23, 2009 | Dell Inspiron 6400 Notebook
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Computers & Internet Logo
339 people viewed this question
David Payne
David Payne
