Question about Kenmore 73952 Gas Dryer
GAS VALVE CHATTERS DOES NOT OPEN - Kenmore 73952 Gas Dryer
    Problem Solver:
COILS ON THE VALVE ARE BAD. REPLACE.
Posted on Feb 02, 2010
Faucet loudly chatters at higher volume restricting the water flow.whats wrong
If this is a single faucet as opposed to a mixed faucet then the issues is the valve seat and seal. If this is a combo or mixed then you can get a kit for it to replace the mixing valve that has all those parts.
Oct 03, 2016 | Plumbing
1F ERROR CODE appears on Hayward model # h250PED2
Code Fault Diagnosis Step Remedy
None
Open FC3 and/or
F1 Fuses
1. Check for faulty Gas
Valve wiring.
Inspect Gas Valve wiring. Ensure insulation on wiring is not worn. If
OK, proceed to step 2.
2. Verify that Gas Valve is
not defective.
Mesure for resistance across Gas Valve terminals and between each
terminal and ground. If short exists, replace Gas Valve. If OK, proceed
to step 3.
3. Check for faulty Control
Module wiring.
Inspect Control Module wiring. Ensure insulation on wiring is not worn.
If OK proceed to step 4.
4. Control Module is
defective.
Replace Control Module.
Ignition Failure 1. Ensure gas supply shutoff
valves are open.
Ensure that main gas shutoff installed adjacent to heater is open. Ensure
that knob on gas valve inside unit is in ''on'' position. If OK, proceed to
step 2.
2. Check for low gas supply
pressure
Ensure inlet gas supply pressure is between the minimum and maximum
values indicated on rating plate. If OK, proceed to step 3.
3. Check for faulty flame
sense wiring or connection.
Inspect flame sense wiring. Ensure wire harness terminals are securely
fastened to flame sense and to control module. If OK, proceed to step 4.
4. Check for faulty gas valve
Inspect gas valve wiring. Ensure wire harness terminals are securely
fastened to spade terminals on gas valve. If OK, proceed to step 5.
5. Check for gas valve
failure or gas valve relay
failure.
1. Measure voltage across gas valve during trial for igintion. If 24VAC
is present and gas valve does not open, gas valve is defective. Replace
gas valve.
2. If 24VAC is not present, gas valve relay on control module is
defective. Replace control module.
6. Check for blockages in
gas orifices and burners
Inspect gas orifices for blockages which could prevent gas flow. Remove
and inspect burners for blockage
Jan 02, 2015 | Hayward H Series Electronic Ignition...
How does laars esc bypass work and how do i test it heater gas valve chatters on and off after running fine for 3 minutes
the internal by-pass regulated the amount the cold and hat water going in and out the heater exchanger. remove and check the condition for calcium build up or corrosion. now the fact the gas valve chatters check for hi gas value (pressure) or not enough .also check for any sediment going into the gas valve ,make sure you have a sediment trap install in you gas line.
Jun 07, 2013 | Pool & Spa
Fuel pump relay chatters
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Oct 12, 2012 | 1995 Buick LeSabre
The valve chatters and small amount of gas comes through.
could a loose connection on the gas valve or it has come apart in the gas valve stopping the flow of gas which could mean a new valve
Jan 09, 2011 | Heating & Cooling
Main gas valve will not open . already replaced starter
have you replaced the primary and secondary gas valve coils located on the gas valve body,they get weak and cant hold the gas valve open
Feb 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Engine (97 ford ranger) stopped at stop lite and would not restart. Spark to plug wires, plenty of gas, good battery. after cranking several times, will start and run 3 or 4 sec. THE RELAY TO THE FUEL PUMP...
You should have to get the truck scanned for codes, so there will be an exact direction to diagnose.
It could be you gonna have a bad valve cover gasket or the electrical connection that goes from valve cover gasket to injector.
It's also possible that the injector could be bad but you would have to test the electrical system to injector to determine that. I recommend you have truck scanned and we'll see what code it is and try to figure out what's going on.
Oct 05, 2009 | 1997 Ford Ranger SuperCab
Main flame does not stay on or does not come on
THE CHATTERING SOLENOID IS FAILING INTERMITTENTLY AND NOT OPENING UP THE GAS VALVE. REPLACE THE SOLENOIDS AS A SET. THEY USUALLY COME PURCHASED AS A SET.
Apr 22, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 73952 Gas Dryer Logo
69 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
