Question about Acer Aspire 5500 5570-2609 Laptop
My laptop won't charge or run on ac power.. none of the lights light up so I know it is not getting any power.. is it power cord? connector? and how would I fix it?
  • 2,005 Answers
If you know how to use a multimeter check your power supply; plug it in and,check for about 19 volts at the computer side of the plug if that is ok; check the motherboard power socket; plug in the power supply and, wiggle the computer side of the plug while it is in the socket while you press and, hold down the power button. If that does not work the motherboard will need professional repair or, replacement.
Posted on Feb 01, 2010
  • Acer Master
  • 2,517 Answers
Watch the Connector green light is on or not. Must be ON.
press proper all the connector point.
Remove the battery & try to play the laptop.
If nothing changed then visit service center.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
OW TO GET MY ACET ASPRE ONE IT STOP BLACK SCHREEN NO POWER
Step by step troubleshooting.
Verify power outlet is good
Verify power adapter is good
verify connection to computer is good
fully charge battery
test
=======do this
Check power source, plug known good light into AC receptical.
If AC cord has connector to power block verify it is properly seated.
plug adapter into AC outlet
Verify Power is present at power connector with another similar computer or voltmeter. (12V to 20V)
When plugged into computer, charge (not power) indicator MUST light either red, amber, or green. If not, connector on computer may be broken.
leave overnight or until charge light is green
turn on normally.
most likely causes:
- loose connector
- broken wire from power adapter
- broken power plug on computer.
- anything else is probably beyond ur capabilities to fix.
Aug 10, 2014 | Acer Aspire One PC Notebook
Lenovo idea pad won't charge or run plugged in
Is the cord and Battery the EXACT same power spec? If so, it may be the AC jack in the Laptop has been damaged due to pulling on the cord while plugged in, broken connection.
Apr 06, 2013 | Lenovo IdeaPad Y450 Notebook
The battery on my laptop stopped charging, but was working for a over a week, then it was acting funny and slow.. I shut down moved to another room and it won't boot up! The light doesn't come on...
I think your power cord is bad. It probably was not charging the battery at all and so now all your battery power has drained since you were running on it. Once the battery power is drained and if the AC Adapter Power Cord is not working the computer will not boot because it has no power source.
Some AC Adapter & Power Cords have lights on them to let you know when it is plugged in if it is working. Normally when you plug the power cord in the laptop somewhere on the laptop lights up to let you know it is receiving power. Sometimes the light is where you plug it in, sometimes at the front of the laptop or right above the keyboard area.
I thing you need a power cord. And don't settle for one of the one size fits all (with a removable tip designed to fit any laptop) that the big box stores will sell you.
If your power cord is good and the laptop is not receiving power then the problem could be your DC Power Jack where the power cord plugs into the computer.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Apr 03, 2012 | Acer Computers & Internet
Laptop won't start up
I'm inclined to think that your power cord is bad and you have drained your battery.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Fujitsu Siemens Computers & Internet
My LG laptop is not powering on. what will i do? I didn't used it for three days then when I started to turn it on. there is no power. When I put the power cord, there is no light on the battery. What...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 06, 2011 | LG Computers & Internet
My sons power pack died leaving laptop with dead battery. small light flashing orange at the front .i bought a replacement power pack making sure it was for his model.plugged it in and nothing it wont...
May 25, 2011 | Advent 4211c Notebook
My toshiba satellite l35 wont turn on,,,the light blinks then shuts off ,,,thats all it does
May 17, 2011 | Computers & Internet
Unit will not power on// has a solid amber light// turns green for about 3 seconds then back to amber
You may have a bad DC connector:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 17, 2010 | IBM ThinkPad T20 2647 Notebook
Hello, I am having problems with my Compaq nx6110 laptop not charging. It is not the battery, as I replaced it at the end of December. The problem seems to be that the charge isn't reaching the battery,...
If you remove the battery, does the AC Adapter power the computer? Does the laptop have a barrel type power connector? I have replaced several power connectors for broken center pin. Does wiggling the power connector affect the charging light?
Mar 20, 2010 | HP Compaq nx6110 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
