Question about Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G
How do I put auto fill on my tool bar? I also can't find the tool wrench.
    Problem Solver:
  • 5 Answers
Try to make sure that your toolbar is not locked by right clicking on it. than you can slide toolbars around in different spots to reveal longer options. you may see your wrench there that will help you enable auto-fill
Posted on Feb 01, 2010
How to install the trunk lid torsion bars on a 2007 Saturn Ion?
The procedure is the same on every vehicle that uses this type of opening assist. So here is another persons instructions on a GM product.
Tools used:
Leather gloves!!
3/4" combo wrench (biggest I had)
1/2" deep socket (3/8")
6" extension (3/8")
1.With the trunk lid up and the curved part of the torsion bar against the rear trunk wall, I slipped the box end of the combo wrench around the torsion bar. I don't remember which way I had the angle of the box end facing. Just use what will work.
2.Then use the extension and the socket on the end of the torsion bar and push back so that you can get the combo wrench down past the curve, this is key. Once that is done you can remove the socket and extension. Pressure will push the wrench against the rear trunk wall.
3.Now comes the fun part. Push the wrench forward (VERY CAREFULLY) all the way past the side engine grill support and onto the peg of the hinge. The tip of my torsion bar just nicked the grill support. Make sure the wrench is seated well because it could slip around on you and cause your paint some damage and maybe even you.
4.Now that the torsion bar is on the hinge peg, you'll notice that your left with a wrench stuck on the bar... Just move (wiggle, twist) the wrench as far to the end of the torsion bar as it will go.
5.Take the extension, without the socket and place over the tip of the torsion bar. Push down while you slip the wrench past the peg. Remove the extension and slip off the wrench.
6.Now use the extension again to push down and put the roller (plastic, metal) bearing onto the peg.
7.Secure all the bolts, and lube it up.
That's it. Hope it'll help someone else. Please be careful.
Feb 09, 2017 | Saturn Cars & Trucks
How does the fan come off the water pump for a 2002 denali?
THE EASIEST WAY TO DO THIS IS TO HAVE A AIR COMPRESSOR AND A AIR HAMMER WITH A FLAT HEAD CHISEL PUT THE HAMMER CHISEL ON THE END OF THE BOLT AND BUZZ IT OF TO THE LEFT TOWARDS THE PASSENGER SIDE .TO PUT ON JUST USE YOUR HAND TO THRED IT BACK ON SNUG IT WILL TIGHTEN ITSELF ON START UP.IF YOU DONT HAVE THIS STUFF IVE SEEN PEOPLE USE A HAMMER AND LONG BAR WITH A FLAT HEAD AND BANG IT OFF..OR AUTO ZONE AND RENT THE TOOL LONG SKINNY WRENCH.
Aug 05, 2011 | 2002 GMC Yukon Denali
How to replace a serptine belt need diagram
Hello country.... the auto-tensioner has a bolt in the center of the pulley. Use either a wrench or (preferably) borrow the proper tool which is just a wrench on a nice leverage bar. When you put pressure the tensioner pulley arm will swing and give you room to remove and replace the belt. Just don't be afraid of loosening the pulley (that was my fear) and don't try a hex wrench on the engine mount side of the tensioner arm.
images?q=tbn:and9gcrdwc1lacwunqlzkmyabrcalmxivclre_ffu1cahcjazdtthmd2
Jun 17, 2011 | 1999 Honda Passport
How do i change the assesories that come with dremil how do i use the hand held dremil??
If you have the standard dremel tool ther is a small bar sticking out at the collet end of tool. This is a locking rod to hold motor shaft in place so you can loosen coollet nut. Put pressure on thebar and slowly rotate the shaft until the bar drops in place. There should be a small open end wrench that comes with your tool to loosen nut. If not use asmall wrench to loosen nut.Turn it counter clock wise to loosen. It is not needed to take the nut all the way off. You may have to move tool slighyly to get it to come out.
The tool that you use is determined by what job you are trying to do.Most come with abrasive cut off wheels small grinders,sanders,and polishers.To secure new tool in collet just insert tool shaft in collet and tighten down. When it gets snug then Depress locking bar to finish tightening. Hope this helps you some. Thank you.
May 29, 2011 | General Hand Tools
How do i get fan clutch loose on 97 ford explorer to put water pump on
Below are the tools used to loosen the fan/clutch from the water pump. Similiar tools can be purchased at harborfreight.com or at some large auto parts stores. The large tool can be attached to a breaker bar. It is positioned over the four water pump pulley bolts while the wrench tool turns the fan nut. It's a bit awkward but works. Good Luck!
Apr 18, 2011 | 1992 Ford Explorer
How do i change the oil in my 1994 buick park ave
first you will check your owners manual for the required specification of what weight ( 10w30) oil to use and then the fill capacity.( 5.quarts ) also the auto parts store will tell you those as well. I always buy one extra quart. Once you have oil and filter, warm car up for 3-5 minutes, (this will help oil drain faster and easier) once car is warm shut of motor,block rear wheels jack the front of car up enough to slide under it. BLOCK car or support with jack stands.put a drain pan under car, remove the oil drain plug on the bottom or side of the oil pan.( make sure your catch pan will hold at least 6-7 quarts of fluid. once oil has stopped draining replace drain plug, now remove the oil filter, unscrew counterclockwise, lube new oil filter seal with oil, screw on to oil housing clockwise rotation, hand tighten. fill motor with oil to recommended fill capacity.start car , check for leaks around filter, if no leaks shut car off and lower car to ground, check oil on dipstick and wipe off,insert and check again,fill to fill line on dipstik and your done.
Jan 14, 2011 | 1994 Buick Park Avenue
Google is my home page,I'm missing a tool bar that had auto fill, etc. How do I get tool bars back.
mcdevito75 here, at your google home page you can right click on the tools top of your screen and check the Google tool bar. this should restore your google tool bar.
Jul 07, 2010 | E-Machines eMachines Desktop PC
Can't take off serpentine belt on my 97 dodge stratus
you need a serpentine belt tool for the tensioner bolt. they are a flat bar with hex cut outs in them.you have to release the tensioner first or the belt will not come out.Auto parts places carry the tool.
Apr 13, 2010 | 1997 Dodge Stratus
Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G Logo
266 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
