Question about GE GSD3800G - Multiple Color Built-in Dishwasher
GE GSD 4920 digital display not lighting up, but the machine is running. How do I fix this? Ilana
    Novelist:
  • 127 Answers
If its actually running through the cycle normally, with all functions as they should then the power board is ok, BUT the display board part # WD21X780 - SIG BRD&HSG**NLA 01/08** is showing as no longer available unfortunately.. if you can find it expect to pay a fair chunk of change for it..
However if you tear the door and console apart you may inspect the display control board and find a very obvious broken wire to the display.. ya just never know.
best of luck, and have fun,
ttfn
Posted on Feb 02, 2010
Serial # FL442725 GE stainless steel is not running. Light is on but the motor or digital numbers do not appear on the digital display window.
sounds like you have an electrical problem with either your display or main control board. Your more than likely going to have to contact a tech for more assistance (in person)
Aug 09, 2013 | GE GSS25SGSSS Stainless Steel Side by Side...
What causes the water to stay running on a ge gsd series dishwasher?
The float is stuck it may need to be replace it is located on the front left side of the dishwasher
Apr 08, 2013 | GE 24 in. GSD1000G Built-in Dishwasher
Acer 4920 randomly restarting
might not be the fix but try getting the hover and where the fan outlet is give it a good hover the fan can get blocked and this will make the cpu shut down when it gets to hot
Jan 13, 2013 | Acer Aspire 4710 4920 4935 4930G 4930...
I have standing water in bottom of GE GSD 666 dishwasher. I pressume I need to clean screen/filter? How?
I have the same problem, same model GSD660G0322. Have an inch or two of standing water. When I run the drain pump in Service mode, it successfully clears the water. How do I access the filter to clean?
Oct 22, 2011 | Dishwashers
My GSD 21 is mated to a Garmin 3210. Bought both componants new. Every single year since new it works 2-3 trips. Then just doesn't come on. Have to send it back to garmin who so far have waranted...
The GSD 22 is discontinued. I would not buy any electronics that are discontinued, because there has to be a reason.
If I were in your shoes I would be looking a full change to either the brand leaders, Raymarine or Humminbird. I have had Humminbird since 2007 with a 798SI and since 2014 with a 998SI HD. 100% reliable for GPS and depth. Boat used twice a week May to October. The 998 has features to set a chart course and I do that when coming from Toronto to Port Credit. Humminbird also do full chart plotters, but in Georgian Bay, I wouldn't have thought necessary unless you use an auto-pilot. Uses Blue Chart maps.
You aren't the only one to have problems. Read the link below.
I did find this thought and there are others in the thread
http://www.thehulltruth.com/marine-electronics-forum/146766-installer-i-stumped-garmin-problem.html
Make certain that the transducer(s) cable is separated from any engine power cables. When those wires cross or are bundled together, the highly sensitive sonar signal gets polluted with high amp noise bleeding off the engine wires, and you're lucky to get any signal.
To test if this is the problem, shut your engines off and see if you get a good sonar view. Then start the engines and see if the same sonar quality is displayed. If it degrades, you've got the current bleeding problem.
I had this problem when I installed the new gear (Furuno 585, Airmar b60) and ended up re-routing the transducer cable using some "wire hangers" to keep the transducer cable away from the others. Now I get a firm fix on the bottom at all speeds and the only time the display gets lost is when I reverse the starboard engine, from air bubbles under the thru-hull.
GSD 21 with 3210 problems - Google Search
Mar 21, 2017 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
GE Profile Dishwasher Mod. #GSD 4430
I have the same problem right now. What is the casue?
Oct 19, 2008 | Dishwashers
GE Nautilus - GSD 4200J00BB
i try to reply to evertone what is it in regards to?
Sep 09, 2008 | GE Nautilus 24" Built-in Dishwasher
Corrected serial # on Nautilus dishwasher
Ok, great! I found the correct part for your model number. To view the pump/motor assembly, click here. Hope this was helpful.
Jun 25, 2008 | GE Nautilus 24" Built-in Dishwasher
GE GSD3800G - Multiple Color Built-in Dishwasher Logo
519 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
