Question about Hotpoint Aquarius WF000 Front Load Washer
My washing machine is making rattling noises when spinning. it will be safe to open the basket from the top to inspect?? or you think is the bearing that are gone??
    Sergeant:
  • 215 Answers
More likley bearings
Posted on Feb 08, 2010
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
Dec 08, 2017 | Washing Machines
GE Washing Machine WWSE6260B1WW won't spin out water makes a rattle noise
use a putty knife to remove the front panel , you can remove it by pushing the putty knife into the 2 black tabs between the top and front panel. from there you can get to the drain pump . inspect by taking the hoses off the pump and remove debris. If nothing found replace the pump. hope this helps, let me know
Feb 19, 2013 | Washing Machines
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
How do I stop my aav 8000 washing machine from making a rattling noise in spin cycle? It's on level ground ;-\ I disassembled some of the washing machine and the noise is coming from a metal par
It is so common that the washing machine can maketerrible noise in many ways and is a common fault. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that machine isvibrating when it is running then the motor /drum suspension has to beinspected. Since these fittings are located on the underside of the machine itis important that you look for the noise with a good inspection lamp. Manuallyturn the motor and drum and listen for the noise, if so the motor bearings, thedrum agitator shaft and fittings must be checked. Also the suspensions whichinclude the shock absorbers and springs, the body clamps must be checked to bein correct alignment and not changed in position. Tightening of themounting is also very important. Finallyin most cases a drop of OIL or smear of grease on the moving parts cane solvemost issues.Check this link :http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlFor replacement of bearings check for tips on thisvisual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jul 05, 2012 | Admiral Washing Machines
My washing is getting bits of dirt on it. How do I clean out the machine?
Below are tools and instruction need to solve the problem.
If your washing machine begins making strange noises such asrumbling, banging or screeching, it is time to troubleshoot the problem and fixthe machine. A noisy washing machine that's ignored can become expensive lateras the problem worsens and leads to damage of more expensive parts.
1 Inspect inside the basket for loose items. Objects such as coins, pens andpaperclips can fall out of pockets and become lodged in the basket. Run themachine again to test for any further noise.
2 Remove the top panel bysliding a flat-head screwdriver under the panel and releasing the clips. Slidethe top off of the machine and shine a flashlight into the sides of the basketto check for loose items. Remove any items and run the machine again.
3 Place a level on top of themachine and verify that it is completely level. If the machine is at alluneven, adjust the bottom feet by turning them to the right or left. On mostmachines a turn to the right will raise the machine and a turn to the left willlower it. If the machine is level or still making noise after adjustments,continue trouble shooting.
4 Replace the drum bearings.Review your owner's manual to locate the drum bearings. Unplug the machine andturn off the water supply. Remove all necessary panels with a screwdriver.Remove the driver belt and manually spin the drum. If it makes a rumblingnoise, then unscrew the drum bearings and replace them.
5 Replace the drive belt as well if it isworn, cracked or loose. This will prevent the need to re-open the washingmachine if the noise continues after replacing the drum bearings.
6 Re-assemble the machine and run it again. If it isstill making noise, contact a repairman for a consultation.
Thanks for using fixya.
Sep 06, 2011 | Fisher and Paykel GWL11 Top Load Washer
FAV6800AWW is very loud in the spin cycle only, the basket does move freely and the belt is in good condition. the noise does not seem to be from the clutch,
Derek,
What are the first two digits of you serial number of you FAV6800A or FAV9800A? It will digits 10, 11, 12,thru 17.
In spin Cycle the Wash Basket rotates in the Outer Tub bearings in the CCW direction. I1f you spin the wash basket CCW by hand as fast as you can the Wash Basket should cost several revolutions to a gentle stop. Does it?
Do you hear and bearing noise/grinding sounds as the wash basket coast to a stop? If so I would drop the clutch out and inspect for traces of a Tub Seal leak.
My Clutch Fix will help you disassemble and let me know if can help. I have …….Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The neptune TL model 6800AWW makes a terrible noise at what seems to be the end of the wash cycle. Is this a rebalance? Because it sounds like metal against metal. Or could this be a belt issue. The...
Hello acelmo3,
Thank you for the model number, can you give me the first two digits of your serial number. That number is located on the back right side of the console. I only need the first two digits.10, 12, 16,,,etc.
Let's try to troubleshoot the grinding noise issue, You mention the spin cycle. Have you taken any dc or UC errors in spin cycle? Can you try the following and let me know what you find?
1. Open the lid and rotate tie wash basket by hand Counter Clock Wise, CCW. The wash basket should rotate freely with no restriction. The wash basket will not rotate Clock Wise, CW by hand.
2. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 2. (See page 33 of the Service Manual for putty knife insertion point). Also see pic attached.
3. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it will begin to rotate CCW. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction and the Spin Cycle will fail with dc/UC errors. If this is not the situation move on to step 3. This is what I refer to as a soft failure and possible clean up of the clutch roller bearings in the clutch hub may restore normal clutch operation. A hard failure would be the clutch spring has failed, the roller bearings are rusted beyond clean up. A replacement clutch is required.
Pic attached for top cover removal .
Let me know if you see the tumblers rotating in Spin Only cycle and if yo hear the grinding noise. Rich
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Frigidaire front load washer making a noise and jumping when going through the spin cycle. Why???
If this is a brand new washer, make sure the shipping materials are all removed, yellow shipping pins in back, styrofoam blocks etc. If this is an older machine, new problem, empty the machine, reach into the washer and give the basket a good hard spin, if you hear any type of grinding noise, or excessive rattling, your bearing and possibly the spin basket support are bad. I would also remove the top and front- bottom panel, and make sure the suspension springs and shocks are not broken before assuming the bearing, as this is a very lengthy and expensive job, (although the basket itself should have a lifetime warranty).
Sep 15, 2008 | Washing Machines
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
98 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
